jaybrinkmeyer(at)yahoo.co Guest
Posted: Fri Jun 01, 2007 9:47 am Post subject: Vans mount bracket and ME406 ELT? |
I have a single Vans ELT/Strobe mount and it fits perfectly with the Wheelen
strobe power supply (nice!). Does anyone know what needs to be done to the Vans
mount to hold the Artex ME406 ELT? It's not obvious (at least to me) looking at
photos of the ME406 mounting tray how one would securely mount the tray to the
Vans bracket.
Thanks in advance for replies!
Jay
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games.
http://sims.yahoo.com/
bcondrey
Posted: Fri Jun 01, 2007 9:55 am Post subject: Vans mount bracket and ME406 ELT? |
Jay,
The ME406 tray has multiple sets of holes is designed to be able to
mount in the same place as either an Ameriking or ACK ELT (to make
retrofit easier). I made a mount that fit an ACK E-01 and the ME406
lines up exactly with those holes. I can get you details when I get
home if you need them.
Bob
AirMike
Posted: Fri Jun 01, 2007 5:09 pm Post subject: Re: Vans mount bracket and ME406 ELT? |
I mounted my ELT under the fiberglass fairing in the tail. Fits nice back there. One of my buddies suggested that I bend the antenna under the fiberglass fairing also........
As he suggested, putting the antenna vertical my not be all that meaningful as he said, " who knows what position the plane will be in after a crash." Inside the fiberglass cone it is probably better protected in a crash.
_________________ See you OSH '18
Q/B - sold. |
jump2(at)sbcglobal.net Guest
Posted: Sat Jun 02, 2007 2:10 am Post subject: Vans mount bracket and ME406 ELT? |
Yea but your tail will block out some of the signals and why not turn it on before you crash if you have time? Call your Elt maker and see What they have to say.
Look at The AC43 and see what it says about mounting Elt antennas. It's only your life and the people you carry.
Pat
AirMike <Mikeabel(at)Pacbell.net> wrote:
[quote]--> RV10-List message posted by: "AirMike"
As he suggested, putting the antenna vertical my not be all that meaningful as he said, " who knows what position the plane will be in after a crash." Inside the fiberglass cone it is probably better protected in a [quote][b]
