		| Author | Message |
		| bobbyhester(at)charter.ne Guest
				|  Posted: Mon May 28, 2007 5:18 am    Post subject: Nose gear lube |   |
				| My swiveling nose wheel has gotten jerky. Will just squirting a few
shots of grease in the zert fitting take care of this or do I need to
 take it all apart clean, grease and reassemble? 65 hrs. on it.
 Surfing the web with my laptop from Hopkinsville, KY
 Visit my RV7A website: http://webpages.charter.net/bobbyhester/MyFlyingRV7A.htm
 | |  |  | - The Matronics RV-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?RV-List
		| Back to top |  |
		| denis.walsh(at)comcast.ne Guest
				|  Posted: Tue May 29, 2007 5:19 am    Post subject: Nose gear lube |   |
				| I would recommend not squirting anything in the grease fitting.  Long
a go there were reports of excess grease melting/oozing down on the
 bell washer and giving you the shakes on landing.  Haven't heard much
 lately.
 Have been slathering a little #5 grease on the wear points after
 dissassembly and put it back together, once a year.
 Has worked ok for my first 3,300 landings.
 P S check the  big washers for burrs.  Jerky is not usual.  Be sure
 and adjust tension for prescribed break out force.
 Denis Walsh
 On May 28, 2007, at 07:17 262740005, Bobby Hester wrote:
  	  | Quote: |  	  |
 to take it all apart clean, grease and reassemble? 65 hrs. on it.
 MyFlyingRV7A.htm
		| Back to top |  |
				|  Posted: Wed May 30, 2007 7:39 pm    Post subject: Nose gear lube |   |
				| I took it apart cleaned it up and lubed it real good, no more herkie
jerkies, nice and smooth
 Bobby Hester wrote:
  	  | Quote: |  	  |
		| Back to top |  |
