Malcolmbru(at)aol.com Guest
Posted: Wed May 16, 2007 3:08 am Post subject: gas cap not venting? |
wear can I find another gas cap? mine are made by Eaton with a stainless steel tub welded to it. mal
See what's free at AOL.com.
dcsfoto
Posted: Wed May 16, 2007 3:33 pm Post subject: Re: gas cap not venting? |
kitfox LLC has them
Float Flyr
Posted: Wed May 16, 2007 3:44 pm Post subject: gas cap not venting? |
Mal are you sure the tube is stainless? it may be chrome plated copper tube soldered not welded into the cap. I bought a regular cap last year removed all the plastic stuff and the sealing gasket inside, drilled a hole in it and soldered in a chrome plated copper tube normally used as a toilet feed stem. when I was finished I cut the tube to length and bent it forward into the airflow. Of course I re installed the gasket.
[img]cid:855193823(at)16052007-3239[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
19.77 KB |
358 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Posted: Wed May 16, 2007 5:23 pm Post subject: gas cap not venting? |
ordered one today $25 no problem mal
barry(at)pgtc.com Guest
Posted: Thu May 17, 2007 4:29 am Post subject: gas cap not venting? |
On my Model IV the tube is steel, may be stainless but probably plated after welding along with the cap. And it is welded, I can remove and/or tighten the cap by torqueing the tube and see the weld bead. It is not soldered.
Barry West
19.77 KB |
404 Time(s) |
Posted: Thu May 17, 2007 6:31 pm Post subject: gas cap not venting? |
my cap's where welded w/ stainless tub buy the builder mod 2 ser 347 I ordered a new one from Deb Wednesday will comment on the differences later but I assume the new one will work a definite improvement over the home made one . mal
Float Flyr
Posted: Sat May 19, 2007 4:30 pm Post subject: gas cap not venting? |
It would be very easy to use steel brake line and mig weld it into place. My slightly flared chrome plated copper tube soldered quite nicely into place and is quite rugged but I don't think I'll be reaming on it just to see if it can take the punishment. Steel can be soldered brazed or welded into place as it's not a structural part I expect it's well within the capability of most to fabricate. If you're not too sure of your welding skills (like me) you could have it welded easily at a commercial welding shop.
[img]Signature1.jpg[/img]
Canada
Aerocet 1100s
19.77 KB |
363 Time(s) |
Kitfox III-A
