dan(at)azshowersolutions. Guest
Posted: Wed May 16, 2007 5:04 am Post subject: spray painting |
I'm getting ready to primer my elevator trim tab and was curious if anyone had found a way to paint over a piano hinge without gooping it up? Any tricks in anyone's bag?
Dan B
Mesa, AZ / Kitfox-IV
www.azshowersolutions.com/Kitfox1.html
kitfoxmike
Posted: Wed May 16, 2007 5:51 am Post subject: Re: spray painting |
vaseline
Posted: Wed May 16, 2007 3:22 pm Post subject: spray painting |
Float Flyr
Posted: Wed May 16, 2007 3:57 pm Post subject: spray painting |
Just a guess but I'd consider taking the hinge apart (remove the pin), lubricate or soap the inside of the hinge and then paint it separately. When the paint is dry it should be easy to remove from the lubricated surfaces yet should hold to the untreated surfaces. Then re-assemble the hinge. I have seen helicopters used in wildlife counting, where they actually paint caribou, pre sprayed with WD40 before each flight so the overspray is easy to wipe off. Given enough warm water the WD40 disappears too.
[img]cid:291065023(at)16052007-3240[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
272 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Guy Buchanan
Posted: Sat May 19, 2007 9:21 am Post subject: spray painting |
At 06:03 AM 5/16/2007, you wrote:
| Quote: | I'm getting ready to primer my elevator trim tab and was curious if
I did absolutely nothing preventative and it worked fine. I painted
both halves separately, took moderate care to not spray inside, and
it re-assembled and worked great.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Posted: Sat May 19, 2007 3:13 pm Post subject: spray painting |
