jonboede(at)hotmail.com Guest
dsavarese(at)elmore.rr.co Guest
Posted: Thu Jun 07, 2007 7:48 am Post subject: engine mounts |
Besides lifting the engine slightly to relieve the weight from the engine
mount rubbers, I'd suggest removing the generator and the magnetos. It will
make the job significantly easier. Before you remove the mags, remove any
grease or oil around the base of the mag where it mates with the accessory
case. Then using a Sharpie pen make 3 vertical marks between the base of
the magneto and the case about 1/4" to 3/8" apart. The marks will enable
you to reinstall the magnetos in precisely the same location and not have to
retime the magnetos. Replace one rubber mount at a time. The attached
document should help with how tight the plates, nuts and washers should be.
Dennis
 Download |
| Filename: |
DAMPERS_INSTALLING_MODEL_.PDF |
29.14 KB |
| Downloaded: |
201 Time(s) |
Posted: Thu Jun 07, 2007 8:28 am Post subject: engine mounts |
Super-helpful, Dennis... THANKS!!
[quote]From: "A. Dennis Savarese" <dsavarese(at)elmore.rr.com>
Reply-To: yak-list(at)matronics.com
To: <yak-list(at)matronics.com>
Subject: Re: engine mounts
Date: Thu, 7 Jun 2007 10:45:20 -0500
will make the job significantly easier. Before you remove the mags, remove
any grease or oil around the base of the mag where it mates with the
accessory case. Then using a Sharpie pen make 3 vertical marks between the
base of the magneto and the case about 1/4" to 3/8" apart. The marks will
enable you to reinstall the magnetos in precisely the same location and not
have to retime the magnetos. Replace one rubber mount at a time. The
attached document should help with how tight the plates, nuts and washers
should be.
Dennis
