Yak52(at)aol.com Guest
Posted: Sun May 06, 2007 7:18 am Post subject: facet fuel pumps |
I have installed two facet 40108 pumps in series on the floor in front of the gascolator in a 601xl. The line then goes through the firewall to the carburetor on a continental 0200a. There is no pressure regulator except the pumps themselves. The fuel pressure indicator is at the carb. Upon starting, the fuel pressure using one pump goes to 4 pounds, but at cruise rpm's the pressure goes to 1 pound. Adding the second pump raises the pressure at cruise to 7 pounds, but floods out the carb if rpm's are lowered to pattern power settings. I am at a loss to explain, but searched the archives and noticed that others have had low pressure problems with the facet cube pumps upon occasion. Is the installation in series the problem? Are the pumps not of sufficient volume? Should I go to the traditional piper style 480545 facet interrupter pumps? There is no mechanical fuel pump on this engine as it was taken from a cessna 150.
Yak52(at)aol.com (Yak52(at)aol.com)
See what's free at AOL.com.
Posted: Sun May 06, 2007 9:01 am Post subject: facet fuel pumps |
One problem you certainly have with this setup is loss of electrical power will kill the engine. Since you have a low wing, fuel will not get to the engine if power is removed from the electric pumps. That is why it is customary to use a combination of electric and mechanical pumps on an airplane.
It seems prudent to add a mechanical pump to this installation.
Paul
XL fuselage
At 08:16 AM 5/6/2007, you wrote:
[quote]I have installed two facet 40108 pumps in series on the floor in front of the gascolator in a 601xl. The line then goes through the firewall to the carburetor on a continental 0200a. There is no pressure regulator except the pumps themselves. The fuel pressure indicator is at the carb. Upon starting, the fuel pressure using one pump goes to 4 pounds, but at cruise rpm's the pressure goes to 1 pound. Adding the second pump raises the pressure at cruise to 7 pounds, but floods out the carb if rpm's are lowered to pattern power settings. I am at a loss to explain, but searched the archives and noticed that others have had low pressure problems with the facet cube pumps upon occasion. Is the installation in series the problem? Are the pumps not of sufficient volume? Should I go to the traditional piper style 480545 facet interrupter pumps? There is no mechanical fuel pump on this engine as it was taken from a cessna 150.
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Sun May 06, 2007 10:14 am Post subject: Re: facet fuel pumps |
The pressure should double for two fuel pumps in serie. According to an email answer of info(at)facet-pumpen.de it is important that you keep a distance of at least 40 cm (= 15 inch) between the two pumps.
I would always rely on a mechanical pump too!!!
Rgds
Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
jetboy
Posted: Sun May 06, 2007 9:39 pm Post subject: Re: facet fuel pumps |
The 0-200 has a mount pad for mechanical pump for your application, so best practice is to fit one and use one electric pump as boost pump. its also possible to fit the electric pumps in parallel, with a non-return check valve in each outlet line, if the pumps dont alredy have this. But you need dual electric supply then.
Ralph, ex - c150
_________________ Ralph - CH701 / 2200a |
s.c.richards(at)homecall. Guest
Posted: Mon May 07, 2007 9:08 am Post subject: facet fuel pumps |
Hi If you have a Marvel Carburettor for use with a mechanical fuel pump I believe the Max inlet pressure is 6 psi. I believe I read in the 0200 manual that a different carb inlet valve is used with gravity feed due to lower pressure I assume you have this fitted if your carb is off a C152. You may be able to confirm this by asking carb manufactures or looking in there web site.
Ray's 601 I fly has a facet 40106 rated 4-5.5 psi on fire wall as a backup in parallel with the engine driven pump the feed is from header tank through gascolator to pumps.
We donot have a pressure gage fitted so donot know running pressures.
We topup the header tank from wing tanks with a facet 40105 pump supplied with kit. There will be a lot of information on fuel systems in the archives.
do no archive
Clive Richards
Ray Lasnier 601HD Continental 0200 110 Hours todate
