		wayne.e(at)grandecom.net Guest
				 Posted: Wed May 09, 2007 3:21 am    Post subject: Gas leak |
				I am currently getting close to having a DAR come  out and hopefully give me his blessings. A few days ago I filled the tanks with  fuel and yesterday I was under the wing taking off the inspection plates in  preparation for the DAR and, you guessed it, I found a small gas leak coming out  from one if the rivets. This is a quick build wing and apparently those guys in  the Philippines didn't do a good tanks test.
  Oh the trials and tribulations we go through to get  these things in the air. Oh well move on I guess.
  Wayne Edgerton #40336
  getting closer (I think)
		flysrv10(at)gmail.com Guest
				 Posted: Wed May 09, 2007 3:45 am    Post subject: Gas leak |
				You did not ask for a fix but I will tell you in case you did not know.  Use Loctite 290.  It works wonders.  I had the same issue with my QB wings.
 On May 9, 2007, at 7:21 AM, Wayne Edgerton wrote:
  	  | Quote: | 	 		  I am currently getting close to having a DAR come out and hopefully give me his blessings. A few days ago I filled the tanks with fuel and yesterday I was under the wing taking off the inspection plates in preparation for the DAR and, you guessed it, I found a small gas leak coming out from one if the rivets. This is a quick build wing and apparently those guys in the Philippines didn't do a good tanks test.
				 Posted: Wed May 09, 2007 4:43 am    Post subject: Gas leak |
				I'm preparing to test my QB tanks.  Any hints on what/where to look?
 Did other QB wing people test the tanks?
 I intend to use a fuel seal product on the sender unit instead of
 Pro-seal.  I understand that the fuel seal products are designed to seal
 while remaining pliable enough to be removed later.
 Rob Kermanj wrote:
  	  | Quote: | 	 		   You did not ask for a fix but I will tell you in case you did not
  my QB wings.
 > *         - The RV10-List Email Forum - class="Apple-converted-space"> --> http://www.matronics.com/Navigator?RV10-List              - NEW MATRONICS WEB FORUMS -  class="Apple-converted-space">   --> http://forums.matronics.com*
		AV8ORJWC
				 Posted: Wed May 09, 2007 9:52 am    Post subject: Gas leak |
				Wayne it is a great idea to retest your tanks before primer and topcoat.  It can be a heartbreaker to see the stains develop through the finish when proseal can be placed at the errant rivet to mitigate the QB workmanship.  Remember that the wing is going to do a lot of flexing and can break most sealing agents loose with just reasonable future flights.
 John Cox #600
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
  Sent: Wednesday, May 09, 2007 4:21 AM
  Subject: Gas leak
   [quote]   [b]
		john_rv10(at)yahoo.com Guest
				 Posted: Wed May 09, 2007 12:49 pm    Post subject: Gas leak |
				Wayne,
 Did you just apply the Loctite 290 to the outside of the offending rivet and let it seep into the joint, or did you do something else?
 John Cleary
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kermanj
  Sent: Wednesday, 9 May 2007 9:44 PM
  Subject: Re: Gas leak
    	  | Quote: | 	 		  |               - NEW MATRONICS WEB FORUMS -  class="Apple-converted-space">   --> http://forums.matronics.com[/b] http://www.matronics.com/Navigator?RV10-List  | 	  01234
				 Posted: Wed May 09, 2007 1:15 pm    Post subject: Gas leak |
				John, this is Rob.  i will send you the Loctite Data sheet to your email address so you can read it.  Basically, you put a drop on the rivet, come back the next day and find that the stuff is still liquid and wonder what the heck?
 The liquid seeps around the rivet and will solidify where there is no air.  If the rivet is leaking on the bottom and you have gas in the tank, I suggest that you empty it.  However read the directions.
 n May 9, 2007, at 4:47 PM, RV_10 wrote:
 Wayne,
 John Cleary
 From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Rob KermanjSent: Wednesday, 9 May 2007 9:44 PMTo: rv10-list(at)matronics.com (rv10-list(at)matronics.com)Subject: Re: Gas leak
 01234
 5 |
		carl.froehlich(at)cox.net Guest
				 Posted: Wed May 09, 2007 2:18 pm    Post subject: Gas leak |
				Recommend using proseal on the senders.  I have heard of others using fuel
 lube on the senders, but they started leaking with time.  Odds are the leak
 will start right after you get done painting!  If you need to pull a sender,
 it is not too hard running a putty knife under the proseal to get it out.
 For that matter, I flew my RV-8A the first 100 hours with just the
 fiberglass painted (a quick one coat garage job).  No fuel leaks until just
 before taking the plane down for final painting.  At that point I found one
 rivet on the rear baffle of the left tank weeping fuel.  Easy to fix before
 paint - a pain afterward.  I'll fly my RV-10 for at least 100 hours before
 final paint.
 Carl Froehlich
				 Posted: Thu May 10, 2007 4:11 am    Post subject: Gas leak |
				Van's assist center, Bruce, told me I should  remove the tank and then turn it over and put the Loctite 290 on the offending  rivet and then let it set. Is that what you previous leak experience people  did?
		Deems Davis
				 Posted: Thu May 10, 2007 6:13 am    Post subject: Gas leak |
				The posts/info that I recall reading on this topic also suggested that
 you put a 'weak' vacuum on the tank to try and draw the Locktite into
 the leak area. HOWEVER, that advice also came with a STRONG warning to
 be careful and NOT collapse the tanks by putting too great a vacuum to it.
 Deems Davis # 406
 Finishing - ( A Misnomer ! )
 http://deemsrv10.com/
  	  | Quote: | 	 		   Van's assist center, Bruce, told me I should remove the tank and then
				 Posted: Thu May 10, 2007 6:22 am    Post subject: Gas leak |
				Yes, but of course I was lucky and my leak was on top and I did not have to remove the tank.  My luck did not last long though.  Shortly after painting, I discovered other leaks that necessitate the removal, cutting and repairing the inside of the tank.
 do not archive.
 On May 10, 2007, at 8:10 AM, Wayne Edgerton wrote:
  	  | Quote: | 	 		  Van's assist center, Bruce, told me I should remove the tank and then turn it over and put the Loctite 290 on the offending rivet and then let it set. Is that what you previous leak experience people did?
		mritter509(at)msn.com Guest
				I drilled out the leaking rivet prior to painting and replaced it with a
 cherry max rivet dipped in pro seal.  95 hours later no problems.
 Mark
 N410MR
 Austin, TX
  	  | Quote: | 	 		  From: "Wayne Edgerton" <wayne.e(at)grandecom.net>
 Date: Thu, 10 May 2007 07:10:06 -0500
 Now you can see trouble…before he arrives
 http://newlivehotmail.com/?ocid=TXT_TAGHM_migration_HM_viral_protection_0507
		sam(at)fr8dog.net Guest
				 Posted: Thu May 10, 2007 7:05 am    Post subject: Gas leak |
				Was this a QB wing tank? If so,what did Van's have to say?
 Sam Marlow
 Rob Kermanj wrote:
  	  | Quote: | 	 		   Yes, but of course I was lucky and my leak was on top and I did not
  do not archive.
				 Posted: Thu May 10, 2007 7:59 am    Post subject: Gas leak |
				Yes it was QB tank.  They were sympathetic and supplied everything I
 needed for the repair.
 Do not archive.
 On May 10, 2007, at 11:02 AM, Sam Marlow wrote:
  Sam Marlow
 > do not archive.
 >> people did?
				 Posted: Thu May 10, 2007 12:08 pm    Post subject: Gas leak |
				What does Van's say about all of these.  It sounds like leaks on a QB wing
 is par for the course and well-sealed tanks are the exception.
 Jesse Saint
 Saint Aviation, Inc.
 jesse(at)saintaviation.com
 www.saintaviation.com
 Cell: 352-427-0285
 Fax: 815-377-3694
				 Posted: Thu May 10, 2007 12:29 pm    Post subject: Gas leak |
				I once was the ninty fifth caller on a radio station and qualified to be one
 of 65 people to draw keys out of a fish bowl, one would open the door to a
 924 Porche. I didn't get the right key.
 I have a pair of QB wings just waiting to be tested...any bets!!!!!!
 WHINEEEEEEER.
 [quote]From: "Jesse Saint" <jesse(at)saintaviation.com>
 Subject: RE: Gas leak
 Date: Thu, 10 May 2007 16:07:38 -0400
 Jesse Saint
 Cell: 352-427-0285
 Fax: 815-377-3694
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Wed May 23, 2007 7:40 pm    Post subject: Re: Gas leak |
				 	  | flysrv10(at)gmail.com wrote: | 	 		  | You did not ask for a fix but I will tell you in case you did not know.� Use Loctite 290.� It works wonders.� I had the same issue with my QB wings. |
 I am looking for a source of this product.  Can someone direct me to a supplier?
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
		Rhonda(at)bpaengines.com Guest
				 Posted: Thu May 24, 2007 5:12 am    Post subject: Gas leak |
				Try your local industrial bearing supplier.  Mine keeps it in stock.
 Rhonda
		apilot2(at)gmail.com Guest
				 Posted: Thu May 24, 2007 10:03 am    Post subject: Gas leak |
				Your friendly NAPA or Autozone, etc. auto parts store, in their
 (aircraft) sealant's area. Right along with their Form a gasket,
 Permatex #2 & #3, epoxies, etc.
 On 5/23/07, orchidman <gary(at)wingscc.com> wrote:
  Gary Blankenbiller
  RV10 - # 40674
  (N410GB reserved)
  http://forums.matronics.com/viewtopic.php?p=114486#114486
		orchidman
				 Posted: Sun May 27, 2007 4:44 pm    Post subject: Re: Gas leak |
				 	  | apilot2(at)gmail.com wrote: | 	 		  Your friendly NAPA or Autozone, etc. auto parts store, in their
 Permatex #2 & #3, epoxies, etc. |
 I found it in the aircraft supply section of Autozone.  Previously in this thread, it was referenced as 'Loctite 290' but all I found was 'Permatex' and their number was PX # 29000.  It is labeled 'Threadlocker Green' and 'Penetrating Formula' so I am sure it is the correct item.
 The good news is that today I tested both tanks and they got a green light, no bubbles detected.  This last week I had been baloon testing and they were going down at a VERY slow rate which I attribute to the fact that you blow up a baloon, tie it off and it will still go down over the course of a couple days.  So to go the extra mile, I soaped up the tanks and I am a happy camper
 Gary
				 Posted: Mon May 28, 2007 6:20 am    Post subject: Gas leak |
				It is a Locktite product perhaps I said 290 and meant 260.  I am
 traveling and do not have the exact information with me but i know it
 is a Loctite product.
 On 5/27/07, orchidman <gary(at)wingscc.com> wrote:
  The good news is that today I tested both tanks and they got a green light, no bubbles detected.  This last week I had been baloon testing and they were going down at a VERY slow rate which I attribute to the fact that you blow up a baloon, tie it off and it will still go down over the course of a couple days.  So to go the extra mile, I soaped up the tanks and I am a happy camper [Laughing]
  Gary
  http://forums.matronics.com/viewtopic.php?p=115110#115110
 Rob Kermanj
