		wreining(at)gmail.com Guest
				 Posted: Thu May 10, 2007 10:02 pm    Post subject: QB Wing Inspection and Questions |
				My son and I took a critical look at our QB wings this evening, following the instructions step by step to verify everything was built correctly.  Here are our discoveries, up through section 18 (fuel tanks).
 <![if !supportLists]>o        <![endif]>Main Spar - Page 13-3, step 9 calls for the enlargement of an existing 9/32 hole in the left (only) spar and installation of a snap bushing.  This was not done.
 <![if !supportLists]>o        <![endif]>Main Spar - Page 13-4, step 6 the tie down bracket is cut, tapped and drilled.  The tie down bracket in both wings was never tapped!
 <![if !supportLists]>o        <![endif]>Fuel Tanks - Page 18-8, step 5 the tanks all installed.  A note was included with our QB wings warning that “the fuel tanks are secured for shipping purposes ONLY by a few screws through the tank skin and several bolts through the Z-brackets.  It is expected that the builder will install the rest of these critical fasteners before the airplane is inspected or flown.”  Well, all of the screws and bolts were attached, but about half of the bolts for the Z-brackets were not fully tightened – glad we checked them with the torque wrench!
 We have a couple of questions:
 1.  What’s the purpose of the bushing through the spar specified on page 13-3?
 2.  Where are the instructions for testing the fuel tanks for leaks?
 Bill and Jon Reining
 40514 – QB wings
		Mike Whisky
				 Posted: Fri May 11, 2007 12:17 am    Post subject: Re: QB Wing Inspection and Questions |
				Hello Bill & John,
 the snap bushig is used to guide the wire of the stall warning from the leading edge through the spar. It is only requires for the left wing.
 MY QB Wings were in the exact same state, but all screws were tightend. Anyway I had to remove the left tank to install the stall warning in th eleading edge.
 The tigh downs are not tapped too, if you tap them make sure that the chips & oil will not drop into the inside of the wing since you can't get to them easlily.
 Best Regards
 Michael
  _________________ RV-10 builder (flying)
#511 |
				 Posted: Fri May 11, 2007 2:20 am    Post subject: QB Wing Inspection and Questions |
				My QB wings were also in the same exact state.  You'll need to buy the
 bushing (get a bunch of the them in differents sizes).
 It's not exactly clear where to start and with what... you have to jump
 around a little.  You'll need to add all the platenuts around the root
 of the  both top and bottom skins
 For QB tank testing, Vans has a little low cost kit with 2 tank fittings
 in it plus instructions that include the use of a ballloon as a pressure
 guage.  I haven't done it yet but net of it is that you want to
 pressurize the tanks *gently* and use soap suds to check for leaks.  The
 balloon insures less than 1psi is used.
 Michael Wellenzohn wrote:
  Hello Bill & John,
  Best Regards
  Michael
  RV-10 builder (wings)
  #511
  http://forums.matronics.com/viewtopic.php?p=112194#112194
		millstees(at)ameritech.ne Guest
				 Posted: Fri May 11, 2007 7:18 am    Post subject: QB Wing Inspection and Questions |
				Bill  & Jon:
  Pressure testing the tank is easy.  I just plumbed a valve  into one fitting, and a section of aluminium tubing into the other.  I  then applied compressed air through the valve to inflate a balloon that I taped  to the aluminium tubing, and closed the valve.  If the balloon is still  inflated the next morning, you have a good tank.
  Best of luck !
 Steve Mills N750SM  (reserved)
 RV-10 40486 Slow-build
 Naperville, Illinois
 Finishing kit
 Do Not  Archive
		DAVELEIKAM(at)wi.rr.com Guest
				 Posted: Fri May 11, 2007 7:52 pm    Post subject: QB Wing Inspection and Questions |
				How do you adjust the fuel sending floats in the QB  tanks?  You cannot access the inside of the tanks to adjust travel of the  floats.
  Dave Leikam
  40496
  QB wings
  [quote]   ---
				 Posted: Sat May 12, 2007 4:18 am    Post subject: QB Wing Inspection and Questions |
				There's some detailed writeups in the Matronics archives. Short version
 is that entire assembly can be inserted thru the hole in which it is
 mounted. There is some potential interference with some of the tank
 stiffener J channels which can make it a time consuming process. I went
 to the solution that involves turning the float 90deg into a vertical
 orientation. You lose about some fraction of an inch in travel but the
 adjustment becomes easy. You use a multimeter to check the travel.
 It's impossible to fully describe or understand until you have it in
 your hands.
 I recommend removing the tanks from the wing for inspection. It can also
 make the sender installation a bit easier but it's not required.
 Dave Leikam wrote:
 [quote] How do you adjust the fuel sending floats in the QB tanks? You cannot
  Dave Leikam
  40496
  QB wings
