wingsdown(at)verizon.net Guest
Posted: Thu Jun 07, 2007 12:50 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Moving sale all parts half off listed price. No room here in the new
smaller place.
Thanks.
KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: 02/06/07
Custom air oil separators (as seen on sportflight pic post) $150.00
each......................both for 250
CAP 140 complete hub assembly for NSI redrive, may fit others, no blades
$1,500 OBO.............
E.I digital EGT instrument, no probe $180 each or both for
$300.00....................
Hand held radio Yaesu VXA-200. This was there top of the line model and
should be compared to same now, has altitude,density altitude,pressure
alt. Temp, VOR heading plus extra Nmhi battery and programming software
and cable, list was over $600.00 sell for $350.00....................
Electric clock model MD-90 $60.00.....................
Electric servo/ jack screw assembly $500.00 OBO..................
Wheel pant left side only painted ready to mount or repaint
$50.00............
VDO gages:
2 1/8 tack , water temp,oil pressure, boost, large RPM 3 1/8 maybe 1/4,
EGT make offer..............
Horizontal Stabilator faired strut braces pair $100.00.................
Custom super trapp exhaust system. Will require the welding of a 3 bolt
flange to exhaust down pipe. $300.00 Pics on request....................
EA-81 turbo engine parts, blocks, engine mounts left and right, cranks,
rods, push rods, heads, cams, open price to be set, accepting
offers................
NSI alternator pulley New $60.00.......................
SS flight controls all factory parts available in excellent
condition....................
Carbon monoxide by co-guardian. Plugs into lighter socket audible plus
digital level indicator. They have a web site. $99.00 ...............
Airborne vacuum regulator valve model 2H3-23 #9AK FAA PMA list $728.00
in ACS catalog make offer..................
Airborne filter mount with filter best offer.............
Mr. Funnel large for water seperation funnel filling of fuel
$20.00...............
Remote PTT $5.00 with other purchse..............
Cessna dual vacuume gage with pop up no vac indicators can be used on
single system PN C668519-0101 $35.00............
Tire or tyre front Aero classic 11X4.00-5 8ply with new tube
$40.00......................
Accumulator brusher for NSI CAP
Model 5 nose gear bushings and extra set used pivot mounts with bushings
E.I. digital EGT gages (2)
Flight control mixers and related control linkages parts, rudder pedal
assemblies ect.
Thanks so much
Rick
3:49 PM
2:03 PM
john(at)leptron.com Guest
Posted: Thu Jun 07, 2007 1:57 pm Post subject: KITFOX PARTS AND OTHER AIRCRAFT PARTS FOR SALE UPDATE: |
Rick tell me about this, is it the older 3/16 or the newer 1/4 heavy bolts,
and faired, streamlined tubing or plastic.
John Oakley
