		ashontz
				 Posted: Thu May 17, 2007 5:40 am    Post subject: 601XL Fuselage build before wings |
				Considering all the talk about wing testing of the 601XL by Zenith, I'm considering putting them aside for now and working on the fuselage. I'm confident that Zenith will rectify any problems if found. That being the case, what problems will I encounter if I build the fuselage first? One problem I see is the center spar. I have one side drilled for the wing root and one side not drilled. If I start building the fuselage around it will I be able to pull it out with out a problem to set the dihedral on the table? Can I build most of the fuselage without the center spar and install the spar at a later time? I just want to keep moving forward and figured now may be a good time to start on the fuselage til we get official word on the wing tests and if there's any corrective actions that need to be taken.
  |  | - The Matronics Zenith-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		p.mulwitz(at)worldnet.att Guest
				 Posted: Thu May 17, 2007 6:22 am    Post subject: 601XL Fuselage build before wings |
				The standard build order starts with the rudder and tail parts, then
 goes to wings, and finally fuselage.
 I think one important reason for this is education of the
 builder.  It is much less expensive in both time and money to make
 mistakes on the simpler and smaller parts.  The fuselage is A LOT
 more complicated and difficult to build than the rest of the
 plane.  You are less likely to make a huge mistake on the fuselage
 after building the rest of the parts.
 I consider this issue a lot more important to an individual builder's
 issues than the possibility that there may be a major design change
 at some undetermined time in the future.  It may be that there is no
 design change at all, or a big change might be some place other than
 the wings.
 I am not saying I am not concerned about the structural failures.  I
 only think that the likelihood of a big fix in the near future is
 very small.  Also, my concern is large, but the real danger of a
 structural failure in any single  601XL with the current design is
 still very small.  It may turn out (much to my frustration) that the
 failures are simply results from overstressing the planes or improper
 cable tensions and if you keep within design limits you will be just fine.
 Paul
 XL fuselage
 At 06:40 AM 5/17/2007, you wrote:
 Andy Shontz
 CH601XL - Corvair
 www.mykitlog.com/ashontz
 http://forums.matronics.com/viewtopic.php?p=113305#113305
		ashontz
				 Posted: Thu May 17, 2007 6:34 am    Post subject: Re: 601XL Fuselage build before wings |
				I thought about that too, the fact that a design change (if it occurs) would also be to the fuselage itself, unlikely though.
 I'm very comfortable with my bulding skills at this point so switching to the fuselage doesn't bother me. I think you learn a lot more building from plans.
 I'm just wondering if I'd be painting myself into a corner if I have to pull out the center spar temporarily to set the dyhedral and I can't. I see that as the biggest show stopper to building the fuselage at this point.
 Believe me, I've actually entertained the idea of just stopping work all together on the XL and ordering plans for an HD. Wouldn't take me anywhere near as long to rebuild. I wouldn't be surprised if the HD uses the same stabilizer, elevator, and rudder (not saying it does, I don't know) so all I'd really be shit out of would be the time and a couple hundred dollars building the right wing. If it came to that, I bet the wing could be donated to a techinical school somewhere for a write-off that would net me whatever I spent building it.
  	  | p.mulwitz(at)worldnet.att wrote: | 	 		  The standard build order starts with the rudder and tail parts, then
 the wings.
 Paul
 XL fuselage
 Andy Shontz
 CH601XL - Corvair
		gboothe5(at)comcast.net Guest
				 Posted: Thu May 17, 2007 7:05 am    Post subject: 601XL Fuselage build before wings |
				Andy,
 Tail feathers are the same. XL plans have all the latest do-dads for the
 fairings and trim, but otherwise are interchangeable.
 BTW - ever looked across the dogfight circle and seen the oilcanning on the
 wings of a Cessna 170A? HOLY COW!!!
 Gary Boothe
 Cool, CA
 601 HDSTD, WW Conversion 90% done,
 Tail done, wings done, working on c-section
		ashontz
				 Posted: Thu May 17, 2007 7:16 am    Post subject: Re: 601XL Fuselage build before wings |
				Thanks, I figured they would be interchangable. So worst case, if I switch to an HD, I'm out like maybe $450 for what I spent to get the right wing to the stage I'm at, which is pretty far.
 I'm sure any wing will oil-can under enough stress, that's how they break, buckling of the skin and spar (ie. extreme oil-canning). The thing is none should be observed under zero load.
  	  | gboothe5(at)comcast.net wrote: | 	 		  Andy,
 Gary Boothe
 Cool, CA
		zodierocket(at)hsfx.ca Guest
				 Posted: Thu May 17, 2007 8:10 am    Post subject: 601XL Fuselage build before wings |
				ANDY, your driving me crazy, you remind me of a movie in which the
 fellow gets all self induced hysterical and needs a DAM GOOD SLAP!!
 Let the investigation continue, Andy build your wings, you won't see any
 changes, in my opinion. Chris will test yet another XL to ease your mind
 and the FAA will still undoubtedly leave a fog for concrete answers. The
 FAA has not made any recommendations to the designer that I am aware of,
 and with some knowledge, they will not make any recommendations in the
 closure of the other incidents, so I believe.
 It has been unfortunate that several accidents have happened in a short
 period, some of which were extremely stupid.
 Having a plane fold it's wings and the rear spar fully intact on the
 fuselage is the same as the one that entered into the side of the
 wielding shop or exploded in mid air. Neither should be considered a
 design flaw and unfortunately should be pointed at owner/builder error.
 Be careful out their guys. Build your planes as the plans state, don't
 make structural modifications without the designers approval.
 Fly in conditions you can handle and know the abilities of your plane
 and stay within them. In Canada the 601 series is not rated for
 aerobatics and therefore cannot do any of them. Can the plane do some,
 likely, I have heard of many people trying, many doing and possibly the
 rest leaving a legacy for a couple on this list to cry about structural
 integrity.
 Build your plane and don't make ANDY changes ,fly your plane within it's
 limits and you will have a bird that is fun and safe.
 For the rest if you want to wait 8 mos to start building by all means
 make sure your comfortable, myself I'm getting ready to soon let my only
 daughter at the age of 14, use the 601XL to learn how to fly on. Don't
 take this statement lightly there is NOTHING more important to me in
 this life then my children.
 Now lets get back to building and giving Andy a cuff upside the coconut,
 (not really but I feel better picturing it).
 Mark Townsend  Alma, Ontario
 Zodiac 601XL C-GOXL, CH701 just started
 www.ch601.org / www.ch701.com / www.Osprey2.com
		ashontz
				 Posted: Thu May 17, 2007 8:40 am    Post subject: Re: 601XL Fuselage build before wings |
				I'll let other comment here. I've heard that for every one person that actually speaks up that there's a hundred people thinking the same thng. So you get a hundred and I get a hundred.
  	  | zodierocket(at)hsfx.ca wrote: | 	 		  ANDY, your driving me crazy, you remind me of a movie in which the
 integrity.
		admin(at)arachnidrobotics Guest
				 Posted: Thu May 17, 2007 8:52 am    Post subject: 601XL Fuselage build before wings |
				AMEN!  This list USED to be entertaining and helpful.  I hesitate to even open it in the last week...
 ZodieRocket <zodierocket(at)hsfx.ca> wrote:[quote] --> Zenith-List message posted by: "ZodieRocket"
 integrity.
		ashontz
		ashontz
				 Posted: Thu May 17, 2007 9:27 am    Post subject: Re: 601XL Fuselage build before wings |
				Mark, I'm not trying to piss you off. I like you, you're a good guy and have personally taken the time to give me help with stuff and I appreciate that. I'm just wondering (as are others) what if anything is going on. I'd like to continue working on my plane and look forward to flying it at some point. I just want to know it truly is safe and doesn't have any anomolies. It makes sense to me at this point to move onto another area of the plane for the time being. There may never be anything conclusive or any changes other than the introduction of the CH601XLHD or something like. You never know. Figure I'll let it slide for awhile and see what happens. Doesn't mean I need to sit dead in the water.
 integrity.
				 Posted: Thu May 17, 2007 9:56 am    Post subject: 601XL Fuselage build before wings |
				Andy,
 There you go, again...
 Wing flutter? ONE lister reported wing flutter in a very peculiar
 circumstance! That hardly means that wing flutter is a problem, but the more
 you bring it up, all of a sudden wings are fluttering off of 601's
 everywhere.
 To my knowledge, no one ever agreed what caused the wing flutter of the guy
 who reported it while flying over a heat plume. It was certainly not agreed
 that it was a structural problem with the wing.
 You don't work for the RV guys, do you?
 Gary Boothe
 Cool, CA
 Me too til I starting taking notice of the thread about wing flutter.
 There's still plenty of other fun and interesting thread on here.
 Andy Shontz
 CH601XL - Corvair
 http://forums.matronics.com/viewtopic.php?p=113386#113386
		Gig Giacona
				 Posted: Thu May 17, 2007 10:12 am    Post subject: Re: 601XL Fuselage build before wings |
				I'm with Mark so add another 100.
  	  | ashontz wrote: | 	 		  I'll let other comment here. I've heard that for every one person that actually speaks up that there's a hundred people thinking the same thng. So you get a hundred and I get a hundred.
601XL Under Construction
		Jeyoung65(at)aol.com Guest
				 Posted: Thu May 17, 2007 10:13 am    Post subject: 601XL Fuselage build before wings |
				Gray, what is a 601HDSTD?
  DO NOT ARCHIVE"
 See what's free at AOL.com.
				 Posted: Thu May 17, 2007 10:22 am    Post subject: 601XL Fuselage build before wings |
				601 HDS TailDragger. It’s my own acronym. Pretty clever, eh?
 So now, when you do your searches for wing failures on 601’s, you may have to include 601HDSTD.
 Gary Boothe
  Cool, CA
 DO NOT ARCHIVE
 From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jeyoung65(at)aol.com
  Sent: Thursday, May 17, 2007 11:12 AM
  Subject: Re: Re: 601XL Fuselage build before wings
 DO NOT ARCHIVE"
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith-List  | 	  01234
		John Bolding
				 Posted: Thu May 17, 2007 10:40 am    Post subject: 601XL Fuselage build before wings |
				[quote]    Andy,
    Me too, add another 100,  I'll throw in some    bird house plans so you can be 100% safe as you have stated is your    desire. You are NOT gonna climb THAT hill building airplanes that    have "Experimental" on the side in big letters.        John
 --> Zenith-List message posted by: "Gig Giacona" <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
 ashontz wrote:
  	  | Quote: | 	 		   I'll let other    comment here. I've heard that for every one person that actually speaks up    that there's a hundred people thinking the same thng. So you get a hundred and    I get a hundred.
 W.R. "Gig"    Giacona
		dredmoody(at)cox.net Guest
				Et moi aussi,
 Dred
 ---- Gig Giacona <wr.giacona(at)suddenlink.net> wrote:
  W.R. "Gig" Giacona
  http://forums.matronics.com/viewtopic.php?p=113400#113400
		ashontz
				 Posted: Thu May 17, 2007 10:55 am    Post subject: Re: 601XL Fuselage build before wings |
				Interesting responses considering I'm not even the one who mentioned wing flutter or originally posted the accident reports.
 As far as working for RV, why would I work for RV AND build a 601XL with a webpage with posted progress?
 Just looking for answers.
 As far as the Experimental posting on the side, yup, mine will obviously have that as well as everyone else's. That being the case, that's exactly what it means, experimental, yet everyone comes down on me for doing just that, experimenting with the idea that perhaps the wings aren't as resistant to twist as they should or could be. When it comes to that, then I'm told to not toy with the idea (ie. don't experiment). So which is it, not experimental yet with Experimental on the side or truly experimental? If it's not experimental, then I'd like to see some more posted data that says that it's totally structurally sound in all respects up to +6 Gs.
		hillsgun(at)nwinfo.net Guest
				 Posted: Thu May 17, 2007 11:21 am    Post subject: 601XL Fuselage build before wings |
				Thank You. My sentiments exactly. Dan.
  [quote]   ---
		Gig Giacona
				 Posted: Thu May 17, 2007 11:47 am    Post subject: Re: 601XL Fuselage build before wings |
				Andy,
 I've pretty much stayed out of this. It is your airplane and as long as you can get it by the AW inspector you can do what ever the hell you want to it.
 What I have a problem with is you suggesting completely untested and un-engineered fixes to a problem that probably doesn't exist.
		bill_dom(at)yahoo.com Guest
				 Posted: Thu May 17, 2007 11:48 am    Post subject: 601XL Fuselage build before wings |
				Gary,
   This is where all the comments about wing flutter might comes from:
   "As the airplane flew to the southwest, he saw the wings  visibly vibrate, and observed what he thought were pieces of metal  separate from the airplane."
   This comes from the NTSB report about the accident in Oakdale  California. Apparently, the guy who was flying over the plant is not  the only one who have experienced wing flutter.
   William Dominguez
   Zodiac 601XL Plans
   Miami, Florida
 Gary Boothe <gboothe5(at)comcast.net> wrote:[quote]  --> Zenith-List  message posted by: "Gary Boothe"
 Andy,
 everywhere.
 Gary Boothe
 Cool, CA
 Andy Shontz
 CH601XL - [quote][b]
