darinh
Posted: Sat Jun 02, 2007 10:01 pm Post subject: Series 7 heater questions?? |
I have two questions related to the cabin heater install in my Series 7.
First:
I am installing the cabin heating kit on my Series 7 and it required me to cut/drill 2 - 1 inch holes in the SS firewall. I have a metal flywheel cutter that works great on aluminum and mild steel but stainless is a beast to drill or cut as it stress hardens with heat. Is using the flywheel the best way to approach this? I am going to try it tomorrow but don't want to flub up my firewall. I'm sure many have done this so I thought I would as before I go forward with it.
Second:
The radiator (Earl's supplied with the heater kit) has two fittings for the water that have an o-ring seal. The Kitfox manual says to use a good quality thread sealer, while the Earl's installation instructions for the radiator say to simply apply a good quality oil to the o-rings and snug the fittings with a wrench. Do I need to use the thread sealant and if so, can I use teflon tape? Seems like that would do the trick and actually be overkill given the o-ring designed seal. Any thoughts?
Thanks guys,
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
wingsdown(at)verizon.net Guest
Posted: Sun Jun 03, 2007 1:18 am Post subject: Series 7 heater questions?? |
I used a drill first, go slow speed with pressure add lube if you like
with cutting oil. Then use the appropriate hole knock out punch. Much
cleaner. SS is difficult to cut. One inch will probably be OK if your
careful and have a good quality hole saw with metal cutting type teeth.
Don’t go fast or you will burn up the teeth and or bit. What make a nice
clean hole if you don’t want or have the hole punch is a step drill. You
can find them in and sizes. Good luck. OH be careful of what's on the
other side of the firewall. Sounds simple I know.
Rick
john(at)leptron.com Guest
Posted: Sun Jun 03, 2007 5:25 am Post subject: Series 7 heater questions?? |
Darin,
I am still unpacking and setting up my shop at home, but, I thing I can find
my 1 inch punch. It is a clamshell thing and all you need is a 1/4" (I
think) hole then a wrench to tighten the clamshell. I am headed to Heber
city in the am; I could drop by or meet you.
Do not use the Teflon tape, bad use on an airplane. Teflon in a tube from
loctite can be found at a parts store, if you feel the need. (Napa)the o
rings will do the job just fine.
John Oakley
89 kitfox 4 speedster
750 hours now
Ogden ut
lcfitt(at)sbcglobal.net Guest
Posted: Sun Jun 03, 2007 5:53 am Post subject: Series 7 heater questions?? |
Darin,
I think the manal was referring to the taper pipe fittings that were on the
earlier Earl's coolers. If yours has O-rings, I would go with the Earl's
instructions. Regarding the firewall hole. With what is in my shop, I
would try the fly cutter at the slowest speed possible. The punch would be
the best - no heat. I have had poor results with hole saws as they are very
rarely round and have always given me a hole somewhat larger than the
desired dimension.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 870 hrs.
7suds(at)Chartermi.net Guest
Posted: Sun Jun 03, 2007 6:04 am Post subject: Series 7 heater questions?? |
| Quote: | I have two questions related to the cabin heater install in my Series 7.
Darin,
Sounds like you have received some good advise already, knock out punches
work great just make sure they are sharp and close clearance for use on
stainless, another option is to drill a smaller hole than needed, again make
sure you have a sharp bit, use oil and turn the bit slow with lots of
pressure, I also like to back up drilling light stainless with a block of
wood, and then use a dremel tool with a stone to finish out to your desired
size. However you make the hole you will want to debur any sharp edges and
also use a rubber grommet or sleeve in the hole to protect the fluid hoses.
Lloyd C
Upper Mich.
Mod 5 912ul
Maybe next Summer
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sun Jun 03, 2007 6:58 am Post subject: Series 7 heater questions?? |
Darin,
I just recently installed the heater in my 7. I have the firewall and
engine mounted and did not want to remove to drill the two holes. First I
tried the step drill. It was not possible to get a clean hole and prevent
hole drift. I stopped before making a big mess. I then used a 1.25"
knockout punch to finish. Finally I installed 1.25" OD, .875" ID rubber
grommets. The heater's fittings fit tightly within these. Be sure to make
careful measurements - the fittings and grommets just clear the structural
tubing of the fuse. If you need a couple of grommets, send me your address,
I'll send them to you (I had to buy an entire bag of the silly things!).
Oh, I'll send a couple of photo's (digital via email) if you'd like.
Vic
Vic Baker
Carson City, Nv
K-7 912S Warp 80%
_________________ Vic Baker
Series 7
Carson City, Nevada |
Guy Buchanan
Posted: Sun Jun 03, 2007 7:42 am Post subject: Series 7 heater questions?? |
At 11:01 PM 6/2/2007, you wrote:
| Quote: | I am installing the cabin heating kit on my Series 7 and it required
I have a very thin hardened stainless firewall. It's very hard to
drill. For free-standing holes, (those drilled without benefit of a
backing plate, ) I start with a very small drill, on the order of
1/16" and drill a pilot hole. I then enlarge that to about 3/8" with
a step drill. I then go larger with a Dremel and burr. I have found
that no matter how sharp my drills, they cause the hole to divot. (No
backing plate.) And no matter how sharp my step drills, they drill an
out-of-round hole. (Again, no backing plate.) So I use the burr to
enlarge to a marked line. It's not perfect, but the best I could get
without a backing plate.
I never considered using a punch, as I though the stainless was way
too hard. It sounds like I should have tried that first. I would also
contact Murle Williams on this question. He's a perfectionist and has
probably figured the best way to drill large holes in free-standing stainless.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
darinh
Posted: Sun Jun 03, 2007 8:38 am Post subject: Re: Series 7 heater questions?? |
Thanks guys for the info. I will probably take John up on the punch as he lives nearby. I will let you all know how it turns out.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Sun Jun 03, 2007 7:24 pm Post subject: Series 7 heater questions?? |
Vic,
I think an attachment picture would be proper on the list for everyone. This
is a building list.
John Oakley
darinh
Posted: Sun Jun 03, 2007 7:42 pm Post subject: Re: Series 7 heater questions?? |
I have made the holes, one turned out ok the other turned out perfect. Here is what I did.
1st hole: Pilot drilled to 1/4" starting with a #40 and working up in steps spinning the drill very slowly with lots of pressure. Then I used the flywheel cutter...ended up sharpening the cutter 3 or 4 times before I got the hole. Then finished up with the dremel. I wouldn't try this method again.
2nd hole: Drilled the same pilot hole as before but then used my Unibit and it cut the stainless very easily. I used a 2x4 as a backing plate and drilled slowly. The hole is very nice and clean with not warping of the stainless. This is the recommended way if you don't have a laser or punch handy.
Series 7
914 Turbo
Kaysville, Utah |
