wjones(at)brazoriainet.co Guest
Posted: Fri Jun 08, 2007 5:06 pm Post subject: Bending 6-B-21-1 & 2 |
Hello group ,I asked for some advice about a week ago on bending these tubes .I received some good ideas from several of you good people .Today I received my material from AS .I made the forms from 3/4" MDF today .My plan is to mount the forms to my table and try to bend to shape around the forms .May have to pack with sand as Larry suggested .Anyone see any problems in doing it this way, maybe I should have ordered additional material for screw ups. Thanks DO NOT ARCHIVE
Wade Jones South Texas
601XL plans building
Cont. 0200
Posted: Fri Jun 08, 2007 5:48 pm Post subject: Bending 6-B-21-1 & 2 |
You can do the initial bend on the form by just grabbing the ends and pulling. This may take two people as the tube is so long. But due to spring-back you will have to use a tighter radius form to bring it to final shape. So after the first bend the form is just your template. I started with a 10 inch radius but had to finish the ends with a 5-6 inch radius. You might be able to skip the sand if your forms support the circular cross-section of the tube but why make the potentially expensive experiment? I just filled mine with sand, plugged both ends with some rubber stoppers from Home Depot held on with duct tape.
For me the process that worked best was to mark off sections on the tube with matching marks on the the form and work on sections proceeding from the center of the tube toward the ends. That way you aren't trying to adjust bends all over. If you overbend you *can* correct. Just don't do it too often in a given section as you will start work-hardening the tube. After a few bends I was able to get a feel for the spring-back. I was able to do one tube in an evening. BE PATIENT!
-- Craig
Posted: Sat Jun 09, 2007 5:50 am Post subject: Bending 6-B-21-1 & 2 |
Hi Wade,
You want to pack the tubes with sand because it will prevent the tube
from kinking as you go. The forms will get you half way,
but you should try the 3-point bend setup using casters, block tubes and
c-clamps to get it exactly right. You only have to bend
just a little at a time and lay it over the form outline to get it
extremely close. This arrangement will permit you to also unbend a little
here and there as necessary. No need for excess material if you take
your time.
http://www.macsmachine.com/images/fuselage/full/tubebender.gif
Larry McFarland
wade jones wrote:
| Quote: | Hello group ,I asked for some advice about a week ago on bending these
ARCHIVE
Cont. 0200
