Mark IIIC won't turn right in straight and level
John Bickham
PostPosted: Thu May 17, 2007 4:12 pm    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Need help with this one.
A local friend of mine purchased a Kolb Mark IIIC. I think the previous owner was the former partners of the TNK. I'm terrible with names but I remember he was a big old boy. I think I remember him flying this plane at the first TNK homecoming I went to.
Anyway, this Mark IIIC will not turn right in straight and level cruise. The stick moves easily to the left but takes two hands to move it a even a little bit to the right. If you put the plane in a climb or a descent, it unloads the problem and allows the stick to move to the right.
I've looked it over and see no obvious problem. I noticed that the center line of the elevator hinge on the left side is not exactly centered with the pivot bolt. Off about a 1/8" I suggested getting that aligned and tightening the cables a bit.
If anyone has faced this problem or has suggestions, it would be greatly appreciated.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
St. Francisville, LA
I know many pilots and a few true aviators. There is a distinct difference that I have the greatest respect for.
mdnanwelch7(at)hotmail.co
PostPosted: Sun May 20, 2007 5:14 am    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
John,
There didn't seem to be too many responses to your dilemma, so I thought
I would make a suggestion. Verify the following:
Take a look at the pivot hinges for the ailerons. Are
they bOTH oriented in the same direction? Meaning....the pivoting action
of the hinge, are they both UP, or both down??
Just an idea, Mike in SW Utah (who didn't
make it to MV, I'm sorry to say!!
Reply-To: kolb-list(at)matronics.com
Subject: Mark IIIC won't turn right in straight and level
Date: Thu, 17 May 2007 17:12:53 -0700
appreciated.
Thanks too much,
John Bickham
Mark III-C
&quot;Using my Repairman Certificate&quot;
http://forums.matronics.com/viewtopic.php?p=113488#113488
Like the way Microsoft Office Outlook works? You’ll love Windows Live
Hotmail.
Richard Pike
PostPosted: Sun May 20, 2007 10:42 am    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Not a clue.
So here's some questions to get things started.
Does it fly pretty much straight and level without effort, does it only take
minimal pressure to keep it flying straight?
If so, what sort of rigging does it have to make it fly straight? What are
it's current rigging adjustments?
Does it have a tendency to turn left anyway?
What is the prop rotation?
Does if turn equally well either way power off?
Does it turn equally well either way in a full power climb?
Does it always break off to one side in a stall?
Are the flaps rigged the same, or is there differential in their droop or
angle?
Not sure what I am looking for, just fishing.
Richard Pike
MKIII N420P (420ldPoops)
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
JetPilot
PostPosted: Sun May 20, 2007 11:52 am    Post subject: Re: Mark IIIC won't turn right in straight and level Reply with quote
What you describe sounds strange, but if description of the proplem is very accurate, this sounds like a control system jamming problem to me. Espeically given that the stick frees up when you climb or descend, it sounds like it may be taking some load off the control system allowing it to move. I would check to make sure that the bushings that the aileron control tube go through are well greased and free. On the ground, have two people put a little up force on BOTH ailerons at the same time, then see if the stick moves left and right freely. Then have them put some down force and see if you feel any binding in the stick. Then check every part of the aileron control system that could possibly jam under load.
The elevator problem you describe should not cause a roll jam as you describe, it is most likely un related.
Attached is a picture of the area I am talking about, this loads up with a lot of downforce in flight, and needs to be well greased through the holes in the bushing. Good luck and let us know what you find.
 Filesize:  211.81 KB
 Viewed:  669 Time(s)
Kolb MK-III Xtra, 912-S
jindoguy(at)gmail.com
PostPosted: Sun May 20, 2007 12:47 pm    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Since the description of the solution, climbing or descending, didn't mention actually unloading the system, i.e. pulling negative or positive G's, but rather movement of the stick, I'm guessing the problem lies in the mixer mechanism at the bottom of the stick. I agree with Mike, it sounds like a mechanical jamming. If you have access to a stethescope you might try listening to all the areas mentioned to check for any slight clicking or grinding sounds as you move the stick.
Rick
On 5/20/07, JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:[quote] --> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=113867#113867
http://forums.matronics.com//files/ultralightmikekolbdetail1_671.jpg
Dennis.Kirby(at)kirtland.
PostPosted: Mon May 21, 2007 11:13 am    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
<< Anyway, this Mark IIIC will not turn right in straight and level
cruise. From: "John Bickham" >>
John B -
I just ordered an "Adjustable Wing Attachment U-Joint" from TNK for a
similar (but not as bad!) problem. My Mark-III always wants bank to the
left, so I must hold constant right stick to counteract. I attached a
bungee to the stick, pulling it right (a-la John H), and that took care
of the problem.
Saw one of these on John Williamson's Kolbra at Monument Valley this
past weekend. It allows you to adjust the height of the rear wing
attachment point. By adjusting the trailing edge of one wing up or
down, you can bring the bottom planes of your wings back into alignment.
Only need one, pick your wing. This may solve your problem.
Looking straight-on at my airplane one day recently, standing just in
front of the nosecone, I made visual comparisons of the flatness
(planes) of the bottoms of both wings. I could see then that my right
wing had a slightly greater angle of attack than the left wing. This
explains the left turning tendency. I'll report my results after I
install the adjustable U-joint.
Dennis Kirby
Cedar Crest, NM
rlaird
PostPosted: Mon May 21, 2007 3:59 pm    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Dennis -
I too had this problem, and the adjustable U was definitely the cure!
-- Robert
On 5/21/07, Kirby Dennis Contr MDA/AL <Dennis.Kirby(at)kirtland.af.mil> wrote:
John B -
of the problem.
Dennis Kirby
Cedar Crest, NM
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com
JetPilot
PostPosted: Mon May 21, 2007 4:54 pm    Post subject: Re: Mark IIIC won't turn right in straight and level Reply with quote
John B,
It is vitally important that you give a completely accurate description of what is going on ( Not second or third hand information ). Getting one detail wrong, or forgetting to tell something could indicate a completely different problem.
The U Joint would fix a trim problem, that is a constant turn to the left, and having to hold a lot of right stick to just hold it straight and level. If you are out of trim that bad, it would be downright scarey to fly, as you would be constantly fighting just to keep your plane level, with the plane turning to the left all by itself and very hard turning to the right... An out of trim problem gets worse with speed, and harder to counteract, so from your description I dont think this is the problem.
If the plane flys more or less level on its own, and is just hard to turn to the right when you want to, indicates a jam, not an out of trim problem. The out of trim probelm would definately be more common, but your description definately indicated a jam rather than trim problem. Recheck your facts, and note exactly what the symptoms to accurately diagnose this problem.
Mike Bigelow
Richard Pike
PostPosted: Tue May 22, 2007 12:06 pm    Post subject: Re: Mark IIIC won't turn right in straight and level Reply with quote
Is it possible that the turn effort changes with speed? Since you mentioned that it is easier in a climb or descent, is it also a function of airspeed? Is it easier when flying slow, and harder when flying fast?
Richard Pike
John Bickham
PostPosted: Wed May 23, 2007 3:41 am    Post subject: Re: Mark IIIC won't turn right in straight and level Reply with quote
Sorry for the delayed response. I work shift work so I go a few days without reading e-mail.
Appreciate the responses and suggestions.
Sorry left out a few key facts. This plane does have the dual stick option. Several have suggested a jam on this system.
Plane has a 912S with prop rotation CCW looking forward
On the ground all controls move freely. Problem only shows up in straight and level cruise.
This problem is much worse than the Kolb constant roll to the left that requires backpressure to the right. You literally can not move the stick to the right when S & L. And yes, I was scared. Scared that something was going to give before the stick moved.
Gonna go through all the suggestions one by one and let you know what we find.
By the by, my plane flies great. Can fly hands off now for extended periods.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
Richard Pike
PostPosted: Wed May 23, 2007 6:54 am    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Any way you can load pressure on the fuselage/motor mounts to simulate
engine thrust and torque and then see what the controls do?
Richard Pike
MKIIi N420P (420ldPoops)
Richard Pike
Kingsport, TN 3TN0
John Bickham
PostPosted: Fri Jun 29, 2007 2:06 pm    Post subject: Re: Mark IIIC won't turn right in straight and level=Update Reply with quote
Just heard from my buddy this afternoon while I was cutting the grass on the runway.
He flew his plane recently and the problem has been fixed. I had been suggesting that he tighten up his tail cables and he did it a couple of times, just never tight enough. Finally, got them tight enough and problem solved.
Thanks for the suggestions.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
PostPosted: Fri Jun 29, 2007 2:23 pm    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
Hey John,
Just a few days ago I asked for an update regarding this problem your
friend was having. Thanks for the update. I was truly curious to know if
he got it figured out. Evidently, he has, but I don't quite understand his
solution, tho. You're saying, he tightened the cables to the rudder and
elevator and THAT fixed his problem?? I thought it was incredibly
difficult to turn right due to some stick control/aileron situation. Could
you explain more precisely what the problem and solution was? I really am
interested...so I don't encounter any ailments like these myself.
Appreciate it, Mike in SW Utah
Subject: Re: Mark IIIC won't turn right in straight and level
Date: Fri, 29 Jun 2007 15:06:02 -0700
the runway.
solved.
Thanks too much,
John Bickham
Mark III-C
http://forums.matronics.com/viewtopic.php?p=121266#121266
Get a preview of Live Earth, the hottest event this summer - only on MSN
http://liveearth.msn.com?source=msntaglineliveearthhm
PostPosted: Fri Jun 29, 2007 2:38 pm    Post subject: Mark IIIC won't turn right in straight and level Reply with quote
| elevator and THAT fixed his problem?? |
Mike:
He tightened up the tail wires. Most folks fly around with them loose
as a clothes line. They need to be tight enough to twang like a
guitar string. There is a lot of activity going on back there, and
loose tail wires agrevate problems.
Here is what John B said:
"I had been
of
problem
solved."
Here is how I check to see if my tail wires are tight enough for me.
1-Grab the leading edge of either horizontal stabilizer with one hand,
and the leading edge of the upper vertical stabilizer with the other.
2-Now..........try to pull the two leading edges together. In the
process of pulling them together, if the wire at the station you are
pulling goes slack, to me, that indicates it needs to be tightened up
to the point that it will not sag when a pretty good pull is put on
the system.
mkIII with tight tail wires.
John Bickham
PostPosted: Fri Jun 29, 2007 2:55 pm    Post subject: Re: Mark IIIC won't turn right in straight and level Reply with quote
Hey Mike in Utah,
Yep, it is fixed. I know it sounds strange that tightening up the cables that brace the tail feathers fixed a roll problem. Kolbers that fold their tale on any frequency may have witnessed this to some degree.
Basic deal is the controls (pitch and roll) are intergrated into the stick. The way the elevator hinge and arm system work at the tail necessitates that both horizontal stabilizers be lined up pretty close to the center of the pivot point and perpindicular. Having the folding option and the design that necessitates it is what contributes to the problem. If one or both of the horizontal stabilizers/elevetors are allowed to move up or down it can put the sitck in a bind.
I know it don't sound right. But you can test it yourself the next time you cables are loose for inspection or maintenance. Move one or both of the horizontal stabilizers up or down a bit. Brace it or have someone hold them. Then try to move the stick fore/aft, left/right. You will notice the stick won't move much off center. At least that was my experience when I was folding because I was jamming a C-172 into a hanger with my Kolb.
The C-172 was for my daughter to build hours in for an Aviation Degree. Changed to Air Traffic Controller in the Air Force. Stationed at Hill AFB just north of SLC, Utah. Was real glad to sell that big tank C-172. May look you up on one of the visits.
Hope this is helpful.
Thanks too much,
John Bickham
Mark III-C w/ 912UL
