Upper Fwd Fuse
flywrights(at)yahoo.com
PostPosted: Tue May 22, 2007 10:08 am    Post subject: Upper Fwd Fuse Reply with quote
Is it feasible to cleco in the upper fwd fuse, then fit and install the canopy, and then remove the upper fwd fuse so I can play with my panel and sub-panel? Later on I'd then slide the fwd fuse back into place and rivet it once my sub-panel mods are complete.
Rob Wright
#392
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool. http://us.rd.yahoo.com/evt=48518/*http://autos.yahoo.com/carfinder/;_ylc=X3oDMTE3NWsyMDd2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDY2FyLWZpbmRlcg-- hot CTA = Yahoo! Autos new Car Finder tool [quote][b]
rene(at)felker.com
PostPosted: Tue May 22, 2007 10:43 am    Post subject: Upper Fwd Fuse Reply with quote
That is the way I am doing it. It is the last airframe item I have left to put on.
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert Wright
Sent: Tuesday, May 22, 2007 12:06 PM
Subject: Upper Fwd Fuse
Rob Wright
#392
ScooterF15
PostPosted: Tue May 22, 2007 10:50 am    Post subject: Upper Fwd Fuse Reply with quote
Rob,
I think that would be tough, though maybe not impossible. There might be some rivets that are hard to get to near the point that the canopy rests on the upper forward fuse. I was looking at these pictures of my canopy installation to see if there was anything that would prevent from doing things in that order; I'm not really sure, but maybe they'll help you.
-Jim
40134
In a message dated 5/22/2007 2:12:06 P.M. Eastern Daylight Time, flywrights(at)yahoo.com writes:
Rob Wright
#392
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
See what's free at AOL.com.
 Filesize:  91.58 KB
 Viewed:  306 Time(s)
 Filesize:  82.7 KB
 Viewed:  316 Time(s)
 Filesize:  47.55 KB
 Viewed:  311 Time(s)
PostPosted: Tue May 22, 2007 11:01 am    Post subject: upper fwd fuse Reply with quote
Hopefully I'm not sending this multiple times....
Rob Wright
jesse(at)saintaviation.co
PostPosted: Tue May 22, 2007 11:04 am    Post subject: Upper Fwd Fuse Reply with quote
Yes, it can be and has been done. I would recommend, before gluing the top on, however, that you hold it on with a couple of screws/bolts and make sure you can take off the upper forward fuse and get it back on. I seem to remember we needed to do a little extra sanding to make this possible, but it was a while ago.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Tuesday, May 22, 2007 2:06 PM
Rob Wright
#392
Choose the right car based on your needs. Check out Yahoo! Autos new Car Finder tool. http://us.rd.yahoo.com/evt=48518/*http://autos.yahoo.com/carfinder/;_ylc=X3oDMTE3NWsyMDd2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDY2FyLWZpbmRlcg-- hot CTA = Yahoo! Autos new Car Finder tool [quote] [b]
PostPosted: Tue May 22, 2007 11:55 am    Post subject: Upper Fwd Fuse Reply with quote
Thanks Jesse and James. And yes, I guess I sent it multiple times....
Rob Wright
#392
LloydDR(at)wernerco.com
PostPosted: Tue May 22, 2007 7:09 pm    Post subject: Upper Fwd Fuse Reply with quote
I did it this way and there is no issues that I can think of. The rivets get bucked from the inside channel and there is plenty of room.
Dan
Albert Gardner
PostPosted: Tue May 22, 2007 8:28 pm    Post subject: Upper Fwd Fuse Reply with quote
Rather than putting this little gusset on the outside as the plans indicate, several builders are riveting it on the inside where it is less obvious.
Albert Gardner
Yuma, AZ
 Filesize:  47.55 KB
 Viewed:  284 Time(s)
RV-9A N872RV
RV-10 N991RV
ron.mcgann(at)baesystems.
PostPosted: Thu May 24, 2007 4:50 pm    Post subject: Upper Fwd Fuse Reply with quote
hey Rob
Yes - that is what I have done. I have the cabin deck, engine mount and gear on while the upper fuse is still removable. Just be aware that some of the fwd fuse rib - firewall and fwd fuse skin - cowl hinge rivets may be hard to set with the engine mount in place.
cheers,
Ron
187 finishing
[quote] From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Robert Wright
Sent: Wednesday, 23 May 2007 3:36 AM
Rob Wright
#392
