				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| bobbyhester(at)charter.ne Guest
				|  Posted: Mon May 28, 2007 4:52 am    Post subject: CHT vents |   |
				| Ron, I saw an old post about your cowl louvers. Are they what made the
big differance? My CHT's are getting up to 455 by about 2500 ft on climb
 out and then I level off til they come down to about 430 then I climb
 some more. At cruise I am seeing 410-420. I would really like to see
 them more like 350 at cruise. This is at about 87 degree F OAT on the
 ground. Any other suggestions? Were did you get you louvers?
 Surfing the web with my laptop from Hopkinsville, KY
 Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm
 | |  |  | - The Matronics RV-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV-List
		| Back to top |  |
		| ronlee(at)pcisys.net Guest
				|  Posted: Mon May 28, 2007 5:38 am    Post subject: CHT vents |   |
				| I did three things.
 1)  Remove the extra tubing that went with a dual cabin heat system (tubes
 all over in the back of the engine area).
 2)  Opened up the bottom of the cowl around the exhaust.
 3)  Added louvers made by a friend of a friend.
 I don't know where my flight test numbers are but my recollection is that I
 got about equal
 improvement from all three.  This was after ensuring that the baffling and
 associated sealing
 was in good order.
 Ron Lee
		| Back to top |  |
		| khorton01(at)rogers.com Guest
				|  Posted: Mon May 28, 2007 5:48 am    Post subject: CHT vents |   |
				| On Mon, 28 May 2007 07:50:47 -0500
Bobby Hester <bobbyhester(at)charter.net> wrote:
  	  | Quote: |  	  |
 Bobby - If I understand properly, you have a 180 hp engine.  There are many, many RV-7/7As flying with this engine without CHT problems.  While adding cowl louvers might bring your CHTs down, I fear that you would simply be curing the symptom, without really fixing the basic problem.  This could lead to greater grief down the road, if the basic problem is significant.  For example, some people have high CHTs due to a too lean mixture, caused by the wrong carb.  If this were the problem, it would be far better to find it and fix it now.
 Kevin Horton
 Ottawa, Canada
		| Back to top |  |
		| n616tb(at)btsapps.com Guest
				|  Posted: Tue May 29, 2007 5:19 am    Post subject: CHT vents |   |
				| Bobby,
 My plane was essentially self grounded till I could fix the high CHT
 problem.  I tightened up the cowl, sealed around the front intake ramps, put
 a door across the back of my oil cooler (cooler temps around 160-170) and
 absolutely no joy.  Finally I added louvers I got from Alex De Dominicis in
 Texas.  I think you can reach him through his website at
 http://www.RVtraining.com  After this my plane was flying again.  My CHT
 will still climb to near 450 on climb out sometimes but will be under 400
 for cruise.  They do make a difference.  I cannot say this is the cure all
 as Kevin mentioned there is a reason mine runs hot and so many others don't.
 I just don't know what it is.
 My next step is to remove some more of the lower cowling around the exhaust
 area as mine is particularly smaller since my scoop portion actually hangs
 back over the airframe about 2 inches.  I am going to remove all of that
 this week before I fly this coming weekend.  If you haven't done that, it
 would be advisable.  I am still trying to get mine down quite a bit more.
 My plane is an RV-6 with 0-360A1A and constant speed prop.  I am flying
 without wheel pants or leg fairings.
 [quote] --
		| Back to top |  |
		| Doug Gray
				|  Posted: Tue May 29, 2007 6:30 am    Post subject: CHT vents |   |
				| There has been discussion about two issues that may be a factor for you,
first was casting flash obstructing airflow and the second was adding
 some spacers (washers only) between baffles and cylinders at the
 mounting bolts.
 Sorry I cannot be more specific I not familiar with the specifics,
 others may be able to add detail.
 Doug Gray
 On Tue, 2007-05-29 at 08:18 -0500, Tim Bryan wrote:
 Bobby,
		| Back to top |  |
				|  Posted: Tue May 29, 2007 6:38 am    Post subject: CHT vents |   |
				| I should have mentioned; I did check for casting flash and did not see
anything significant.  I may not have looked in the right place or something
 however.  I also did add washers to the rear of the baffles where they
 typically would restrict the airflow around the rear cylinders.  I saw no
 difference in my application but others have so Bobby may want to check this
 on his. Thanks for bringing these points up.
 [quote] --
		| Back to top |  |
				|  Posted: Tue May 29, 2007 6:41 am    Post subject: CHT vents |   |
				|  	  | Quote: |  	  | My plane is an RV-6 with 0-360A1A and constant speed prop.  I am flying without wheel pants or leg fairings.
 Adding wheel pants and leg fairings will add 10-15 knots at ZERO additional
 power.  That means additional cooling with no changes.  Seems like that
 should
 be a priority.
 Ron Lee
		| Back to top |  |
		| pitts_pilot(at)bellsouth. Guest
				|  Posted: Tue May 29, 2007 8:22 am    Post subject: CHT vents |   |
				| Tim, place a lightbulb below the cylinder and look down through the fins around the spark plug.  There should be about 1/8" (maybe less) between the fins.  With the light, it will be apparent if the flashing is there.  I see it on almost every Lycoming cylinder I look at.
Linn
 Tim Bryan wrote:
 [quote]   [quote]--> RV-List message posted by: "Tim Bryan" <n616tb(at)btsapps.com> (n616tb(at)btsapps.com)
 [quote]--
		| Back to top |  |
				|  Posted: Tue May 29, 2007 8:33 am    Post subject: CHT vents |   |
				|  	  | Quote: |  	  |
 > Tim
 additional
 should
 be a priority.
 Ron Lee
 [Tim] You are right Ron.  I wish I could stop flying long enough to put them
 on.  Actually we moved to Texas and are still living in our 5th wheel trying
 to get a house built.  The wife thinks it is a bigger priority.  I wonder if
 it would make my plane cooler thought? Hmmm.
		| Back to top |  |
				|  Posted: Tue May 29, 2007 5:37 pm    Post subject: CHT vents |   |
				| My engine is a Superior XP-0360
There is no casting flashing on the cylinders
 I added a washer at the rear screw/bolt on the #3 cylinder to help cool that cylinder.
 I've sealed all holes that I can find.
 Baffling seems to be sealing farely well.
 The cowl exit is cut off even, all the way across.
 Doug Gray wrote: [quote]   [quote]--> RV-List message posted by: Doug Gray <dgra1233(at)bigpond.net.au> (dgra1233(at)bigpond.net.au)
 mounting bolts.
 Doug Gray
 Bobby,
 [quote]--
		| Back to top |  |
		| rv8tor(at)lazy8.net Guest
				|  Posted: Tue May 29, 2007 7:06 pm    Post subject: CHT vents |   |
				| Bobby, have you checked the mag timing? Not using LASAR are you?
 The other common problem is too lean a mixture...do you have the usual 50 rpm rise when you pull the mixture to idle cutoff when shutting down?
 The baffles that come with the engine, that go in between the cylinders often have some pretty big holes where they go up against the case.
 I think Kevin is right, the basic design of the cowl has worked on many similar engines...I wouldn't cut it up unless I had tried every other possibility.
 Good luck, John
 Bobby Hester wrote: [quote]       My engine is a Superior XP-0360
 mounting bolts.
 Doug Gray
 Bobby,
 [quote]--
		| Back to top |  |
		| dale1rv6(at)comcast.net Guest
				|  Posted: Tue May 29, 2007 11:13 pm    Post subject: CHT vents |   |
				| The point about rpm rise at shut down has no bearing on the mixture at power settings well above idle.  Has the accuracy of the CHT gauge been verified twice?  I noticed on your website the sealing around the inlets. Can you rig up a couple tape strips to determine if that seal is fluttering during flight? The tape needs to be placed so that engine rock during startup and shutdown will not tear it loose.
Good luck,
 Dale
 From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of John Huft
 Sent: Tuesday, May 29, 2007 11:04 PM
 To: rv-list(at)matronics.com
 Subject: Re: CHT vents
 Good luck, John
 [quote] [b]
		| Back to top |  |
		| PGLong
				|  Posted: Wed May 30, 2007 1:50 am    Post subject: CHT Vents |   |
				| Bobby, I had kind of a reverse problem, but also may work for you. My RV-4  couldn't warm the oil up enough. I closed by about 40-5-%, the lower  cowling area where the exhaust and air exit from cooling the engine. This  brought up my oil temps to normal.  I just put a baffle plate of  sorts to throttle the air leaving. I would think that if you opened your up to  allow more air to exit, you would also get more air in and hence do more  cooling. Wish you the best.
Pat  Long
 PGLong(at)aol.com
 N120PL
 RV 4
 Bay City,  Michigan
 3CM
 See what's free at AOL.com.
 Pat Long
 RV-4, N120PL
 Bay City, MI
		| Back to top |  |
				|  Posted: Wed May 30, 2007 7:38 pm    Post subject: CHT vents |   |
				| I just double checked the timing on my Lightspeed Ign.. The timing was just slightly off. I adjusted it and it is perfect now.  Test flight did not show any change in my CHT's. What I did find out is that I can tell if the timing is correct by looking at the RPM drop on the Electronic Ign. Before makeing the adjustment I had about a drop of about 20 RPM. The first adjustment I made was not right and I got about a 200 RPM drop. I found my mistake and made the correct adjustment and now I only have a 10 RPM drop. When checking the timing on the lightspeed, with a automotive type timing light, you disconnect the Manifold pressure hose to retard the timing, The engine run quite a bit rougher like that, which I beleive is how it would be running with two mags. When the line is connected back it advances the timing and runs much smoother, all this at about 850 RPM. This is some good info to find out. Now I've got to get to work on those wheel pants and leg farings.
 Superior XP-0360  65hrs and counting
 mounting bolts.
 Doug Gray
 Bobby,
 [quote]--
		| Back to top |  |
		| martin(at)gbonline.com Guest
				|  Posted: Fri Jun 01, 2007 7:00 pm    Post subject: CHT vents |   |
				| Tim,
8 years ago when I finished my RV8, I encountered similar problems with
 temps.  After trying a lot of different fixes, it was suggested that my
 electronic ignition was set to far advanced.  I reset the ignition timing
 (with more care and also reread the instructions) and have had no problems
 since.  Also loose fitting of engine baffles etc will also cause your
 problems.  Good luck.
 Dick Martin
 RV8 N233M
 the fast one
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
