wjones(at)brazoriainet.co Guest
Posted: Thu May 24, 2007 7:50 am Post subject: 601XL tube frames |
Hello group ,when plans building are the tube frames 6-B-21-1 & 6-B-21-2 difficult to bend .My plan is to build the form per plans and try to match the form while bending . Any suggestions . Thanks
Wade Jones South Texas
601XL plans building
Cont. 0200
heatonhe36(at)msn.com Guest
Posted: Thu May 24, 2007 10:40 am Post subject: 601XL tube frames |
Wade,
I'm going to try to bend my frames today. I traced the coordinates on a
large piece of paper and will use that for a visual reference. I have a
conduit bender that I am going to try. I put a layer of inner tube rubber
inside the groove to keep from marking the tubing. I think by making small
bends every inch or so, I should be able to make a usable part.
Herb,
Colorado Springs, CO
Quote: | From: "wade jones" <wjones(at)brazoriainet.com>
Reply-To: zenith-list(at)matronics.com
To: <zenith-list(at)matronics.com>
Subject: 601XL tube frames
Date: Thu, 24 May 2007 10:49:10 -0500
Cont. 0200
Posted: Thu May 24, 2007 10:52 am Post subject: 601XL tube frames |
Hi Wade,
You can bend the tubes very accurately if you fill and pack them with
fine sand, cap them with a wooden plug
and set up a simple bend apparatus of clamps, a piece of square tube and
small rigid steel casters.
You work on a table, using it as the jig, trace the form you want on the
table just in front of the bend area and
do a little at a time. You can also bend your top longerons this way
and remove a little bend the same way.
See links
http://www.macsmachine.com/images/canopy/full/frontbowbend.gif
http://www.macsmachine.com/images/canopy/full/frontbowadjust.gif
http://www.macsmachine.com/images/fuselage/full/longeronbender.gif
http://www.macsmachine.com/images/fuselage/full/longeronbend.gif
Larry McFarland at www.macsmachine.com
wade jones wrote:
Quote: | Hello group ,when plans building are the tube frames 6-B-21-1 &
Cont. 0200
Posted: Thu May 24, 2007 11:11 am Post subject: 601XL tube frames |
The attached photos show how I did it (based on Larry McFarland's approach). As Larry said, pack them with sand. Also buy the tubes about 2 feet longer that the finished part to give you some leverage when making the initial bend by hand around your form block. For the tighter part of the curve towards the ends I use a smaller radius work block (not shown) of about 5 inch radius.
-- Craig
Description: |
Filesize: |
93.21 KB |
Viewed: |
344 Time(s) |
Description: |
Filesize: |
89.75 KB |
Viewed: |
317 Time(s) |
Posted: Thu May 24, 2007 11:55 am Post subject: 601XL tube frames |
Thanks to all of you for the ideas for tube bending .And Larry I used your method for bending the longerons and it worked great .
Cont. 0200
