		| Author | Message |
		| cptimm(at)telus.net Guest
				|  Posted: Sat Jun 16, 2007 10:14 am    Post subject: MicroAir Radio |   |
				| on 07/6/13 9:38 AM, Niels Kock at nielskock(at)get2net.dk wrote:
 Wise and true words, Ira.
 Niels
		| Back to top |  |
		| riddon(at)sent.com Guest
				|  Posted: Sat Jun 16, 2007 10:43 am    Post subject: MicroAir Radio |   |
				| Peter,
 I have had both a Microair radio and transponder installed and working
 for four years. The radio works fine although I have added a separate
 voice activated intercom. The transponder does not seem to have the
 range of some but generally I am happy with it. Service from Microair
 has been good. I did have a small problem with the transponder in the
 early days but they sent me an exchange unit FOC.
 If I were building again I would also look at the Xcom radio as this has
 vox intercom built in. http://www.mcp.com.au/xcom760/
 Hope this helps.
 Richard Iddon G-RIXS
 A friend of mine is wiring up his beautiful Jodel and is thinking of
 installing a MicroAir radio and transponder. Does anyone in our group
 have
 any experience with this make? Of particular interest is the performance
 of
 the intercom, since the radio seems to be o.k. in glider installations,
 where engine noise and vibrations are of no concern.
 Any comments would be greatly appreciated!
 Peter Timm
 C-GIET
 # 110,Classic Mono 912S, Airmaster
 15/06/2007 11:31
		| Back to top |  |
		| josok-e(at)ukolo.fi Guest
				|  Posted: Sat Jun 16, 2007 11:05 am    Post subject: MicroAir Radio |   |
				| Yes, good question Peter
 That is i can't find anything you wanted to know or were telling about
 that radio or anything else as a matter of fact. Still i would like to
 hear from somebody owning such a radio or a XCom about their experience.
 Did it need any service and how did that go?
 Jos Okhuijsen
 http://www.europaowners.org/kit600
		| Back to top |  |
		| mark.henwick(at)btconnect Guest
				|  Posted: Sat Jun 16, 2007 11:19 am    Post subject: MicroAir Radio |   |
				| Hi Peter
 It will be a while till I get my Europa flying, but I fitted a Microair
 radio in my CT2K and then removed it due to the electrical engine noise
 coming through from the Rotax.
 At the time I was chosing a replacement I decided to get a transponder as
 well and now have the Filser RT (ATR600) & TX (TRT800). Very happy with
 them. The Microair intercom was possibly slightly better than the Filser.
 Mark Henwick
  	  | Quote: |  	  | A friend of mine is wiring up his beautiful Jodel and is thinking of installing a MicroAir radio and transponder. Does anyone in our group have
 any experience with this make? Of particular interest is the performance of
  	  | Quote: |  	  | Peter Timm C-GIET
 11:31
		| Back to top |  |
		| avgashead(at)btinternet.c Guest
				|  Posted: Sat Jun 16, 2007 10:08 pm    Post subject: MicroAir Radio |   |
				| Peter, has your friend considered the Icom IC-A200? We bought one for
Our Emeraude, it is very clear with great range(picks up a French
 airfield on some days)and about £200 less than the Microair. So
 impressed I've just bought one for my Mono. A radio engineer who is
 helping me with the wiring is not very complimentary of the Microair.
 Richard Scanlan
 103 Mono
		| Back to top |  |
		| Paul Sistern
				|  Posted: Sun Jun 17, 2007 2:54 am    Post subject: Re: MicroAir Radio |   |
				| The Microair built-in intercom is not voice activated (VOX) and the volume setting is via a hole for a small screwdriver in the side of the case, so it can't be adjusted without removing the radio from the panel. It's best to turn the volume right down and use a separate intercom. That way, because it's not a VOX system and always open mic, you will not have to listen to cockpit noise which becomes a pain on long flights.
 I have been using the MicroAir radio now for 5 years and would give it about 7/10 for performance.
 As for the transponder, I was recently warned off them by ST Aviation, I believe they have, or have had, some sort of technical problem.
 Paul
		| Back to top |  |
		| topglock(at)cox.net Guest
				|  Posted: Sun Jun 17, 2007 6:39 am    Post subject: MicroAir Radio |   |
				| I can also vouch for the clearity and reliability of the icom A200.
Price is right, too...
 Jeff - Baby Blue
 296 hours
 Richard Scanlan
 103 Mono
		| Back to top |  |
