Posted: Sun May 06, 2007 9:28 am Post subject: Flap Seals |
| Quote: | John mentioned how sealing up the aircraft would clean up the lines,
resulting in better speeds. I decided to add some gap seals to the
wing, to seal the flaps, upon retraction. What I used was a 2.25"
wide piece of .020" styrene, a product that I use, almost daily in my
sign/graphics business. I attached it to the wing using 1" hem tape
(a very strong, two sided tape, used to hem banners).
Hey Jeff...
I've also had email exchanges w/ John Lawton and have perused a site he
recommended for info on gap seals...all very interesting. Could you go
into a little more detail on the nature of your installation? Exactly
where and in what plane have you attached this styrene? Does it create
a pressure seal?. In what way does it alter the airflow?
Fred
A194
working on cockpit module (finally!)
topglock(at)cox.net Guest
Posted: Sun May 06, 2007 12:30 pm Post subject: Flap Seals |
Fred,
I took some pics, but haven't had a chance to post them. The process is
dead simple, though. I cut two pieces of styrene, 2.25" wide, the
length of the flaps (about 63"), then added the hem tape to one edge.
The tape is 1" wide, so I marked back 1" onto the wing and drew a line
with a grease pen, parallel to the underside of the wing edge. I then
notched the styrene, where it had to clear the flap hinges, removed the
backing tape from the hem tape and applied the strip to the wing. The
width was such that it covered the gap, spilling over onto the flaps.
It is not truly a pressure seal, but is sufficient to direct the air
under the flap and not up, into the closeout. My guess is that it also
deflects the air, under the flaps, even with the flaps deployed, as
there is a definite lack of drag. If you do this mod, be prepared to
re-learn your approaches and it wouldn't hurt to have a good bit of
runway on the first few attempts...
Jeff - Baby Blue
Fred Klein wrote:
Hey Jeff...
he recommended for info on gap seals...all very interesting. Could you
go into a little more detail on the nature of your installation?
Exactly where and in what plane have you attached this styrene? Does
it create a pressure seal?. In what way does it alter the airflow?
Fred
A194
garrys(at)tampabay.rr.com Guest
Posted: Sun May 06, 2007 1:07 pm Post subject: Flap Seals |
Jeff, did you think about applying gap seals to the ailerons? Any reason to
do just the flaps?
Garry
96victor(at)gmail.com Guest
Posted: Sun May 06, 2007 3:14 pm Post subject: Flap Seals |
Thanks Jeff
Is the hemtape "Orabond?'
Is the styrene available at sign makers?
Don't some of the glider guys use mylar for seals/
Tom
On 5/6/07, Rman <topglock(at)cox.net (topglock(at)cox.net)> wrote: [quote]--> Europa-List message posted by: Rman <topglock(at)cox.net (topglock(at)cox.net)>
Fred,
Jeff - Baby Blue
Hey Jeff...
Fred
A194
working on cockpit module (finally!) [quote][b]
daseitz(at)cfl.rr.com Guest
Posted: Sun May 06, 2007 3:49 pm Post subject: Flap Seals |
The flaps on the Europa are Slotted Flaps. They are designed to let the air
go thru the slot from the bottom to the top of the flap. The next step up is
the Fowler Flap design.
Dean Seitz
Posted: Sun May 06, 2007 4:19 pm Post subject: Flap Seals |
On Sunday, May 6, 2007, at 01:29 PM, Rman wrote:
It has also resulted in more float, during landing, which I attribute
to reduced stall speeds. I say reduced stall speeds, because, by
reducing my final approach from 65 kph to 60 kph, across the numbers,
Baby Blue lands like she used to.
also deflects the air, under the flaps, even with the flaps deployed,
as there is a definite lack of drag. If you do this mod, be prepared
to re-learn your approaches and it wouldn't hurt to have a good bit of
Jeff...Thanks for your very clear explanation of your installation.
There are no doubt folks on this list w/ more knowledge of aerodynamics
than I, but I believe that the Europa flap design is such that when
deployed, some portion of the increased lift is the result of air
flowing over the top of the flap as the flap drops and moves to the
rear when deployed.
Of course even when the flap is retracted, some air will find its way
up thru the gap between the leading edge of the flap and the vertical
face of the wing closeout, and it is this airflow which one wants to
eliminate in order to enhance cruise efficiency.
If this is so, it would seem that another way to get this increase in
cruise efficiency might be to install a compressible strip which would
close the gap when flaps are retracted but allow airflow over the flaps
when they are deployed, thus maintaining the short field
characteristics of the aircraft which, if I understand you correctly,
have been changed.
Keep us posted on your testing,
Fred
tonyk(at)kaon.co.nz Guest
Posted: Sun May 06, 2007 4:47 pm Post subject: Flap Seals |
| Quote: | >
have been changed. <<
Adding compressible strips in the flap closeout was suggested to me some
time ago by a person with many years of aeronautical design experience.
The key is to close the airflow from lower to upper surface during
cruise but to ensure that the lower to upper airflow over the flap
remains per the design spec when the flaps are down.
This is quite easy to achieve by adding some light doorstop strip into
the flap closeout and, in many cases, will have already been achieved on
the port side if the pitot/static lines were run in the flap closout as
part of a retrofit.
Tony
Posted: Sun May 06, 2007 7:13 pm Post subject: Flap Seals |
Tom Friedland wrote: | Quote: | Thanks Jeff
| Yes. Very strong stuff...
| Usually from a supplier, but some, such as myself will have some in stock...
| I believe they do...
Tom
On 5/6/07, Rman <topglock(at)cox.net (topglock(at)cox.net)> wrote: | Quote: | --> Europa-List message posted by: Rman <topglock(at)cox.net (topglock(at)cox.net)>
Fred,
Jeff - Baby Blue
Fred Klein wrote:
> --> Europa-List message posted by: Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)>
> Hey Jeff...
> Fred
> A194
> working on cockpit module (finally!) |
Posted: Sun May 06, 2007 7:15 pm Post subject: Flap Seals |
I thought about it, but believe that the aileron is sufficiently
recessed to negate the need. My opinion, of course. I also considered
the compressible seal, but did not have any around the shop. Might
still try it out, as replacing the styrene would be easy and cheap,
should I decide to return to that...
Jeff
reason to do just the flaps?
Garry
william(at)wrmills.plus.c Guest
Posted: Mon May 07, 2007 12:11 am Post subject: Flap Seals |
If anyone in the UK finds a suitable lightweight compressible strip, please
let us know the source and the material spec.
The ailerons can be sealed by flexible adhesive tape placed over the
underside gap along the hinge line with the aileron in the full up position
(so as not to restrict any movement).
William
wdaniell(at)etb.net.co Guest
Posted: Mon May 07, 2007 1:56 am Post subject: Flap Seals |
Hmmm that would have been my question too. My understanding was that the
flaps were designed to ensure flow up through the gap. Perhaps someone can
shed light on this.
Will
willie.harrison(at)tinyon Guest
Posted: Mon May 07, 2007 3:19 am Post subject: Flap Seals |
Presumably, UK aircraft couldn't have this mod without the blessing
of the PFA??
On 7 May 2007, at 10:55, William Daniell wrote:
<wdaniell(at)etb.net.co>
that the
someone can
shed light on this.
Will
rogerabc
Posted: Mon May 07, 2007 11:37 am Post subject: Flap Seals |
This appears to fit the bill:
http://www.lasaero.com/las/30?part=DTD5531-60
10mm very soft silicone P seal which compresses easily to 3mm
They sent me a sample but I haven't bought the full length yet.
Cheers,
Roger
On 7 May 2007, at 09:09, William Mills wrote:
<william(at)wrmills.plus.com>
strip, please let us know the source and the material spec.
the underside gap along the hinge line with the aileron in the full
up position (so as not to restrict any movement).
William
ami(at)mcfadyean.freeserv Guest
Posted: Mon May 07, 2007 12:12 pm Post subject: Flap Seals |
Roger,
Could you double-confirm please that the 10mm dimension is the thickness
prior to compression, or the width.
Duncan McF.
Posted: Mon May 07, 2007 2:17 pm Post subject: Flap Seals |
If this seal is suitable, it would appear that it would stop airflow
thru flap gap when flaps are both deployed and retracted.
Is it then incorrect to believe that air flowing thru the gap w/ flaps
deployed is desireable for max. lift?
Fred
A194
On Monday, May 7, 2007, at 12:35 PM, Roger Sheridan wrote:
<rogerjohnsheridan(at)yahoo.co.uk>
Cheers,
Roger
| Quote: | >> The key is to close the airflow from lower to upper surface during
>> Tony
rogerabc
Posted: Mon May 07, 2007 11:14 pm Post subject: Flap Seals |
It's the diameter of the circular section of the P & hence the
thickness.
On 7 May 2007, at 21:11, Duncan & Ami McFadyean wrote:
<ami(at)mcfadyean.freeserve.co.uk>
Roger,
thickness prior to compression, or the width.
Duncan McF.
