gmitchell(at)coastcomposi Guest
Posted: Mon May 14, 2007 4:24 pm Post subject: ACS Gascolator rubber seal. |
A word of warning about the AC Spruce homebuilder gascolator. I just returned from the Hangar to find a huge stain under the cowling and tailwheel. I had dismanteled and checked the filter screens in the gascolator the week before, re assembled them CHECKED for leaks did not see any and went home. My hangar buddy called me a couple days later to tell me about a stain on the floor. Turns out I spilled 28 galls of fuel through the rubber seal in the gascolator. It was a hot day here in So Cal when I checked the screens and re assembled them, I have a feeling that's why it did not leak there was just enough expansion in the rubber and aluminum to make the seal. When it all cooled down and shrank it started to leak. when I checked the rubber seal it has tiny crackes around the periphery also. So this needs replacing 1 per year it seems.
Just a word to the wise.
Graham Mitchell
Graham Mitchell
Program Manager
Coast Composites Inc
Tel 949 455 0665 ext 128
Email gmitchell(at)coastcomposites.com
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
This message and any attachments may contain confidential or privileged
information. The information is intended only for the use of the individual
or entity named above. If you are not the intended recipient, you are
hereby notified that any disclosure, copying, distribution of, or the taking
of any action in reliance on, the contents of this information is strictly
prohibited. If you have received this message in error, please immediately
notify the sender by reply email or call the IT Department at 949.455.0665 x125
and delete all copies of this message and any attachments. Thank you.
| | - The Matronics Tailwind-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Tailwind-List |
dmagaw(at)att.net Guest
Posted: Tue May 15, 2007 5:39 am Post subject: ACS Gascolator rubber seal. |
At today's fuel prices that's probably well over $100 spilled on the floor. Good thing you found the leak before flight, however.
Dave M
| Quote: | -------------- Original message from "Graham Mitchell" <gmitchell(at)coastcomposites.com>: --------------
Graham Mitchell
Graham Mitchell
Program Manager
prohibited. If you have r eceive d this message in error, please immediately
| [quote][b]
Malcolm.Lovelace(at)coope Guest
Posted: Tue May 15, 2007 5:57 am Post subject: ACS Gascolator rubber seal. |
I use a cork gasket in mine. I had the same problem.
Malcolm
[quote] --
downing.j(at)sbcglobal.ne Guest
Posted: Tue May 15, 2007 12:49 pm Post subject: ACS Gascolator rubber seal. |
Those cork gaskets are available at Tractor or Farm Supply Stores. Farmer
John
Posted: Tue May 15, 2007 1:27 pm Post subject: ACS Gascolator rubber seal. |
Thanks for the info I will get cork. This could qiet easily have happened in the air as the temp cooled at altitude.
Graham Mitchell
redswing(at)mcn.org Guest
Posted: Tue May 15, 2007 7:22 pm Post subject: ACS Gascolator rubber seal. |
They are also the same as for flathead Ford fuel pump sediment bowls, and are usually rubberized cork and last longer than plain cork and don't squirm as much as the rubber.
Red
eschlanser(at)yahoo.com Guest
Posted: Wed May 16, 2007 6:24 pm Post subject: ACS Gascolator rubber seal. |
I had a similar experience over 20 years ago when fuel was cheaper. I had gotten out of the habit of turning the fuel supply off before heading home from the hangar. Thanks for reminding me. Eric
Red Hamilton <redswing(at)mcn.org> wrote:[quote] They are also the same as for flathead Ford fuel pump sediment bowls, and are usually rubberized cork and last longer than plain cork and don't squirm as much as the rubber.
Red
Posted: Wed May 16, 2007 6:28 pm Post subject: ACS Gascolator rubber seal. |
What is a source for the rubberized cork ones? Thanks, Eric
Red
Posted: Wed May 16, 2007 7:04 pm Post subject: ACS Gascolator rubber seal. |
Red's Headers, the business that I used to own, has them.
I'll get a part number tomorrow and post it here.
Red
Posted: Thu May 17, 2007 7:13 pm Post subject: ACS Gascolator rubber seal. |
The mfg part number is 2081, I believe. Note that this will appear as the ALU in their program, not the item number
If you call Red's Headers at 760 343 2590, Jim Davis is the new owner.
or you can order online at reds-headers.net
Red
Posted: Fri May 18, 2007 7:27 pm Post subject: ACS Gascolator rubber seal. |
I hope that no one acted on the prior message, because the info is obsloete.
I am getting some of the superceeding p/n gaskets here to test for 100LL compatibility, stay tuned.
Red
Posted: Tue May 22, 2007 7:53 pm Post subject: ACS Gascolator rubber seal. |
OK, I've got six of them here. I will put one in 100LL tomorrow and see what it does. They appear to be the same as the one that I used on our Bellanca.
Red
Posted: Mon May 28, 2007 8:57 pm Post subject: ACS Gascolator rubber seal. |
Eric,
One has been in 100LL for 5 days now, neither the gasket nor the gasoline appear to be changed in any way, so far.
Want me to send you one to try?
On another note, 31 May is the last day to register for the 2007 Airventure Cup race.
Red
Posted: Wed May 30, 2007 5:33 pm Post subject: ACS Gascolator rubber seal. |
Red,
No rush. I will pick it up at Boo or Oshkosh if that's OK? I won't have gas in my gascolator for a couple of years yet. Eric
Red Hamilton <redswing(at)mcn.org> wrote:[quote] Eric,
Red
