Yak 52 Problems
PS
PostPosted: Sat Jun 02, 2007 2:06 pm    Post subject: Yak 52 Problems Reply with quote
1) How does one unclog a fuel vent on a Yak 52 with the single vent system? I took a rubber tube attached it to the vent under the belly of the plane, blew thru it and found it difficult to blow air into the tanks. Also, the left tank seems to be transferring fuel to the right tank which overflows while sitting on the ground with caps loose. Any ideas?
2) Where is the fuse located for the Baklan radio? If the fuse is good, what would the next step be in finding out why the radio is dead?
Thanks in advance to responders,
Phil
See what's free at AOL.com.
Phil
netmaster15(at)juno.com
PostPosted: Sun Jun 03, 2007 8:41 am    Post subject: Yak 52 Problems Reply with quote
Unclog fuel vent? Try piece of safety wire
Phil
ttp://www.matronics.com/Navigator?Yak-List
tronics.com
Scooter
PostPosted: Wed Jun 06, 2007 11:30 am    Post subject: Re: Yak 52 Problems Reply with quote
Recently someone mentioned replacing a 10 amp fuse on the "radio tray" to repair a radio problem.
