		jeff(at)rmmm.net Guest
				 Posted: Sun Feb 12, 2006 4:45 pm    Post subject: RF Problem |
				HI All,
 I remember this was discussed before, but to know resolution as I
 recall. I Have been fighting an RF problem with my I-Com radio. The RF
 is obviously getting into the ground as even the trim LED's are
 effected. I have a Stratomaster engine monitor from MGL that seams to
 work great until I hit the push to talk button. It then goes black and
 the trim and Navaid LED's go crazy as well. I have a Bob Archer antenna
 in the tail and the radio sounds clear and transmits well. When tested
 with any other antenna the same thing occurs. The power to the antenna
 is about 7 watts and there was only about a half a watt or less coming
 back on the shield when tested.  I made sure some time ago that the com
 RG cable to the antenna was isolated from any other cables. We have
 checked, and all grounds are good on the radio. I have been told to
 install some ferrite RF suppressors on the ground and output of the
 transmitter and to place them on the ground and power going into the
 engine monitor. Before I order these have others run into this and have
 you determined the cause and solution? Any Ideas are very welcome as I
 have been scratching my head for a week!
 Thanks in advance,
 Jeff Roberts
 A258 - N128LJ
 Waiting inspection 1st week in March.
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Sun Feb 12, 2006 5:20 pm    Post subject: RF Problem |
				Jeff,
 I have a Bob Archer antenna in the tail of my Europa.  My trim control &
 Navaids go nuts when I transmit and I haven't ever solved the problem.  My
 SWR is spot on, and the I never have a problem being heard, so the
 transmitter is working well.
 I am about to go down the ferrite bead route as well, I would be interested
 to know how you get on.
 Paul
		SPurpura(at)aol.com Guest
				 Posted: Sun Feb 12, 2006 5:57 pm    Post subject: RF Problem |
				DOES YOUR RADIO SHARE A COMMON GROUND OR HAVE ITS OWN.
		flyinggpa(at)comcast.net Guest
				 Posted: Sun Feb 12, 2006 6:21 pm    Post subject: RF Problem |
				 	  | Quote: | 	 		  DOES YOUR RADIO SHARE A COMMON GROUND OR HAVE ITS OWN.
 I was thinking the same thing. The Navaid is having a voltage problem. Make sure the radio has "lots" of wire on the power side.  My BENDIX/KING called for two # 18 wires on both the + and  -  side.  I think "your problem" is what they were trying to avoid. It never hurts to have to much wire size.  (make it bigger)
		n3eu(at)COMCAST.NET Guest
				 Posted: Sun Feb 12, 2006 8:03 pm    Post subject: RF Problem |
				 	  | Quote: | 	 		   I was thinking the same thing.  Make sure the radio has
 "lots" of wire
  	  | Quote: | 	 		   on the power side.  My BENDIX/KING called for two # 18
 wires
  	  | Quote: | 	 		   on both the + and  -  side.  I think "your problem" is
 what they were
  	  | Quote: | 	 		   trying to avoid. It never hurts to have to much wire size.
 (make it bigger)
 Two wires for +14V IN and GND are for redundancy.  Rather
 common in avionics boxes.  I'm afraid lack thereof will not
 solve the orig complaint.  In plastic airplanes, the
 radiated field is a strong, vigorous one, easily affecting
 other electrical items.  In aluminum planes, those affected
 items are significantly shielded by the airframe.  I know
 this from me little handy field strength meter, while
 xmitting, with the meter inside my aluminum plane, vs.
 sticking it out the window in better line-of-sight from the
 xmitting antenna.  It's needle can peg with a resounding
 click!
 I'd first try the ferrite suppressors to trap the EMI
 radiated to wiring of affected devices. Those things abound
 everywhere these days from wall-brick "switching power
 supplies" to charge the battery in consumer devices, through
 those now found on the RF cable feeding digital, high-def TV
 sets or digital cable boxes.
 Reg,
 Fred F.
				 Posted: Sun Feb 12, 2006 8:45 pm    Post subject: RF Problem |
				Paul,
 I'm going to remove the panel and have the local avionics shop that
 wired it install the ferrite beads where I mentioned. As soon as I
 reinstall it I'll let you know. I guess I can live with it to but I'd
 rather fix it now if possible.
 Thank you all for your comments.
 Jeff
 A258 - N128LJ
 On Feb 12, 2006, at 7:15 PM, Paul McAllister wrote:
  <paul.mcallister(at)qia.net>
  Jeff,
   My
  interested
  Paul
		n9zes(at)verizon.net Guest
				 Posted: Mon Feb 13, 2006 5:52 am    Post subject: RF Problem |
				Jeff,
 Paul
 ---> I've had a bit of experience with RF problems, being a ham operator for the past decade or so, both with a 5 watt 144MHz handheld and also a 150 watt SSB HF radio.  The wierd part is the 5 watt radio caused more issues than the big rig.  I could wipe out every TV in our house with it.
 The problem is not with the transmitter, or the SWR of the antenna.  The problem is with other wiring, like the trim servo leads, picking up the radiated power and bringing it back to whatever is there.  The solid state components in the 'box' act like a diode rectifier (a.k.a. crystal radio) and that power just overloads the circuitry.  Most solid state electronics today is pretty well wide open to RF interferrence.  Telephones are usually really bad, TV's, alarm systems, touch lamps, etc. are great at getting RF into them.
 Part of the problem is the Europa itself. Since it's glass, the fuselage offers no internal shielding of other equipment from the radio transmissions like a Spam Can would.
 The other problem is that any leads to servos, lighting, etc. will pick up the transmitted power, and be especially bad if the lead lengths are a multiple of the frequency (in 1/4 wavelengths).
 A few solutions to try:
 1) Make sure the radio chassis is grounded well to the airframe ground bus.
 2) Make sure you are using good coax for the antenna lead (double shielded if necessary - foil and braid)
 3) Get a ferrite bead assortment (Amidon is one brand).  The ferrites do NOT go on the radio, but on everything else that is affected.  This would mean that signal and power leads to trim systems, engine monitors, etc. all need to have beads or torroids applied.
 4) In worst case situations, you need to actually shield the affected equipment itself, which means building a grounded box around the device from copper sheet, etc.
 Chris
		topglock(at)cox.net Guest
				 Posted: Mon Feb 13, 2006 10:26 am    Post subject: RF Problem |
				Jeff,
 I'm using the same setup Icom/Archer.  My coax runs through a 1" x 2"
 channel in the left of the fuse, along with the transponder coax, left
 wing wiring and a couple of other power wires.  You've ridden in the
 bird and, as you probably know, there is no interference, at all.  The
 only time I had a probelm, was with the mic going to open and affecting
 the trim, tripping the breaker.  That turned out to be a short in
 intercom wiring.  Once it was fixed, the problem went away.  I'd check
 all other connections, including grounds, just to be sure they are all
 good.  Other than that, I'm stumpped, but that's not hard to do...
 I know you're close to first flight.  Keep us apprised.  Hope to see you
 at Sun-N-Fun...
 Jeff - N55XS
 141 hours
 JEFF ROBERTS wrote:
  HI All,
  Thanks in advance,
  Jeff Roberts
  A258 - N128LJ
				 Posted: Mon Feb 13, 2006 1:38 pm    Post subject: RF Problem |
				Hi Jeff, hows it going? Yes I agree the ground is the most likely place
 it's getting in but I'v run a second ground to the radio rack the
 engine monitor the trim and still can't get rid of it. I'll try the
 ferrite beads next. I too ran all my coax down the opposite side
 keeping them away from the others wires. I'll be taking the panel to
 Ron Dupler at the local avionics shop and letting him have a stab at it
 as myself and two other local plastic plane builders are all stumped.
 Looks like Paul McCallister is having the same problem.
 I probably wont have the hours flown off by Sun & Fun but I still may
 be there. I have a friend that lives not far from Lakeland thats
 expecting me. I'll let you know or call your cell then.
 Thanks, and we'll let you know of the first flight.
 Jeff
 A258
 On Feb 13, 2006, at 12:06 PM, Jeff B wrote:
  Jeff,
  you
  at Sun-N-Fun...
  Jeff - N55XS
  141 hours
  JEFF ROBERTS wrote:
 > HI All,
 > antenna
 > com
 > have
 > Thanks in advance,
 > Jeff Roberts
 > A258 - N128LJ
		n3eu(at)comcast.net Guest
				 Posted: Mon Feb 13, 2006 2:58 pm    Post subject: RF Problem |
				Chris Beck wrote:
  	  | Quote: | 	 		   The weird part is the 5 watt radio caused more issues than
 it.
 Chris, ain't that fun.  My 2.3W-carrier VHF handheld, at 20
 feet from small (cheap) TVs, will briefly make the screen
 black and kill audio.  But just inches anywhere from a new,
 big Sony flat-screen digital -- absolutely nothing.  It may
 be as much circuit design as shielding of the "victim"
 device, as interference I guess is intolerable for the big
 bucks you have to pay!
  	  | Quote: | 	 		   2) Make sure you are using good coax for the antenna
 I would consider "bettering" the coax a last resort.  If I
 take said handheld and xmit in the vicinity of a RG-58 patch
 cable (unterminated) at the input of my 200mHz oscilloscope,
 coax about antenna length, I might see like only 10mV a few
 feet from this cable.
 Since receive is the reciprocal of xmit in these matters,
 the corollary is shielding the input wires to the victim
 device, single or multi-conductor as convenient.  The shield
 would not be a ground path, just grounded at the instrument
 end, I would say.
  	  | Quote: | 	 		   3) Get a ferrite bead assortment (Amidon is one brand).
 Ferrite beads or small toriod donuts have a frequency spec
 and may be less than what we need if small.  A larger donut
 allows spiral winding (twice at least) around the core.
 If instead of RG-58 in above test, I then use plain, solid
 wire.  Again about 1/4-wavelength.  Scope sensitivity will
 have to be readjusted...a lot!  If I lengthen the wire to
 random length (nonresonant), way down. If I then take a 1"
 ferrite cylinder with even 3/8" ID, pass the wire through it
 and near the BNC input, scope trace is way down.  Make one
 spiral turn around the ferrite, way down again.  So,
 ideally, the wire should be spiral-wound around a donut a
 couple times.  For instrumentation as the victim device, I'd
 try input wires first, like sensor wires.  Ten of millivolts
 on the 14V or ground wire shouldn't matter much.
 Google: ferrite core suppressor, for ideas, sources, and
 white papers on the science.  Rather than undo wiring, I'd
 first try the plastic encased clamp-on suppressors.  One may
 be able to liberate one off a consumer device wall charger,
 and affix it around the wire bundle to the instrument.  To
 see if we're going in the right direction.
 Reg,
 Fred F.
