Malcolmbru(at)AOL.COM Guest
Posted: Tue May 22, 2007 6:43 pm Post subject: gas cap venting |
my new gas cap came today. it is the same brand Eaton with the same type of s steal vent tube welded to it , but the new one is drilled all the way threw the cap and welded from the inside as well, then the old vent holes on the inside are welded shut it is much easer to blow thru the new one. my old cap's are welded from the top only they aren't drilled all the way threw and the bottom is left alone.
I am a little worried about gas spilling out the gas cap vent of the new cap my old one has never leaked
Last week I flew for 1 11/2 hr and the left tank went dry. the other tank had air bubbles in the hose and I could see air bubbles on the header tank vent line running up and down the hose I was kind of worried about running out of gas. mal KF11
See what's free at AOL.com.
Fox5flyer Guest
Posted: Wed May 23, 2007 2:21 am Post subject: gas cap venting |
Mal, it sounds as if you may be getting uneven pressures on the two caps. Did you replace both of them? Also, check the seals. It's important that both are sealed equally or you'll get a pressure imbalance which will cause fuel to push from one side to the other.
Deke Morisse
N148DM
S5/Soob/CAP
NE Michigan
msm_9949(at)yahoo.com Guest
Posted: Wed May 23, 2007 7:38 am Post subject: gas cap venting |
Mal -
My caps are the same type as your "old " caps. I had similar problems with them: one I could blow through (barely) and the other seemed to be completely plugged. I drilled 3/16" holes on the bottom center of each, apparently like the one you describe in your "new" cap. Now I can easily blow through both of them. (It's part of pre-flight ck list).
I also replaced seals as Deke suggested (with Mercedes-Benz gas cap seals) Now caps vent just fine, both tanks flow and, after 60 hours, no leaks.
Malcolmbru(at)aol.com wrote:
[quote] my new gas cap came today. it is the same brand Eaton with the same type of s steal vent tube welded to it , but the new one is drilled all the way threw the cap and welded from the inside as well, then the old vent holes on the inside are welded shut it is much easer to blow thru the new one. my old cap's are welded from the top only they aren't drilled all the way threw and the bottom is left alone.
Need a vacation? [url=http://us.rd.yahoo.com/evt=48256/*http://travel.yahoo.com/;_ylc=X3oDMTFhN2hucjlpBF9TAzk3NDA3NTg5BHBvcwM1BHNlYwNncm91cHMEc2xrA2VtYWlsLW5jbQ--]Get great deals to amazing places [/url]on Yahoo! Travel. [quote][b]
Guy Buchanan
Posted: Wed May 23, 2007 8:11 am Post subject: gas cap venting |
At 07:42 PM 5/22/2007, you wrote:
| Quote: | I am a little worried about gas spilling out the gas cap vent
I believe I have the same caps with the same problem. When
Skystar welded the caps it appears they welded the steel tube to the
outer cap and to the spring plate inside. They also welded the inside
vent holes. I believe fuel is migrating between the spring plate and
cap inner surface and thence into the cap interior and out the rim
vent holes. (I don't think the spring plate weld penetrated to the
cap inner surface.) It's a very slow leak, but consistent. When I
remove the caps I can shake out fuel.
Others have told me they have filled their caps with resin,
or at least plugged the rim vent holes to prevent this leak path. I
will try the resin trick.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
Lynn Matteson
Posted: Wed May 23, 2007 8:12 am Post subject: gas cap venting |
Speaking of the Mercedes-Benz seals/gaskets, are they rubber (or
Neoprene), and as such, do they fit over the cap locking tabs easily?
The gaskets on my caps are stiff, like some kind of very heavy paper,
and I would not want to try to remove them with thoughts of saving
them. If the M-B gaskets are the same, stiff paper-like gaskets, I'll
stick with what I've got. If the M-B gaskets are rubbery, I may look
into getting some.
Lynn Matteson
flying w/293+ hrs
On May 23, 2007, at 11:38 AM, Marco Menezes wrote:
| Quote: | Mal -
hours, no leaks.
is left alone.
Need a vacation? Get great deals to amazing places on Yahoo!
Travel. _-
www.matronics.com/Navigator?Kitfox-List _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
smokey_bear_40220(at)yaho Guest
Posted: Wed May 23, 2007 8:36 am Post subject: gas cap venting |
I had the same leaky gasket/fuel transfer problem on
the second leg of my first x-country. Did an
emergency fix buy buying some of that orange rubber
gasket sheet from an auto store and cutting my own.
It was a little thick, but you can adjust the tabs for
that.
But I would like to know about the M-B gaskets too.
Always open to something better.
kurt S.
S-5/NSI turbo
Florida and panama
--- Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | Speaking of the Mercedes-Benz seals/gaskets, are
they rubber (or
Check out fitting gifts for grads at Yahoo! Search
http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz
rjdaugh
Posted: Wed May 23, 2007 9:05 am Post subject: gas cap venting |
Lynn,
They are a blue rubber. Very flexible.
You are right, the paper ones are unusable after removing.
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
lcfitt(at)sbcglobal.net Guest
Posted: Wed May 23, 2007 11:37 am Post subject: gas cap venting |
Quoting from an earlier post from Ben B.
Guys the Mercedes Fuel cap gasket is P/N 140-471-00-79 Also under
E2060-124896 It is listed as a hard seal 58x37.5x2.5.
A google search on the E2060- 124896 number gives some sources.
Lowell
Posted: Wed May 23, 2007 12:00 pm Post subject: gas cap venting |
Lynn,
The M-B gaskets are rubber, pliable and thicker than the stiff paper type that come with the cap. I ordered them on-line from some imported car parts house, about $6 each. I had the p/n but can't locate it now check the archives.
[quote]--> Kitfox-List message posted by: Lynn Matteson
into getting some.
Lynn Matteson
flying w/293+ hrs
[quote] Mal -
hours, no leaks.
is left alone.
Travel. _-
Shape Yahoo! in your own image. Join our Network Research Panel today! http://us.rd.yahoo.com/evt=48517/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7 hot CTA = Join our Network Research Panel [quote][b]
jdmcbean(at)kitfoxaircraf Guest
Posted: Wed May 23, 2007 12:19 pm Post subject: gas cap venting |
We have the rubber type gaskets in stock.
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
Lynn Matteson
Posted: Wed May 23, 2007 5:01 pm Post subject: gas cap venting |
Sounds much easier/better to order from you John, than going to the
"furrin car" places...I'll be ordering a pair.
Lynn Matteson
flying w/293+ hrs
On May 23, 2007, at 4:19 PM, jdmcbean wrote:
<jdmcbean(at)kitfoxaircraft.com>
Fly Safe !!
John & Debra McBean
208.337.5111
N369LM |
Float Flyr
Posted: Fri May 25, 2007 5:03 am Post subject: gas cap venting |
I had a fibre gasket on the generic gas cap I converted last year. I removed the one way valve in the top of the cap completely, drilled a hole (5/16") in the centre of the cap and soldered a chrome plated copper tube with the end flared into the hole. Then I put the cap on the plane and marked forward so I could bend the tube into the airflow.
I didn't like the fibre gasket either so I cut it and removed it. I then used it as a template to cut another gasket out of an old inner tube. Works perfectly! Total cost was about $8.00CDN ( Gas caps are a bit dear here ). Oh yes one other thing I'm one of those guys who fly over some rough country so generally unless I'm just up for a few trips around the pond my tanks will be filled to the gunwales. The only leak I ever saw was with the fibre gasket.
[img]cid:336510213(at)25052007-0CD3[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
19.77 KB |
346 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
