DAquaNut(at)AOL.COM Guest
Posted: Wed Feb 08, 2006 8:35 pm Post subject: Evening flight |
Group,
I am having so much fun with my Firefly I cant stand it any longer. I
had Miss Bliss up for 2 hours this evening. The wind was knocking me around
pretty good on takeoff and low passes, so I took her up to 3000 ft and it was
smooth and a good bit cooler but I was dressed for it. Tried out a little
venturi I made to get the airspeed to read higher, but it worked too well and I
will have to work on an adjustment for it. Made 2 landings and bounced it a
bit, but I had it at about 3500 RPMS as was suggested by list members.
Everything is still straight. Those aluminum axles are tougher than I was led to
believe. I already made up 3 pair of 4130 axles and had them heat treated,
just in case. I flew for 2 hours and burned 3 gallons. Course I was only
playing around. That Firefly climbs about twice as fast as the Wizard I used to
have. I now have 4 hours on it and I'm still a grinnin !!!!
Ed Diebel
Hou. TX ( Firefly--- More fun flyin than
building)
Do Not Archieve
JetPilot
