		zackrv8
				 Posted: Fri Jun 08, 2007 9:09 am    Post subject: RV10 Doors Video |
				Guys,
    For those of you who did not get to the RV10 doors yet, you need to see this video.  Even those of you who have completed your RV10 and are flying around and are not happy with the way your doors close, you too need to see this.
   My brother Jim designed them and my Nephew Dave is producing them.  Either make them yourself, or get them from Dave, but put them in your Ten if you want to enhance the closing/locking of your RV10 doors.
   I first saw the problem with the rear door rod not engaging at Oshkosh last year.  I watched again and again as people got in Van's demonstrator and couldn't engage the rear door rod without a conscientious effort.  I initially made my door rods as per Vans plan.  The door did not "rack" properly when closed and was even worse when the door was latched.
   I know of several other RV10's with this safety problem.  The door guides are just one possible solution.  Take a look at this video and see for yourself.  Just remember that the rubber channel is not yet installed.  I will not use Vans supplied rubber channel on my plane.  I'm hunting around for something better that is softer.
   The Door Guides are CNC milled and are tapped from the back side so no screw heads are visible.  The screw pattern is the same as Vans.  If fact, if you haven't reached the stage of building your "plastic" door guides that Vans supplies in the kit, you won't have to drill that big hole through your vertical intercostal because the door pins don't go that far.
   The Door Pins are Stainless Steel, made on a CNC lathe, and have a magnet inserted in them so you can use Vans magnet switch for the door open warning system.  They screw right into Vans door rods (same threads).  You just have to cut the rods to the length you want.
 http://www.youtube.com/watch?v=fIDyecpfc30
 Zack
  _________________ RV8 #80125
RV10 # 40512 |
		flysrv10(at)gmail.com Guest
				 Posted: Fri Jun 08, 2007 9:36 am    Post subject: RV10 Doors Video |
				Zack,  The hardware looks fantastic.  I would like to see the same
 video with the door seals installed.  I know that my doors behaved
 very different once I installed the seals and did not fit as nice.
 In fact, I had to get a smaller diameter seal before I was satisfied
 with the operation.
 Do not archive.
 On Jun 8, 2007, at 1:09 PM, zackrv8 wrote:
  Guys,
  RV10 doors.
  Zack
  RV8 #80125
  RV10 # 40512
  http://forums.matronics.com/viewtopic.php?p=117311#117311
		Jim Berry
				 Posted: Fri Jun 08, 2007 9:40 am    Post subject: Re: RV10 Doors Video |
				Zack,
 Very slick. What is the cost?
 Jim Berry
 40482
		AV8ORJWC
				 Posted: Fri Jun 08, 2007 10:08 am    Post subject: RV10 Doors Video |
				Full Throttle Concepts has done a remarkable video.  Take the time to
 click on the final link below, the conclusion sells the Rivet Head
 product even if you don't conclude the factory doors need immediate
 improvement.  Class Act!
 John Cox -600
  Guys,
  RV10 doors.
  Zack
  RV8 #80125
  RV10 # 40512
		deutscht(at)rhwhotels.com Guest
				 Posted: Fri Jun 08, 2007 10:25 am    Post subject: RV10 Doors Video |
				Does anyone other than me have a concern about the strength of the joint
 where the "bullet" screws into the aluminum tube?
 Tom Deutsch
 #40545 75 hrs flying
		zackrv8
				 Posted: Fri Jun 08, 2007 11:36 am    Post subject: Re: RV10 Doors Video |
				Tom,
   The "Bullet" or "Door Pin" screws in Vans existing rod with at least an inch of threads.  Once the final length is cut from Vans rod and the Bullet tips do not extend pass the door edge, you then Lock-Tite them in.  The "Pins" are loaded in shear, not tension.  Your fiberglass door will break before then door pins break off the rod.
 Zack
  	  | deutscht(at)rhwhotels.com wrote: | 	 		  Does anyone other than me have a concern about the strength of the joint
 Tom Deutsch
RV10 # 40512 |
		zackrv8
				 Posted: Fri Jun 08, 2007 11:53 am    Post subject: Re: RV10 Doors Video |
				I really don't know the cost.  Call Dave at 302-437-6087.  He can help you with that.
 Joe
 quote="jim berry"]Zack,
 Jim Berry
 40482[/quote]
RV10 # 40512 |
		millstees(at)ameritech.ne Guest
				 Posted: Fri Jun 08, 2007 12:59 pm    Post subject: RV10 Doors Video |
				I paid $86.  Came in just a few days, and looks great.  I will be installing
 in the next week or so.
 Steve Mills N750SM (reserved)
 RV-10 40486 Slow-build
 Naperville, Illinois
 Finishing kit
		robin1(at)mrmoisture.com Guest
				 Posted: Fri Jun 08, 2007 3:22 pm    Post subject: RV10 Doors Video |
				Zack,
 	I was actually on the site yesterday looking for this product.
 The video is fantastic, the website is... well if I can say anything
 nice I won't say anything at all.
 	The site does not seem to display the door product or pricing.
 Can you inform the list as to the pricing and what is & is not included.
 Robin
		zackrv8
				 Posted: Sat Jun 09, 2007 6:02 pm    Post subject: Re: RV10 Doors Video |
				 	  | robin1(at)mrmoisture.com wrote: | 	 		  Zack,
 Robin
 Robin,
   Dave informed me the price will be $86 for the set.  The set includes 4 door guides (you probably will have to trim the thickness because every door is different) and 4 door pins.  The pins have the same thread pattern as the threads you already made in Van's existing door rod.  They screw right in.  You have to cut the rod to length so as to not let the door pins extend past the door edge.  Then, screw and Lock-Tite them in.  There is a magnet imbedded in the door pin so you will still be able to use Van's existing door warning switch.
 Zack
 (Yeah,  I know his website needs work, I told him about it!)
RV10 # 40512 |
		KiloPapa
  Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
				 Posted: Sat Jun 09, 2007 7:22 pm    Post subject: RV10 Doors Video |
				Rob,
 What seal did you end up using?
 Kevin
 40494
 <flysrv10(at)gmail.com>
  	  | Quote: | 	 		     In fact, I had to get a smaller diameter seal before I
 was satisfied   with the
  _________________ Kevin
40494
do not archive |
				 Posted: Sun Jun 10, 2007 3:19 am    Post subject: RV10 Doors Video |
				Kevin,  I used  Bulb seal, Item BA-1900010 from Brown Aircraft Supply
 in Jacksonville, FL.  904-396-6655.  The only thing I don't like
 about it is that it leaves a black mark that I clean once in a
 while.  However, the doors operate nicely and they are sealed.  You
 also need Rubber and Gasket Adhesive by 3M, part 1300L to attach this
 thing.
 You may want to get their one page catalog and make your own
 determination.  I think that they only sell door seals.
 Rob.
 On Jun 9, 2007, at 11:21 PM, kilopapa(at)antelecom.net wrote:
  Rob,
  Kevin
  40494
 > <snip>
 > operation.
		KiloPapa
				 Posted: Thu Jun 14, 2007 4:50 pm    Post subject: RV10 Doors Video |
				Rob,
 Thanks for the info.
 Kevin
 40494
 ----- Original Message Follows -----
 Aircraft Supply   in Jacksonville, FL.  904-396-6655.  The
 only thing I don't like   about it is that it leaves a
 black mark that I clean once in a   while.  However, the
 doors operate nicely and they are sealed.  You   also need
   thing.
 own   determination.  I think that they only sell door
 seals.
 Rob.
 > Rob,
 > Thanks,
 > Kevin
 > 40494
40494
do not archive |
