Albert Gardner
Posted: Fri May 11, 2007 6:39 pm Post subject: Dynon FlightDEK D-180 / SL-30 Wiring |
I'm wiring my SL-30 radio to my Dynon FlightDEK-D180 and have hit a snag.
The Dynon FlightDEK-D180 Installation Guide, page 4-6 says "hook the SL30
unit to pin 22 on the FlightDEK's EFIS connector." This input on the Dynon
is labeled "FlightDEK-D180 Receive/PC Serial Transmit (RS-232)"
Problem is, I can't figure out which pin on the SL30 to hook to it. Also, if
this is a RS-232 line aren't they usually a 3 wire setup?
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
N777TY
Joined: 09 Apr 2006 Posts: 69 Location: Charlotte, NC
Posted: Fri May 11, 2007 8:18 pm Post subject: Re: Dynon FlightDEK D-180 / SL-30 Wiring |
It is the RS stuff.. should be pin 5 on SL-30... (double-check, though)... it's the "serial out" or "RS-232 out" or whatever they call it there..
the 3-wire thing you're thinking of is In, Out, and Ground.. if Dynon can't tune the radio, then In would not be connected..
_________________ RV-7A
N777TY |
