		rstone4(at)hot.rr.com Guest
				 Posted: Sun May 13, 2007 5:33 am    Post subject: Fuel system contamination |
				Members,
       I have not had my ZodiacXL  for very long and was unaware of the center fuel drain until a friend pointed it  out to me.  When I opened the valve nothing but black materiel came out  eventually turning green then finally blue.  I have no idea what this  materiel was but I suspect auto fuel.  I did not build this aircraft but  got it from a man in Ringwood, Oklahoma and I suspect he used auto fuel to fly  the 40 hours off.  Have any of you Zodiac601XL builders had an experence  like this and what action did you take.
  Tracy  Stone                       DO NOT ARCHIVE
  Zodiac601XL
  Harker Heights, Tx
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
				 Posted: Sun May 13, 2007 6:15 am    Post subject: Fuel system contamination |
				It nearly sounds like the guy tried to use the same can for his plane
 and a 2-cycle lawn mower.  Aside from that, perhaps he put
 an additive in thinking it would mix and stabilize his fuel over
 winter.  If he used a bad float, it may have gone south too.  I'd at the
 least
 get a flashlight and a mirror in the tank after emptying it and have a
 good look inside.
 Larry McFarland at www.macsmachine.com
 robert stone wrote:
  	  | Quote: | 	 		   Members,
  Zodiac601XL
  Harker Heights, Tx
				 Posted: Sun May 13, 2007 7:46 am    Post subject: Fuel system contamination |
				Hi Tracy,
  Many kit built XLs use black rubber hose for fuel line.  I have heard many reports that this tends to turn the fuel funny colors until the hose is completely cleaned out.
  This is relatively common.  I wouldn't scrap the plane yet for this reason.
  Happy landings,
  Paul
  XL fuselage
  At 06:26 AM 5/13/2007, you wrote:
  [quote]Members,
  Zodiac601XL
  Harker Heights, Tx
		ronlee
				 Posted: Sun May 13, 2007 8:23 am    Post subject: Re: Fuel system contamination |
				I built a 701 and had the same problem with fuel color and tiny bits of material coming through. I washed the tanks very well with soap and water, and rinsed several times before installing them. I blew the fuel lines out with high pressure air before installation. After installation I ran at least five gallons of gas through each tank several times all the way to the carbs. untill the debris was (nearly) gone, I was sure everything was as clean as one could get the fuel components yet the fuel continued to come through colored and very small various colored particles after sitting a while. I am convinced it was all coming from  the black rubber fuel lines. After seventy five hours, all seems clear. All the fuel I add is filtered while being poured into the tanks. Nothing ever comes out of my fuel draines (four) any more.
  _________________ Ron Lee
Tucson, Arizona |
				 Posted: Sun May 13, 2007 1:55 pm    Post subject: Fuel system contamination |
				Paul,
       No kit producer would  include rubber hoses in his fuel system because and petroleum products of any  kind will melt rubber. They use a hose in the flex line areas called  neoprene.
  Tracy Stone
  [quote]   ---
		ashontz
				 Posted: Tue May 15, 2007 9:18 am    Post subject: Re: Fuel system contamination |
				I agree, it sounds like 2-cycle oil, actually, it almost sounds like regualr motor oil used as 2-cycle oil, (you can do that but it smokes like hell). My boat has had the same black fuel lines for 11 years (yes, I shoud replace them), even so, I've never seen anything like that in my fuel/water seperator even after mixing stabilizer in the tanks and letting it sit over the winter.
  	  | larry(at)macsmachine.com wrote: | 	 		  It nearly sounds like the guy tried to use the same can for his plane
 least
 good look inside.
 robert stone wrote:
  	  | Quote: | 	 		   Members,
  Zodiac601XL
  Harker Heights, Tx
