gvjantzi(at)yahoo.com Guest
Posted: Mon May 07, 2007 5:58 pm Post subject: 912 ul throtlle choke cabel assembly |
I am still trying to get information on what I should order an from where. need throttle ,choke cable Assembly . need everything from cockpit to carburetors. for kitfox 5 with rotax 912ul. is there any model 5 drivers that can give me some input. thanks gerry
TV dinner still cooling?
[url=http://us.rd.yahoo.com/evt=49979/*http://tv.yahoo.com/]Check out "Tonight's Picks"[/url] on Yahoo! TV. [quote][b]
runwayrex(at)juno.com Guest
Posted: Mon May 07, 2007 6:39 pm Post subject: 912 ul throtlle choke cabel assembly |
Gerry,
First place to look for parts for your Kitfox would be John McBean and friends over at the Kitfox factory. Great people with lots of knowledge and parts for our planes. Do you need their contact information?
Rex in Michigan
Model 3 / 912UL / Warp Drive / 570 hours
">http://www.matronics.com/Navigator?Kitfox-List
tronics.com
alnanarthur(at)sbcglobal. Guest
Posted: Tue May 08, 2007 8:23 am Post subject: 912 ul throtlle choke cabel assembly |
On May 7, 2007, at 6:56 PM, Gerald Jantzi wrote:
| Quote: | | I am still trying to get information on what I should order an from where. need throttle ,choke cable Assembly . need everything from cockpit to carburetors. for kitfox 5 with rotax 912ul. is there any model 5 drivers that can give me some input. thanks gerry |
Sportplane LLC is Info(at)sportplanellc.com (Info(at)sportplanellc.com)
Kitfox LLC is info(at)kitfoxaircraft.com (info(at)kitfoxaircraft.com)
John McBean is john(at)kitfoxaircraft.com (john(at)kitfoxaircraft.com)
Debra McBean is debra(at)kitfoxaircraft.com (debra(at)kitfoxaircraft.com)
and finally the telephone is 208 337-5111 and the fax is 208 337-5116
The web page is http://www.kitfoxaircraft.com/contact.htm
paul.kates(at)pathfinderl Guest
Posted: Tue May 08, 2007 4:33 pm Post subject: 912 ul throtlle choke cabel assembly |
Sky Star previously sold the throtle assembly, Mine is a common vernier throtle that I cut to fit. It only has to reach the spliting mechanism. Choke assemblies can be had at various motorcycle shops that sell models with two carbs, or look for a motorcycle parts supply on the internet for a split choke assembly... mine needs replacing as well so I'll let you know what I find.
From: owner-kitfox-list-server(at)matronics.com on behalf of alnanarthur
Sent: Tue 5/8/2007 11:23 AM
Subject: Re: 912 ul throtlle choke cabel assembly
Sportplane LLC is Info(at)sportplanellc.com <mailto:Info(at)sportplanellc.com>
Kitfox LLC is info(at)kitfoxaircraft.com <mailto:info(at)kitfoxaircraft.com>
John McBean is john(at)kitfoxaircraft.com <mailto:john(at)kitfoxaircraft.com>
Debra McBean is debra(at)kitfoxaircraft.com <mailto:debra(at)kitfoxaircraft.com>
The web page is http://www.kitfoxaircraft.com/contact.htm <http://www.kitfoxaircraft.com/contact.htm>
dan(at)azshowersolutions. Guest
Posted: Tue May 08, 2007 5:33 pm Post subject: 912 ul throtlle choke cabel assembly |
Due to the recent development of the light sport RV-12, Van's Aircraft has developed what looks to be a solid choke pull for the cockpit. The new -12 is using the Rotax 912s. I just got a brief look at it, but it is said to make the pull a little easier...I'm looking into it.
FWIW
Dan B
Mesa, AZ
Kitfox IV , Building
Paul Kates <paul.kates(at)pathfinderlwd.com> wrote:
| Quote: | Sky Star previously sold the throtle assembly, Mine is a common vernier throtle that I cut to fit. It only has to reach the spliting mechanism. Choke assemblies can be had at various motorcycle shops that sell models with two carbs, or look for a motorcycle parts supply on the internet for a split choke assembly... mine needs replacing as well so I'll let you know what I find.
jdmcbean(at)kitfoxaircraf Guest
Posted: Tue May 08, 2007 6:02 pm Post subject: 912 ul throtlle choke cabel assembly |
We also offer a simple choke design that works very well…
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
"It's not how Fast... It's how Fun!"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of Dan Billingsley
Sent: Tuesday, May 08, 2007 7:32 PM
Subject: RE: 912 ul throtlle choke cabel assembly
FWIW
Dan B
Mesa, AZ
<![if !supportLineBreakNewLine]> <![endif]>
<![if !supportLineBreakNewLine]> <![endif]> [quote]<![if !supportEmptyParas]> <![endif]><![if !supportEmptyParas]> <![endif]> - The Kitfox-List Email Forum - --> http://www.matronics.com/Navigator?Kitfox-List - NEW MATRONICS WEB FORUMS - --> http://forums.matronics.com<![if !supportEmptyParas]> <![endif]>[b]
andynfultz(at)bellsouth.n Guest
Posted: Tue May 08, 2007 7:18 pm Post subject: 912 ul throtlle choke cabel assembly |
John,
Can't find it on your web page catalog. Where is it?
Andy
[quote] --
cathyboone(at)softcom.net Guest
Posted: Fri May 18, 2007 8:06 am Post subject: 912 ul throtlle choke cabel assembly |
Gerald,
Sorry I'm late on my email reply. John McBean has everything you need at the Kitfox factory. Go online for Sportplane LLC or Kitfox and you could also call 208 337-5111
Larry Boone, Denair, CA
Building Series 5 Outback
Rotax 912 uls, IVOPROP Med
