		DAquaNut(at)aol.com Guest
				 Posted: Fri Feb 10, 2006 7:55 pm    Post subject: Re Rudder trim tab |
				Group,
     I am left with no choice but to put a trim tab on my  rudder. Problem is
 the factory put the ribs on the right side of the rudder as  viewed from the
 rear. I need to make the rudder move to the left substantially .  That would
 involve putting the 2" portion of the trim tab on the left side of  the rudder
 while the 3" portion which is roughly 30* would be on the right side  in order
 to push the rudder to the left. There is not a rib on the left side to  put
 the rivets in. Is it OK to mount the  entire trim tab on the right  side  where
 the ribs are. I will have to put the rivets on the right side  instead of how
 Kolb shows it. Hope I am making sense . I just dont  think I have seen a trim
 tab mounted on the same side as the angled part.
            Ed  Diebel
		John Jung
  Joined: 10 Jan 2006 Posts: 108 Location: Surprise, AZ, USA
				 Posted: Fri Feb 10, 2006 8:41 pm    Post subject: Re: Re Rudder trim tab |
				 	  | DAquaNut(at)aol.com wrote: | 	 		   I just dont  think I have seen a trim
 tab mounted on the same side as the angled part. |
 Ed,
 My rudder trim tab is on the right side to push the rudder to the left. The rivets are on the right and the bend is to the right. It works good for me. Mine is made from Lexan and is less noticable than aluminum.
  _________________ John Jung
Firestar II N6163J
Surprise, AZ |
		HShack(at)aol.com Guest
				 Posted: Fri Feb 10, 2006 8:45 pm    Post subject: Re Rudder trim tab |
				In a message dated 2/10/2006 10:56:01 PM Eastern Standard Time,
 DAquaNut(at)aol.com writes:
 rudder
 order
 where
 Ed, you will surely get more replies tomorrow, but I will offer my opinion
 now.
 I have not seen Kolb's dwg. on the rudder trim tab, but I have seen a bunch
 of tabs.
 If the rudder needs to be moved to the left, then the tab should be mounted
 on the right side & bent to the right.
 Don't see where you have a problem.
 Howard Shackleford
 FS II
 SC                                      do not archive
		Mike Schnabel
  Joined: 27 Jan 2006 Posts: 114 Location: Manchester, TN
				 Posted: Sat Feb 11, 2006 4:08 am    Post subject: Re Rudder trim tab |
				Ed,
   My Firestar 2 has a lexan tab attached to the right side of the rudder covering 2 rib bays, has 3 on the outboard angle and 2 on the attached angle. It is bent to the right thus pushing the rudder to the left (if you are looking at the plane from the rear). My Kolb was built by Brian Milburn, who I believe most would agree has a stellar reputation for building quality Kolb aircraft.
   If you need rudder deflection to the left, to me it makes most sense to have the tab on the right side of the rudder, thus "pushing" the rudder to the left, spreading most of the load along the trim tab itself. With the tab attached to the left side of the rudder the tab would actually be "pulling" the rudder to the left and placing most of the load against the attach rivets. But then again, the load amounts might be so small that this is not an issue. My guess is that the key point is to attach the tab to the side of the rudder opposite the trailing edge tube.
   I do have a Kolb Trim Tab document dated 10-96 that does show the tab attached to the left side of the rudder bent to the right. But in this drawing, the trailing edge tube is on the right side of the ribs, thus making the best installation point the left side. My plane the trailing edge tube is on the left side of the ribs, so the tab is best mounted on the right.
   Well thats just my .02 worth, and in this case, you are probably not even getting your monies worth!
   Mike S
   Manchester TN
   Firestar 2 503
 Group,
 Ed Diebel
				 Posted: Sat Feb 11, 2006 8:28 am    Post subject: Re Rudder trim tab |
				In a message dated 2/11/2006 6:08:56 A.M. Central Standard Time,
 tnfirestar2(at)yahoo.com writes:
  right
            Mike,
      That is the same drawing I had .  I  think I will make a tab out of
 lexan like you said. Do you know what thickness  your tab is?
               Ed
				 Posted: Sat Feb 11, 2006 8:37 am    Post subject: Re Rudder trim tab |
				Thanks too all who replied on rudder trim. I have  decided to go with lexan.
 I just dont know the best thickness to use.
         Ed
		rsanoa
  Joined: 10 Jan 2006 Posts: 71 Location: Bell Buckle,TN
				 Posted: Sat Feb 11, 2006 8:59 am    Post subject: Re Rudder trim tab |
				Just my opinion after having used dozens and dozens. Trim tabs to be optimized usually need to be fine tuned by the very smallest bend.  Lexan is springy and I'm afraid you will be making an awful lot of flights to get the minute adjustment needed. Thin aluminum works best for me. If I need an extra long one, I cut narrow slots in it and bend each segment individually rather than ann at once.
 Ed
  _________________ Ray S.Anderson |
		rsanoa
 Ed
		Denny Rowe
  Joined: 10 Jan 2006 Posts: 89 Location: Leechburg, PA
				 Posted: Sat Feb 11, 2006 9:36 am    Post subject: Re Rudder trim tab |
				Ed,
 1/16" (.0625) or 3/32" .09375) Lexan will work fine for the tab.
 Denny Rowe Mk-3, PA
 PS:Let me know if you need some and what size piece, I probably have enough
 scraps laying around to make your tab.
		Mike Schnabel
				 Posted: Sat Feb 11, 2006 10:25 am    Post subject: Re Rudder trim tab |
				Ed,
   I did not have a good measuring tool, but am pretty sure that the lexan trim tab is 3/16 of an inch. I do like that its not very obvious. Step back a few feet and you cant even see it!
   Mike S
   Manchester TN
   Firestar 2 503
 right
 Mike,
 Ed
		Mike Schnabel
				 Posted: Sat Feb 11, 2006 10:27 am    Post subject: Re Rudder trim tab |
				Ed,
   I just realized i goofed... meant to say 3/32 of an inch NOT 3/16th!!!
   Sorry for the brain freeze. Thanks to Denny, when i read his reply It woke me up!
   Mike S
 Denny Rowe <rowedl(at)highstream.net> wrote:
 Ed,
 Denny Rowe Mk-3, PA
		Richard Pike
				 Posted: Sat Feb 11, 2006 10:46 am    Post subject: Re Rudder trim tab |
				Be careful to only add the absolute minimum of weight to the trailing
 edge of the rudder. If you add too much weight, it will flutter. Guess
 how I know this?
 Richard Pike
 MKIII N420P (420ldPoops)
 Mike Schnabel wrote:
  Ed,
    Mike S
  Ed,
  Denny Rowe Mk-3, PA
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
