kdbelue(at)charter.net Guest
Posted: Thu Jun 07, 2007 8:03 pm Post subject: Mixture arm problem |
I have a Bendix servo on my IO540-C4B5 engine that has a straight mixture lever. It's not working out very well because the airbox interferes with it - even with the cutout. Does anyone know where I can get an offset mixture arm like most seem to have? The unit has these numbers:
Model: RSA-5AD1
Serial: 49426
Parts List: 4524213-11
My straight mixture arm has this number on it: 25220U4
I'd appreciate any help with this!
Kevin Belue
RV-6A >700 hrs
RV-10 finish work
Deems Davis
Posted: Thu Jun 07, 2007 8:26 pm Post subject: Mixture arm problem |
Call Don Rivera (at) Airflow Performance, I know they make offset levers
for their fuel controllers, He will be able to tell you if one of theirs
will fit the unit you've got.
Deems Davis # 406
Baffling / Plenum / Engine Stuff
http://deemsrv10.com/
rene(at)felker.com Guest
Posted: Thu Jun 07, 2007 8:28 pm Post subject: Mixture arm problem |
I was able to get one from aerosport power. Vans recommended them to me.
Rene' Felker
N423CF
40322
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kevin Belue
Sent: Thursday, June 07, 2007 9:41 PM
Subject: Mixture arm problem
Model: RSA-5AD1
Serial: 49426
Kevin Belue
RV-6A >700 hrs
RV-10 finish work
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
Posted: Fri Jun 08, 2007 5:47 am Post subject: Mixture arm problem |
The part number on N415EC is 2521287. Any of the shops mentioned should have them, including Mattituck, etc.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
Sent: Thursday, June 07, 2007 11:41 PM
Model: RSA-5AD1
Serial: 49426
Kevin Belue
RV-6A >700 hrs
RV-10 finish work
[quote] [b]
Posted: Fri Jun 08, 2007 12:28 pm Post subject: Mixture arm problem |
Aircraft Accessories in Oklahoma is sending me an offset mixture arm. Thanks for all of the replies!
Kevin
---- Kevin Belue <kdbelue(at)charter.net> wrote:
| Quote: | I have a Bendix servo on my IO540-C4B5 engine that has a straight mixture lever. It's not working out very well because the airbox interferes with it - even with the cutout. Does anyone know where I can get an offset mixture arm like most seem to have? The unit has these numbers:
Model: RSA-5AD1
Serial: 49426
Kevin Belue
RV-6A >700 hrs
RV-10 finish work
