lcottrell
Posted: Wed Jun 06, 2007 1:14 pm Post subject: FIRE!!!!! |
Sent: Wednesday, June 06, 2007 2:08 PM
Subject: Re: Re: FIRE!!!!!
Quote: |
JetPilot wrote:
> olendorf wrote:
>> I saw a guy pouring from a red plastic gas can into his Minimax and it
>> caught on fire. The guy had the sense to put the gas cap back on his
>> airplane tank really fast and no more fire. I was impressed.
The thing to remember is that you should always have a ground when fueling
your plane. If you insist on using a Mr Funnel, the ground should be
connected to each of the componets of the process, if not then you are at
risk. The fluid passing through the plastic openings build up static
electricity. I use a gascolator to prevent water building up in my tanks, I
also draw from the bottom of the fuel tank, so any water in the system will
be passed on to the gascolator. I have not yet ever found any in any of my
tanks. Of course it is so dry here that spitting could be a problem. I
transfer fuel to my plane using a siphon tube from a 5 gal gas can sitting
on the wing. I always make sure that the tube is touching both tanks and so
far have not had any problem. Hopefully this will always be so.
Larry C
crad238(at)verizon.net Guest
Posted: Wed Jun 06, 2007 4:40 pm Post subject: FIRE!!!!! |
Have been lurking on the list for several years.
I am a 40 some year veteran in chemical manufacturing. It is well
known that the pumping and pouring of a dielectric fluid (non conducting)
can build up tremendous static charges. Great pains are taken to ground all
sections of the system.
Pouring/ pumping such a fluid into a plastic container always entails
some risk.
Grounding of non conductive plastic containers is recommended but not
terribly effective.
lcottrell
Posted: Wed Jun 06, 2007 7:05 pm Post subject: FIRE!!!!! |
Russ Kinne
Posted: Thu Jun 07, 2007 7:06 am Post subject: FIRE!!!!! |
I've fueled from plastic cans many many times (hi-wing Cessna), in
Canada & when on floats. Never had a problem, thankfully. Only thing
I do, if I can, is hold spout closed with a fingertip until it's in
the tank neck and in contact. Mainly to avoid spilling. 'Cans' are
apparently non-conducting plastic, marked "UL Classified" Some are
'approved by the LAFD'.
On Jun 6, 2007, at 11:32 AM, JetPilot wrote:
Quote: |
> and it caught on fire. The guy had the sense to put the gas cap
> back on his airplane tank really fast and no more fire. I was
> impressed.
I have never heard of an airplane catching fire because of fueling
with plastic gas cans. Was he doing something strange, or did you
see anything that might have caused this to happen ?
Mike
"NO FEAR" - If you have no fear you did not go as fast
as you could have !!!
Kolb MK-III Xtra, 912-S
http://forums.matronics.com/viewtopic.php?p=116877#116877
lcottrell
Posted: Thu Jun 07, 2007 2:16 pm Post subject: Re: FIRE!!!!! |
----- Original Message -----
. It is well
> all sections of the system.
> some risk.
> terribly effective.
Carl,
It is also known that static releases occur when two surfaces containing
a static charge gets close enough for the charge to bridge the gap. It would
also follow that if there was no gap, there should be no release or spark
jump. It is my belief that by its construction and function that the Mr
Funnel causes a bit more of the static buildup than just pouring it into a
plastic gas container, so therefore if one insists on using it he would be
better off making sure that all of the components are at least grounded to
each other. Even if you do not use a Mr Funnel you should endeavor to
maintain contact between the receptacle and pouring spout. Terribly
effective or not.
Larry C
I posted this yesterday. It showed up on the regular list where we get each message, but not on this one. Oh by the way, it was not meant to be nasty, frustrated perhaps, but definately not nasty.
ropermike
Joined: 28 Aug 2006 Posts: 40 Location: West Texas, South Mississippi
Posted: Thu Jun 07, 2007 5:42 pm Post subject: Re: FIRE!!!!! |
I must tell you all, I was looking in the CPS catalog. The Mr Funnel description says that the funnel must be grounded while pouring fuel in it to prevent sparks and fires! Maybe I do deserve to be called a dumbass! I will use the grounding strap from now on...Mike
_________________ The next best thing to playing and winning is playing and losing!...Mike Hillger |
lcottrell
Posted: Thu Jun 07, 2007 7:07 pm Post subject: FIRE!!!!! |
by0ung(at)brigham.net Guest
Posted: Fri Jun 08, 2007 6:01 am Post subject: FIRE!!!!! |
'approved by the LAFD'.>>>>
Quote: | >>>>>>>>>>>>>>>>>>
Don't know if it makes any difference or not..... I have been told that
when transferring gas from a plastic container,,,, if you can keep the gas
from traveling through open air,,, the static buildup will be less....
Therefore I have glued a long clear plastic hose to the end of the spout on
my plastic tank.... by putting the end of the clear plastic hose into the
bottom of the receiving tank, the gas does not pass through the air,,, also
while pouring I grab the bare aluminum of the plane with my left hand while
holding the plastic can on my right shoulder and holding it with my right
hand... this is in an attempt to keep the tank and plane at somewhat the
same electrical potential. The fuel tank in the plane is grounded to the
frame.
Boyd
russ(at)rkiphoto.com Guest
Posted: Fri Jun 08, 2007 9:33 am Post subject: FIRE!!!!! |
Would be interested to see if the carbon-including plastic in a Mr.
Funnel is conductive . Can anyone with a funnel and a VOM check this?
The rubber in today's tires contains carbon and is conducting. Long
ago gas-station people would sometimes get a shock from a car that's
just driven in . All tank-trucks had a grounding chain trailing on
the ground . Not needed nowadays.
Grounding never hurts. How many of you carry a fire-extinguisher in
your aircraft?
When flames start is NO time to go looking for one.
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Fri Jun 08, 2007 4:26 pm Post subject: FIRE!!!!! |
In a message dated 6/6/2007 4:11:20 P.M. Eastern Daylight Time, ceengland(at)bellsouth.net writes:
Quote: | JetPilot wrote:
Quote: | --> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
olendorf wrote:
> I saw a guy pouring from a red plastic gas can into his Minimax and it caught on fire. The guy had the sense to put the gas cap back on his airplane tank really fast and no more fire. I was impressed.
I have never heard of an airplane catching fire because of fueling with plastic gas cans. Was he doing something strange, or did you see anything that might have caused this to happen ?
Mike
Happened to a friend of mine who flies a rotary powered RV-6. I can send
you his email account of what happened, if you like. He stopped the fire
with the same techniques mentioned by others: cap the fuel tank on the
plane & put out the fire in the gas can with an extinguisher.
He won't use auto fuel any more; fuels only from avgas pumps now.
On the other hand, millions of people fuel boats, cars, lawnmowers,
planes, etc from plastic cans every day with no problems.
About a dozen people had car wrecks within 20 miles of each one of us
today. Anyone plan to stop driving?
Charlie
One thing that has not been mentioned in the dialog about static sparks is that one of the conditions for this to happen is a low humidity day. The drier the surrounding air, the more support for the generation of a spark from the storage point,namely the nonconductive plastic. That is where the charge is stored...or on your clothing or some other nonconducting medium. When the humidity is higher, the charge can be siphoned off or conducted off into the air better thereby eliminating the charge in the first place. My recommendation is to be MORE careful during dry days, as that is when the likelyhood of a spark is greatest. Touching (not rubbing) with your hand all plastic surfaces will also minimize the possibility of a spark.
George Randolph
firestar driver from the Villages, Fl
See what's free at AOL.com.
_________________ George Randolph
Firestar driver, The Villages, fl |
Posted: Sat Jun 09, 2007 4:53 am Post subject: FIRE!!!!! |
Long
Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
I was able to go for a ride with a shirt tail relative / friend,,, in a
tanker hauling gas..... and the elimination of the grounding chain has
more to do with sophisticated electronics that has been added to the trucks
and trailers. Even higher performance aircraft will have static whips
added to help reduce static buildup in the airframe.
Boyd
Russ Kinne
Posted: Sat Jun 09, 2007 6:09 am Post subject: FIRE!!!!! |
I always been told the static wicks on aircraft were to drain off
static charges that affected the radios & nav units.
On Jun 9, 2007, at 8:52 AM, boyd wrote:
Quote: |
Long
friend,,, in a
chain has
the trucks
whips
Boyd
