Connector for copilot stick grip
grantn
PostPosted: Fri Jun 15, 2007 2:17 pm    Post subject: Connector for copilot stick grip Reply with quote
I'm setting up dual trim and dual PTT in my RV9A using RAC pistol grips on both pilot & copilot sides, but would still like to remove the copilot stick once in a while when the wife stays home and I want to carry extra baggage on the passenger side. I'm wondering what others have done to allow quick disconnect and removal of the copilot stick. The inside diameter of the stick is about 3/4 inch, and I would need a six pin (circular?) connector. Any photos of others' efforts and sources for such a connector would be greatly appreciated.
Grant Neilson
Campbell River, B.C.
RV9A, wiring
[img]cid:187350422(at)15062007-1223[/img]
 Filesize:  3.69 KB
 Viewed:  2888 Time(s)
 Filesize:  15.13 KB
 Viewed:  524 Time(s)
jonlaury
PostPosted: Sat Jun 16, 2007 8:57 am    Post subject: Connector for copilot stick grip Reply with quote
Run your wiring out the bottom/side of your stick to a plug that is below your upholstery line. Use a quick disconnect pin (AC Spruce) or a bolt for the stick. Unplug, unbolt/disconnect, stow stick, load piano.
J
