Colin K.
Posted: Tue May 29, 2007 3:50 pm Post subject: LSA compliant vs. not |
How late in the construction is it practical to make the decision on whether your Ligtning will be LSA compliant or not?
I would think it would be just before you chose your propellor and needed to decide to fit VGs rather than gear leg fairings and wheelpants. In other words, right at the end.
Am I missing something?
Colin K.
OK
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
_________________ Colin K.
OK |
N1BZRich(at)AOL.COM Guest
Posted: Tue May 29, 2007 7:18 pm Post subject: LSA compliant vs. not |
In a message dated 5/29/2007 7:51:27 P.M. Eastern Daylight Time, cjk129(at)cox.net writes:
Quote: | Am I missing something? |
Colin,
Don't forget the 1320 max gross weight requirement that should be on the data plate and of course in the log book. The log book entry after your 40 hours are complete is where you document the stall speed and max continuous rpm speed. Others have already mentioned no later change to meeting light sport if you document something other than light sport compliant at first.
Blue Skies,
Buz
See what's free at AOL.com.
Kayberg(at)aol.com Guest
Posted: Wed May 30, 2007 4:47 am Post subject: LSA compliant vs. not |
In a message dated 5/29/2007 11:06:33 PM Eastern Daylight Time, flying(at)qdea.com writes:
Quote: |
Don't forget that the Experimental Amateur Built Aircraft must have
met the definition of a Light-Sport Aircraft *since its original
certification*.
This means that if it *ever* had a variable-pitch prop or didn't meet
some other part of the definition, it is technically *never* eligible
to be flown as an LSA by a Sport Pilot.
You can read the rule here:
http://www.sportpilot.org/learn/index.html
I think there is some bad word engineering here. "Since its original certification" means it must be regestered and loged as Amateur-Built Light Sport from the get-go. You cannot retro register an airplane to another catagory. If any mods are made to take the plane out of Lite Sport parameters it is no longer light sport. It is still a legal airplane. But cannot be flown by a Lite Sport pilot. Just changing the configuration back to the tested Light Sport configuration would make it a light sport again.
If you do a major change, like the prop, then there is a logbook notificatiion, possibly a Fed approval and a fly off. If you add or subtrack wheel pants and fairings, that is not a major mod. A variable pitch prop can be installed from the get-go, it simply cannot be in-flight adjusted from the cockpit. Ground adjust is OK. If you get ramp checked, you should be ready to show how your current adjustment meets the pitch requirements for your Light sport test data.
All this is subject to debate and interpretation, of course. My point is that if words can be engineered in more than one way, then one can take whatever stand you think you can defend. You can work it out with the Feds before or try to work it out after. Permission is often more difficult than forgiveness, particularly when the likelyhood of gettng caught is low.
Also, you can make any claims you want about a Lightning you assemble. I can claim mine stalls at 20 mph if I want. Or that it will only go 100 mph. I can claim that my special MUD FLAPS on my wheels make it so. Because it is EXPERIMENTAL flight, the latitude for changes to an airplane is huge. The only real absolute for Light Sport is Registered Gross Weight. In my opinion, it is about possiblites, not restrictions.
Doug Koenigsberg
Posted: Wed May 30, 2007 4:58 am Post subject: LSA compliant vs. not |
In a message dated 5/30/2007 8:49:04 A.M. Eastern Daylight Time, Kayberg(at)aol.com writes:
Quote: | In my opinion, it is about possiblites, not restrictions. |
I vote for Doug to be the next head of the FAA.
Buz
testpilot(at)wildblue.net Guest
Posted: Wed May 30, 2007 6:30 am Post subject: LSA compliant vs. not |
Hi Doug
I am registering my Light Sport as Expererimental only, not amateur-built-light sport. I fly and have owned a lot of aircraft. When I was able to pass my medical I could fly my experimental and certified aircraft under either rule as long as they had always met (weight, airspeed, etc) as light sport. Flying the same aircraft at night or IFR I could only do that under a pvt or above with medical yet the aircraft was still sport pilot authorized.
If I did a mod to the aircraft that exceeds any light sport limit such as have the weight increased to 1400 pounds and FAA approved, then if I was to remove the mod and return the weight to 1300 pounds and approved by the FAA that aircraft can never be used for sport pilot again. These limits are only the ones put out by the FAA that are applied to the airfrane speed, weight, ect. to make it meet light sport.This is a dumb rule like failing a medical, no fly. No take medical, no fail, same problem, you fly. I have an Ercoupe for sale that caught is under that rule. On our lighting that is experimental I can fly it light sport since I met the limitations but my wife can fly it FIR at night. If we register it as light sport, amateur built it is restricted to fly only under those rules according to what I have read and the local FAA thinks. I do not think this is true but do not want to take a chance and get stuck in only light sport operation by registering it light sport. Our old J3, fly light sport, fly pvt at night. Hope this helps but as of now, I don't trust anything the FAA says about medicals, light sport and aircraft certification. Too many contradictions. Johnny
flying(at)qdea.com Guest
Posted: Wed May 30, 2007 6:45 am Post subject: LSA compliant vs. not |
There is no "Amateur-Built Light Sport" category, there are only
Experimental Amateur-Built airplanes that meet the Light Sport
definition.
According to the rule, "just changing the configuration back to the
tested Light Sport configuration" does *not* make it a Light Sport
aircraft again, because it would not have met the definition of a
Light-Sport Aircraft since its original certification.
I don't care what anyone does with their aircraft, and in fact I
don't like the rule, but it's better to be well-informed on this
matter before the fact.
What I'd like to see is a driver's license medical for recreational
pilots. In that case, a standard Lightning can be flown without a
medical certificate.
Hugh Sontag
Quote: | In a message dated 5/29/2007 11:06:33 PM Eastern Daylight Time,
certification*.
<http://www.sportpilot.org/learn/index.html>http://www.sportpilot.org/learn/index.html
test data.
Doug Koenigsberg
See what's free at <http://www.aol.com?ncid=AOLAOF00020000000503>AOL.com.
<http://www.matronics.com/Navigator?Lightning-List>http://www.matronics.com/Navigator?Lightning-List
Kayberg(at)AOL.COM Guest
Posted: Wed May 30, 2007 9:09 am Post subject: LSA compliant vs. not |
In a message dated 5/30/2007 8:59:22 AM Eastern Daylight Time, N1BZRich(at)aol.com writes:
Quote: | Quote: | In my opinion, it is about possiblites, not restrictions. |
Buz
Thanks for the Vote.
For the fun of it, Permit the following assertions, if you please.
1) Within the rules, there is usually latitude. Read loopholes. That is why there are so many lawyers. They are being paid to find that latitude; often because rules were bent beyond all recognition.
2) If you dont raise a stink, no one will dig in your feces. In my 4 years running Sky Ranger Aircraft Company, I have only gotten one call from the Feds. They wanted to know what the hell kind of airplane flew into Class B airspace and landed on a taxiway without bothering to notice or talk to the tower! They were simply searching for the proper implement to do some digging. More than 100 Sky Rangers flying about the country had not attracted their attention, so they didnt know what it was.
3) If the Feds want you, you are toast. Every flight we make has at least one violation of the FAR's. Our real mission is to offer dis-incentives to have it discovered. If you and your airplane look like you deserve to commit aviation, you can probably get away with it.
4) If you are going to be spectacular, be sure you have your paperwork in line. When asked if he had advice for his drug-selling clients, one lawyer said, "If you are going to transport some quantity of drugs, be sure your tail lights work and drive the speed limit!!!" I often see people try to show off at fly-in's. How stupid it that? Most fly-in's have Feds in attendance who dont WANT to work that hard. But they will if pressed. Do your low flying and stupid stunts where they ARN'T!
5) Remember that when a Homebuilt airplane is inspected in the USA, it doesnt have to be able to fly!! There are no flight charactoristic requirements. Much attention will be paid to nuts, bolts, cable tension, threads showing, control stops, brakes, tires etc. Paperwork will be required that does not make sense. In my opinion, the least regulated part of Experimental aircraft is the most important.... 1)a decent flying aircraft to start with 2) pilot skills that match the aircraft capability. Europeans require extensive flight testing of aircraft designs before they can be sold; done by real test pilots. They worry less about a bolt being installed with the nut on top and more about flight charactoristics.
6) I think it is important to consult with other pilots who HAVE knowlege and a decent skill level. I am amaized by homebuilders who slap some peice of crap together and then slam it into the trees because their control cables are crossed. When they were offered some sage advice they neither considered it nor considered the source. By definition, innovations are rarely appreciated by all. But when you decide to do something new and different, at least carefully consider the criticisms of the concept. Of course there are also people to avoid at most airports. But we are all in this thing together.
I was in the mood for a bit of verbal divestment. Sorry.
doug koenigsberg
Colin K.
Posted: Wed May 30, 2007 6:41 pm Post subject: LSA compliant vs. not |
Thank you all for thoughtful responses to my original queston.
I have read and re-read your posts and refined the following:
The airplane will always be certified as an EAB.
If built , with a ground adjustable variable prop and VGs, and initially tested and documented to meet LSA speed constraints, including the 1320 lbs gross weight limit, it can then be legally flown by a Light Sport Pilot.
It can be modified with gear leg fairings and wheel pants and the propellor pitch can be adjusted thereafter, allowing it to exceed LSA speeds, so long as it does not then exceed the 1320 lbs weight limit, which it was originally certified with. It can then be flown by a Private Pilot, but not a Light Sport Pilot. No documentation is required, since none of the modifications are major.
Later, the fairings and pants could be removed, the propellor pitch readjusted to original setting and the Light Sport Pilot could then fly it again.
I am not trying to abuse or contravene the regulations. I am interested in flying legally and fast, initially as a Private Pilot and later a little slower, as a Sport Pilot, without having to buy or build a new airplane.
I am sure that if carried on ad-infinitum, this thread would become very boring, however, if anyone sees a fatal flaw in the above logic, I would really appreciate hearing from you. Is this an interoretation that one could feel confident in presenting to the FAA?
Also, I had one other question, which no-one responded to (must have been more boring than this one , so I will ask again:
I would think it would be just before you choose your propellor and needed to decide to fit VGs rather than gear leg fairings and wheelpants. In other words, right at the end.
Thanks for your tolerance!
Colin K.
OK
definition.
Hugh Sontag
>certification*.
>test data.
>Doug Koenigsberg
OK |
Posted: Wed May 30, 2007 8:06 pm Post subject: LSA compliant vs. not |
In a message dated 5/30/2007 10:42:33 P.M. Eastern Daylight Time, cjk129(at)cox.net writes:
Quote: | Is this an interoretation that one could feel confident in presenting to the FAA?
NO. Colin, the part of your interpretation that I think is wrong and would not fly with the FAA is:
My understanding (others may have different thoughts) is that any airframe or propeller changes "should" be documented in the log books and the experimental aircraft placed back into phase one testing until the changes are proven out. "IF" you do document these changes, you now have prevented the airplane from flying in the future by a light sport pilot. Again, this is my interpretation. I would suspect that some will make the changes that you mentioned, but not document them. Now don't tell the FAA I said that.
And speaking of the FAA, some pilots think of the FAA just like a fire hydrant thinks of a dog.
Anonymous
mark.stauffer1(at)gmail.c Guest
Posted: Wed May 30, 2007 8:12 pm Post subject: LSA compliant vs. not |
<snip>
<snip>
No, this is incorrect. The aircraft must stay LSA compliant at ALL TIMES.
Quote: | From EAA.org Sport Pilot web site:
Light-Sport Aircraft:
The FAA defines a light-sport aircraft as an aircraft, other than a helicopter or powered-lift that, since its original certification, has continued to meet the following: (goes on to define LSA to include stall speed and maximum speed in level flight)
"Has continued to meet the following" is the key phrase. I'd be cautious if you're using "no major modification was performed" as your basis for changing the configuration of the airplane and the results just so happen allow the plane go faster. Each MIDO (or FISDO - I always get them mixed up) has their interpretation of the rules. I was present when our local Amateur Built - Designated Airworthiness Representative (AB-DAR) was being observed/inspected performing his duties by his boss at the MIDO. I was absolutely amazed at what some of his (FAA MIDO guy) interpretations of "major modifications" were. How about placing tape over a NACA scoop? Extreme interpretation? To me, yes. To him no, but he's the one that can make your life miserable. Your MIDO's mileage may vary!
Sure, how does he (the FAA) know if you tested/certified the plane with the wheel pants on or off or what pitch you had the prop set to but as Doug stated earlier just be prepared to defend yourself if necessary.
I'm not trying to be the sport pilot Gestapo, this is just a question that we get quite often, especially at air shows.
I hope this helps.
Mark
Posted: Thu May 31, 2007 4:15 am Post subject: LSA compliant vs. not |
I suppose I am preaching to the choir, but I dont have confidence that my point is being understood.
Trying to be a bit more clear, here is my understanding.
Guys, there is only one absolute in Light Sport. Paperwork that lists the gross weight at 1320. Thats it.
There are two other very important parameters. Stall speed clean and Maximum continous. But those are subject to interpretation. As Buz says, "your milage may vary"
A strict interpretation that some are advocating would mean that IF you stalled too fast or went too fast ONE TIME you no longer have a Light Sport plane! That is a bit over the top. Conversely, if you brag to the Feds that your Light Sport will stall at 80 and run 200, you will invite some unwanted interest.
So, the Feds have one point of view; the folks at Lightning must hold a particular line that does not invite distain for the Feds....but there is another bit of understanding that I have tried to expound.
IF YOU ARE THE OWNER, IT IS YOUR AIRPLANE!
Unless you are dumb enough to log that your stall speed seems to exceed 40 knots or your top speed exceeds 120 knots, no one will know! You have every right to claim that even without VG's and with fairings, YOUR Lightning is compliant, EVEN IF the "factory" says otherwise.
Additionally, HOW DO YOU KNOW WITHOUT TESTING? Despite how nicely finished and uniform the parts are done, each airplane varies. You simply WILL NOT know your airplane's performance until you FLT it. You may have to do what the CT does and cheat on the stall speed by flexing the flaps down a bit!
I understand that customers want a definitive answer before a purchase. But they should also understand that Experimental Aviation is defined by a circle not a point. Certified aircraft must comply with specific regulations and are treated as such. I am saying that is a single point. But wether kit built or stick built, there is a "circle" of operations that is legal for the Experimental rather then a single point. Yes, there are some absolutes; some points within the circle. But there is a lot of latitude. The responsibility for that latitude rests on the BUILDER/OWNER/PILOT not the "factory". They simply base their claims on the performance of a prototype.
Bureaucrats will define that circle as small as possible to match their General Aviation cultural reference. The Ultralight people like to pretend there is no circle at all. Reality is somewhere between. You may chose to 1) hide from the Feds 2) smooze the Feds 3) Be sensible and safe, obeying all the rules you can 4)ignore everything and everybody and just do whatever the hell you want.
As a "manufacturer' one must smooze the Feds. As an Owner, I suggest # 3. Play by a reasonable interpretation of the rules.
It is a free country.
Doug Koenigsberg
In a message dated 5/31/2007 12:13:54 AM Eastern Daylight Time, mark.stauffer1(at)gmail.com writes:
Quote: | --> Lightning-List message posted by: "Mark Stauffer" <mark.stauffer1(at)gmail.com>
<snip>
<snip>
I hope this helps.
Mark
vettin74(at)yahoo.com Guest
Posted: Thu May 31, 2007 5:50 am Post subject: LSA compliant vs. not |
The key word in all of this is "continuously operated as" this means to be operated as a Sport pilot eligble aircraft the Expermental Ameture built Lightning must show in the airframe log book a entry showing the Vso, Vs1, Vx, Vy, Va, VNE for the aircraft. And the weight and CG location at which they were found. So if the performance numbers that were found during testing were with in the parameters of the sport pilot rule and properly documented here than the aircraft can be operated by a Sport pilot. Again if the aircraft has a "Major change" and the is put back into phase 1 flight testing the new data should be recorded, if the new data is out of parameters for sport pilot and than is operated as such the aircraft can not be brought back to the original parameters because it was not "continuously operated as" so if you start out with a light sport compliant lightning and want to go faster with no intention of coming back, put the mods on document it and go. But do not expect to go fast in the first palce and come back to the Sport Rule later unless your performance numbers show that the plane originaly was flown with in the parameters.....Rember that 2850 is max continuous power for the jab with intermitent operation exceeding that.....it just depends on how long that internitent operation is for.....
Nick
N1BZRich(at)aol.com wrote:
[quote] In a message dated 5/30/2007 10:42:33 P.M. Eastern Daylight Time, cjk129(at)cox.net writes:
Anonymous
Boardwalk for $500? In 2007? Ha!
[url=http://us.rd.yahoo.com/evt=48223/*http://get.games.yahoo.com/proddesc?gamekey=monopolyherenow]Play Monopoly Here and Now[/url] (it's updated for today's economy) at Yahoo! Games. [quote][b]
Posted: Thu May 31, 2007 1:30 pm Post subject: LSA compliant vs. not |
Yeah, what he said.
Doug
In a message dated 5/31/2007 9:51:56 AM Eastern Daylight Time, vettin74(at)yahoo.com writes:
Quote: | The key word in all of this is "continuously operated as" this means to be operated as a Sport pilot eligble aircraft the Expermental Ameture built Lightning must show in the airframe log book a entry showing the Vso, Vs1, Vx, Vy, Va, VNE for the aircraft. And the weight and CG location at which they were found. So if the performance numbers that were found during testing were with in the parameters of the sport pilot rule and properly documented here than the aircraft can be operated by a Sport pilot. Again if the aircraft has a "Major change" and the is put back into phase 1 flight testing the new data should be recorded, if the new data is out of parameters for sport pilot and than is operated as such the aircraft can not be brought back to the original parameters because it was not "continuously operated as" so if you start out with a light sport compliant lightning and want to go faster with no intention of coming back, put the mods on document it and go. But do not expect to go fast in the first palce and come back to the Sport Rule later unless your performance numbers show that the plane originaly was flown with in the parameters.....Rember that 2850 is max continuous power for the jab with intermitent operation exceeding that.....it just depends on how long that internitent operation is for.....
Nick
