dfmoeller
Posted: Thu Jun 07, 2007 2:22 pm Post subject: Another Question on Priming |
OK. Here is yet one more question about the black art of priming/corrosion protecting your structure.
I see that Zenith automatically applies CORTEC to interfacial areas on the parts that make up the spars they build. They do not, however, apply the protection to the external surfaces of the spars. By this, I'm referring to the areas where the rivet's heads and tails bear on the aluminum sandwich.
I can certainly see the wisdom of only applying primer to the interfaces between parts rather than the entire parts. This is where the moisture will wick and cause corrosion.
My question is though, shouldn't the surfaces that will bear the rivets get the same treatment. OR, I had a thought that perhaps the rivet's bearing surfaces form essentially a gas tight seal with the part underneath, needing no protection.
I realize that my descriptions above may be a little cryptic - sorry. Another way to describe this would be when riveting part A to part B, I would think one should prime both sides of parts A and B rather than just the interface between A and B because corrosion could start in the interface between the rivet head and A or the interface between B and the rivet tail. The spars aren't built like that though.
If anyone knows why the surfaces that the rivets bear on are not protected, please enlighten me!
Doug
John Bolding
Posted: Thu Jun 07, 2007 2:51 pm Post subject: Another Question on Priming |
Not a chance, easy to demonstrate, watch what happens when you spray ACF50 or Corrosion X on the INSIDE of a wing . In a couple days there is a 2" circle around each rivet on the OUTSIDE where the penetrant has crawled through. Yeah, yeah, I know it's not apples to apples as water and penetrant have different properties but humid AIR CAN and will deposit moisture in those tight places. Seen it thousands (1000's)of times. If you aren't going to protect ALL faying surfaces during building, keep them protected with a treatment . I like ACF50 over Corrosion X but it's kinda a Ford -Chevy thing I think. Just use SOMETHING regular. John
Posted: Thu Jun 07, 2007 4:12 pm Post subject: Another Question on Priming |
flames on - I have my asbestos suit on.
I believe that all the surfaces you refer to should be primed - mine will be.
I will also be touching a Q-tip with ZPP to the opening in the head of each rivet and wiping with an acetone dampened cloth. The "coated steel" rivet mandrel is bare at the pintail break face.
I bought some of the Cortec primer but I am simply more comfortable with the ZPP so I am not going to use it.
dfmoeller <dfmoeller(at)austin.rr.com> wrote:[quote] --> Zenith-List message posted by: "dfmoeller"
I realize that my descriptions above may be a little cryptic - sorry. Another way to describe this would be when riveting part A to part B, I would think one should prime both sides of parts A and B rather than just the interface between A and B because corrosion could start in the interface between the rivet head and A or the interface between B and the rivet tail. The spars aren't built Luggage? GPS? Comic books?
Check out fitting [url=http://us.rd.yahoo.com/evt=48249/*http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz] gifts for grads[/url] at Yahoo! Search. [quote][b]
JohnDRead(at)aol.com Guest
Posted: Thu Jun 07, 2007 8:09 pm Post subject: Another Question on Priming |
Hello All:
I was using self etch primers when I started building. Recently I switched to Cortec 373 thinned three to one with denatured alcohol. This gives the recommended half mil coating thickness. I brush apply Cortec to all interfaces on the inside of the structure. I have not decided what to use as a primer when I get to final painting. The Cortec seems to bond very well without excessive preparation. I clean of all printed stuff on the parts and all the marking I have made with denatured alcohol, then a light rub over all surfaces with Scotchbrite finally a wipe down with denatured alcohol. I let the surfaces dry thoroughly before priming.
John Read
CH701 coming along nicely
See what's free at AOL.com.
