		dmac11(at)telus.net Guest
				 Posted: Fri May 25, 2007 10:33 am    Post subject: propeller optimization |
				I spoke with a gent at Warp Drive who explained that with the short blade's  used on the europa, the blade pitch angle needed for higher speeds can be  greater than optimal causing turbulance near the tips.
 He told me they can modify the blade near the tips to alleviate this problem  and pick up 5 or 10 kts. He also said it would be better for the europa if one  used the 912 gear ratio (2.27:1) rather than the 914( 2.43:1).
 Has anyone tried the constantspeed blade planeform from Warp Drive? or used  the 912 gear ratio on the 914? if so was performance improved?
 Dwayne McAllister
 dmac11(at)telus.net
		rehn(at)rockisland.com Guest
				 Posted: Fri May 25, 2007 11:26 am    Post subject: propeller optimization |
				Dwayne
 I would talk to the folks at Airmaster; they did extensive testing for their prop using the Europa as the test platform! They seem like pretty smart folks and worked with Warp Drive during the development. The Mono wheel may have some blade length compromises due to the ground clearance but I don’t know. I don’t think Rotax would recommend switching gears around between 912 and 914. I sure like my Airmaster, its worked great for 6 years.
 Jerry
 From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Dwayne McAllister
  Sent: Friday, May 25, 2007 11:32 AM
  To: Europa-List(at)matronics.com
  Subject: propeller optimization
 Dwayne McAllister
 dmac11(at)telus.net
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Europa-List  | 	  01234
				 Posted: Sat May 26, 2007 8:33 am    Post subject: propeller optimization |
				Hello Jerry,
   Perhaps you are right. The blades on my air master 308 are from lockwood and
 were warp drive blades that were installed in the airmaster hub. Are they
 different from the blades supplied from airmaster? Perhaps all the blades
 supplied by airmaster have the "constant speed blade planform" I don't know. It
 is a $55 per blade option.
   Rotec in vernon has told me there is no probem using the 912 gears on the
 914, my question was is it really worth any performace advantage? It would be
 interesting to know that before changing gears of course.
   Did you remove your engine from the plane and take it to Vernon or just the
 gear drive?
   I would like to see a photo of your plane if you have one handy,is the panel
 all electric or has it a vac pump? Mine is all electric. It was a nice surprise
 meeting  you, because I knew of your name from the internet.
   Are you up and flying now? me to much work going on but come july and august
 will be free.
                                  Have a great day, Dwayne
 Quoting Jerry Rehn <rehn(at)rockisland.com>:
  	  | Quote: | 	 		   Dwayne
  have some blade length compromises due to the ground clearance but I don't
  know. I don't think Rotax would recommend switching gears around between 912
  Jerry
    _____
  McAllister
  Dwayne McAllister
  dmac11(at)telus.net
				 Posted: Sat May 26, 2007 8:44 am    Post subject: propeller optimization |
				Thanks Jerry, I'll take your advice. Rotax in Canada have told me there  is no problem to use the 912 gears on the 914 but while the man at warp drive said performance would be improved, how much was my question.
 Visit -  www.EuropaOwners.org
		rampil
				 Posted: Sun May 27, 2007 6:53 am    Post subject: Re: propeller optimization |
				Dwayne,
  When you mention the gear ratio of the 912, you are talking about the
 80 HP engine right?
 The 912S and 912ULS use 1:243
 Ira N224XS
		rampil
				of course there is a decimal point in the 2.43
				 Posted: Sun May 27, 2007 11:37 am    Post subject: propeller optimization |
				Yes Ira the 912 80 hp version comes with 2.27:1 gear ratio, (at) 5800 rpm, prop
 will be 2555 rpm, 912s & 914 use 2.43:1 ratio (at) 5800 rpm, prop will be 2386 rpm.
                                              Regards, Dwayne
				 Posted: Sun May 27, 2007 2:41 pm    Post subject: propeller optimization |
				Those concerned w/ this topic would be well to question the basic
 performance of the Warp Drive blades. In a series of emails I exchanged
 w/ Airmaster some time ago, they concede that the shortened blades
 needed for the Europa and given the speed ranges in which it flies,
 these blades leave much to be desired.
 Fred
 A194
 ..hoping to trial fit wings to CM next week...sigh...
 believed to be clean.
				 Posted: Sun May 27, 2007 3:35 pm    Post subject: propeller optimization |
				Fred
 Good point. I spoke to the Airmaster guys a few years ago and they told
 me they spent a lot of time looking for the right blades. Warp were far
 from ideal, the design of the prop was for ragwing microlights, but
 nobody else was cooperative. Sad, Arplast would have been ideal but the
 chemistry didn't work so both Arplast and Airmaster lost out. Alain
 Petit, the Arplast boss is a nice guy but his English isn't confident
 and I don't suppose the NZ guys speak much French. What an opportunity
 missed. Wish I had been in the right place a few years earlier!
 Graham
 Fred Klein wrote:
  Fred
		rampil
				 Posted: Sun May 27, 2007 4:42 pm    Post subject: Re: propeller optimization |
				The short prop blades are really only for monowheel a/c.
 When I ordered my Airmaster system for my trigear, I asked for the
 blades to each be 2" longer than the "standard Europa" i.e., monowheel
 spec.  It was actually a no-charge ECO since the stock blades are
 longer still.
 Ira N224XS
				 Posted: Sun May 27, 2007 9:54 pm    Post subject: propeller optimization |
				On Sunday, May 27, 2007, at 05:42  PM, rampil wrote:
  spec.
 This is of course a step in the right direction; the fan area that a
 prop generates is one of several important factors in prop performance.
 As Ira says, the Warp Drive blades all come from one mold and are
 simply cut down appropriately to serve various aircraft. One problem as
 I understand it is that much of the twist in the WD blades disappears
 when the diameter is reduced. Another is that since the blade was
 designed for a lower speed range (and perhaps lower rpm at cruise) than
 the Europa flies in, at higher speeds the innermost portions of the
 blade actually generates negative thrust due to the configuration of
 the blade cross section. Both of these issues were raised to me by guys
 who know a lot more about props than I do and warrant some
 consideration. Airmaster confirmed to me as Graham states that the WD
 was simply the best available choice...
 Fred
		william(at)wrmills.plus.c Guest
				 Posted: Sun May 27, 2007 11:20 pm    Post subject: propeller optimization |
				Fred / Graham,
 I believe the ideal combination for a constant speed prop would be a
 Woodcomp hub, Arplast blades and a Smart Avionics controller, for the
 following reasons:  The Woodcomp SR 3000 hub is very well engineered and is
 half the price of the Airmaster, the latest Arplast blades PV55 have a slim
 aerofoil with plenty of twist (hub to tip) to cope with cruise speeds of 120
 /130 Kts (about 24 degs is required) and the Smart Avionics controller is
 very good and extremely reliable.
 I am trying to persuade Woodcomp to manufacture 100% composite blades for
 their SR 3000, so that they can build in more twist with a slimmer aerofoil.
 Their current blades have wooden cores with a carbon skin, which makes them
 a bit bulky and limits the amount of twist, because of grain run-out.  They
 also produce a very good leading edge protection.
 William
				 Posted: Mon May 28, 2007 1:47 am    Post subject: propeller optimization |
				Fred,William Ira
 William and everyone
 I continue to be puzzled by the Warp Drive prop, which we all know was
 designed for slow microlight A/C. Jerry Davis once pointed out that you
 need less twist at hi speed, which can only mean that the Warp has the
 wrong twist at any speed! (Jerry is UK agent for Arplast)
 Thinking for a moment, at the root the blade angle should be nearly
 parallel with the direction of flight. At the tip it will be dependant
 on speed, diameter and rpm, (of the prop) With a VP prop it will only be
 optimised at one particular speed but should be a good compromise for
 the speed range.
 I haven't done any sums so more than that I won't say at this point.
 Graham
 William Mills wrote:
  <william(at)wrmills.plus.com>
   the latest Arplast blades PV55 have  a slim aerofoil with plenty of
  	  | Quote: | 	 		   speeds of 120 /130 Kts (about 24 degs is required)
  William
				 Posted: Mon May 28, 2007 2:48 am    Post subject: propeller optimization |
				Graham et al,
 I think you will find, if you do the vector diagrams at intervals along the
 blade, that the faster the forward speed of the A/C, the more twist you need
 in the blades for them to provide lift along the whole length of the blade.
 Hence, the PV50 and 55 have much more twist than the Warp Drive.  At slow
 speeds i.e. at take-off, the inner section of blade will have too much AOA
 but that is better than producing negative lift at high speed (as Fred has
 already pointed out).  The ideal prop would have adjustable blade twist as
 well as variable pitch.
 William
		carl(at)flyers.freeserve. Guest
				 Posted: Mon May 28, 2007 3:47 am    Post subject: propeller optimization |
				There seems to be a suggestion the Arplast Propeller blades are better
 suited to the Europa than the Warp drive ones (as used in the Airmaster).
 Why then is the Airmaster regarded as the better combination - (ie: endorsed
 by the Europa factory.)
 There is a perception that price is generally an indication of quality/
 suitability but in this case that dosent appear to be so.
 I understand the Airmaster costs in the region of £4,000 - what is the price
 of a complete Arplast installation for the Europa? I cant find any prices on
 the UK distributors pages.
 Carl Pattinson
 G-LABS
 In need of a VP/ CS prop.
		TELEDYNMCS(at)aol.com Guest
				 Posted: Mon May 28, 2007 4:55 am    Post subject: propeller optimization |
				In a message dated 5/28/2007 2:58:33 AM Eastern Daylight Time,  europa-list(at)matronics.com writes:
   	  | Quote: | 	 		  Good    point. I spoke to the Airmaster guys a few years ago and they told
 missed. Wish I    had been in the right place a few years earlier! |
  Greetings team,
  I have it on good authority from Airmaster as of this morning that  they are on schedule to release a new electrically adjustable hub at  Oshkosh this year that uses Sensenich hollow carbon blades. I will be  installing this new arrangement on N245E as soon as it becomes  available.
  John Lawton
  Dunlap, TN (TN89)
  N245E - Flying
 See what's free at AOL.com.
		m.j.gregory(at)talk21.com Guest
				 Posted: Mon May 28, 2007 5:58 am    Post subject: propeller optimization |
				Has anyone tried an Elippse propeller on a Europa?  See article
 www.batterson.net/EAA499/Issue77_8-13.pdf which makes some interesting
 points about propeller design.
 Mike
				 Posted: Mon May 28, 2007 5:59 am    Post subject: propeller optimization |
  	  | Quote: | 	 		   Graham et al,
 the
  	  | Quote: | 	 		   blade, that the faster the forward speed of the A/C, the more twist you
 need
  	  | Quote: | 	 		   in the blades for them to provide lift along the whole length of the
 blade.
 William, To an unfulfilled mathematician (one who discovered nurses at a
 sensitive stage in his emotional development and got diverted into
 medicine!) this was too tempting to ignore. For a 62" diameter prop doing
 2300rpm, tip speed 369 kts, I got the following figures for tip angleof
 incidence, angle at one third radius out from centre, twist (the 1/3 angle
 less the tip angle) and speed of travel. These figures relate simply to the
 angles needed to keep up with the airflow. In practice of course an angle of
 attack has to be added to produce lift.
               TIP ANGLE     1/3 ANGLE         TWIST            SPEED (Knots)
                    5.7                    16.7                   11.0
 36.6
                    9.5                     26.6                   17.1
 61
                   14.9                    38.6                   23.7
 98
                   18.4                    45.0                   26.6
 123
                   21.8                    50.0                   28.2
 148
                   26.6                    56.3                   29.7
 184
 That much nicely confirms your statement, although interestingly enough if
 you continue the table the trend for increasing twist goes into reverse,
 thus:
                   33.7                     63.4                   29.7
 246
                   39.8                     68.2                   28.4
 307
                   45.0                      71.6                  26.6
 368
 This extended bit of table is pretty irrelevant to any Europa, although it
 does imply that if we optimised the prop for130 or 140 kts it would be
 pretty good for all speeds above. The snag is that  the optimal twist for
 say 123 kts is 15 more than you need at 50kts and 10 more than at 60kts. So
 a 120 kt prop is going to be bad at getting you off the ground, when at
 least half of the blade is likely to either in reverse thrust or stalled
 mode - and no doubt this accounts for manufacturers generally optimising
 their props on figures below 100kts.
           This situation is also probably highly relevant to the blade cross
 section. I don't have any figures for critical angle of attack of different
 prop blade sections, but I could imagine that the relatively wide Woodcomp
 section might have  a range of perhaps 12 degrees from zero lift to stall
 whereas the thin, sharp nosed section of the Arplast and the Warp Drive may
 only be half that. If so then the Woodcomp type of section would allow you
 to produce some lift (if not maximum) over a significantly greater
 proportion of the blade when in 'Too slow for the Twist' mode.
				 Posted: Mon May 28, 2007 7:15 am    Post subject: propeller optimization |
				Mike...thanks so much for the reference...fascinating article.
 Fred
 DO NOT ARCHIVE
		karelvranken(at)hotmail.c Guest
				 Posted: Mon May 28, 2007 12:33 pm    Post subject: propeller optimization |
				Graham,
 For the first time your explanation doesn't seem very clear to me. I thought
 today there would be a more scientific approach when making a propeller and
 its application. If the Warp blade is so few adequate for the Europa and
 Arplast so good then why don't we have the choice since Airmaster is not the
 manufacturer of the blades?
 Best regards,
 Karel Vranken.
