Tire Pressure
Goto page Previous  1, 2
wjones(at)brazoriainet.co
PostPosted: Sun May 20, 2007 6:02 am    Post subject: Tire Pressure Reply with quote
Dave that sounds about right for pressure .I fly a Sonerai and it gets very
hard to handle with say over 25# .My Piper Tripacer uses 22# mains & 15#
nose .I have been flying this Sonerai for 30 years and I think I know what
is best for this plane at 600# .I once had a high time pilot call me about
why he was having trouble flying a recently bought Sonerai .I suggested for
him to use the minimum pressure that he could get by with .This cured his
problem enough that he started air racing his Sonerai in the "V" class . I
flew my Sonerai yesterday and today already ,makes an old man feel good
.Making good progress on the 601XL .
Wade Jones South Texas
601XL plans building
Cont. 0200
PostPosted: Sun May 20, 2007 6:33 am    Post subject: Tire Pressure Reply with quote
Correction the 600# is empty weight . DO NOT ARCHIVE
Cont. 0200
rstone4(at)hot.rr.com
PostPosted: Sun May 20, 2007 4:43 pm    Post subject: Tire Pressure Reply with quote
Wade,
I think you have lolved my problem, I have been learning to fly my
ZodiacXL ever since it's completion and all is going well except the
landings. After reading your post about air pressure in the tires of a
light aircraft, I am convinced that the 25 pounds I have in my tires is the
reason I am having so much trouble landing. The nexzt time I fly, I am
going to reduce the pressure down to 20 pounds in all three and see if this
causes my landings to inprove. I will let you know what the outcome is.
Tracy Stone
bryanmmartin
PostPosted: Sun May 20, 2007 6:30 pm    Post subject: Tire Pressure Reply with quote
The pressure printed on the side of a tire is not the recommended
pressure, it is the maximum pressure at the maximum load the tire is
designed for. The recommended pressure will depend on the actual load on
the tire. For instance, the tires on my truck have 60 psi printed on
them but if I were to put that much pressure in them I would be bouncing
all over the road every time I hit a small bump. The recommended
pressure of 34 psi for gross weight is printed on a sticker on the
driver's side door frame and gives a much safer ride. Those who have
suggested a pressure of about 20 psi for the 5 X 5 tires on the 601XL
are in the right ball park.
David X wrote:
Duh! Read the recommended tire pressure on the side of the tire. The aircraft does have suspension, afterall.
Zodiac 601 XL - CZAW Built - Rotax 912S
Bryan Martin
Zenith 601XL N61BM
Ram Subaru, Stratus redrive
Bryan Martin
do not archive.
PostPosted: Sun May 20, 2007 7:13 pm    Post subject: Tire Pressure Reply with quote
Tracy I hope you get your landings worked out ,I am sure you will .We all
know that landings are easier with a reduced tire pressure ,however it goes
without saying that you must maintain a safe pressure . I fly off my grass
strip and when I make a bad landing I never know it due to the wheel
slippage over the grass .Hard pavement landings are much more demanding for
me .
Cont. 0200
David X
PostPosted: Sun May 20, 2007 7:58 pm    Post subject: Re: Tire Pressure Reply with quote
Mine are set for 35 psi as per the manufacture recommendation.
There is a lot of talk about how the lower tire pressure makes for softer landings etc. If you're landing on grass or gravel, then perhaps the lower pressure might help reduce the chances of digging in on soft ground. But if your landing on ashfault or cement, let the suspension do the job instead.
Keep in mind that the lower tire pressure adds to the take-off roll, which is why I keep mine at the upper end. There is a significant difference between a marginally inflated tire and a full one when trying to get up to take-off speed.
DO NOT ARCHIVE
Page 2 of 2
