Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Mon May 21, 2007 3:04 pm Post subject: Sniffle valve |
I am installing a Lycoming sniffle valve (included in Vans FWF kit) to an Aerosport IO-360 and would like to confirm its inteded operation. I "think" it is basically a check valve that should open when manifold pressure is equal to atmospheric (engine not running) to drain any fuel pooled in the sump. Engine running, it should close when manifold pressure drops. The valve I have flows freely when blowing into the sump side, but still passes a bit of air when blown into from the tube side, which I surmise would constitute a small vacuum leak and possible leaner than normal operation.
Is this normal?
Thanks-
Mark
See what's free at AOL.com.
| - The Matronics Engines-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
_________________ From The PossumWorks... |
glcasey(at)adelphia.net Guest
Posted: Tue May 22, 2007 4:15 am Post subject: Sniffle valve |
I assume most Lycoming installations (at least the 3 that I have
owned) just use a simple drain, so there is a "leak" the size of the
tube when the engine is running. The idle speed and mixture
adjustments compensate, so no one seems to worry. A sniffle valve
would presumably reduce that leak, but apparently isn't necessary.
Gary Casey
to an
I "think" it
is equal to
sump. Engine
have
bit of air when
small vacuum
Is this normal?
Thanks-
Mark
apilot2(at)gmail.com Guest
Posted: Tue May 22, 2007 4:29 am Post subject: Sniffle valve |
The engines I'm familiar with all call for a sniffle valve, that looks
like a standard AN 90 degree fitting. I don't know how well it is
supposed to seal after fuel and gunk have drained through it for a few
years.
Gary Casey
> to an
> I "think" it
> is equal to
> sump. Engine
> have
> bit of air when
> small vacuum
> Is this normal?
> Thanks-
> Mark
MONTY(at)bpaengines.com Guest
Posted: Tue May 22, 2007 7:23 am Post subject: Sniffle valve |
If you have a small leak at the “ sniffle “ valve it will only effect you at idle and can be compensated with idle mixture adjustment. At WOT the engine doesn’t care as long as the leak is small. A big hole is another story.
Monty Barrett
BPE, Inc.
Mark Phillips in TN
