full lotus floats
usher
PostPosted: Fri May 04, 2007 11:05 pm    Post subject: full lotus floats Reply with quote
Am mounting full lotus floats on my FK 111. What is best distance for CG forward of step and what angle of incidence of float to chord. Thanks.
Don
Kcozik(at)cablespeed.com
PostPosted: Sat May 05, 2007 3:25 am    Post subject: full lotus floats Reply with quote
HI Don,
I have collected some general information which may help you in your installation. I'll get it from my hangar today or tomorrow and forward it to you. I know there are a few kitfoxs mounted on full lotus floats so finding specific mounting instructions should be easy. Have you contacted full lotus?
Kevin Cozik
S6-7 914 turbo (30 days 'til inspection)
Czech ampibs
Lansing Michigan
Float Flyr
PostPosted: Sat May 05, 2007 6:16 am    Post subject: full lotus floats Reply with quote
The Full lotus folks should be able to give you all the info you need for that install. There are lots of them around here.
[img]cid:989461314(at)05052007-17EA[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  462 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
