baremetl(at)gvtc.com Guest
Posted: Tue Jun 19, 2007 4:27 pm Post subject: LP4-3 Rivets |
Does anyone know if Aircraft Spruce sells a rivet that is equivalent to the LP4-3 that Van's supplies? I'm assembling an order for ACS but don't see the same rivet that Van's sells. I'm hoping to avoid an extra shipping and handling charge just for a few rivets.
Ivan Haecker -4 1370 hrs. S.Cen.TX
tsneidin(at)wisc.edu Guest
Posted: Tue Jun 19, 2007 5:33 pm Post subject: LP4-3 Rivets |
I tracked this down when I first needed to order more:
AVEX RIVETS (LP4-3) http://www.airpartsinc.com/catalog_gif/page18.htm
Non-structural blind rivet.
Aluminum rivet on steel stem. 1/8" diameter has 165 lbs. shear, 230 lbs. tensile.
5/32" diameter has 255 lbs. shear and 375 lbs. tensile.
1661 ( Low Profile ) Dome
View this page
Dia grip range Part # Price Each/100
1/8 .031 - .187 1661-0410 $7.95
5/32 .046 - .250 1661-0512i $7.95
Aircraft Spurce Cherry Rivets
MINIMUM RIVET SHEAR AND TENSILE STRENGTH (Ibs.)
RIVET
DIA.
BS SERIES ALUM RIVET / STEEL MAND. GRADE 19
MS SERIES MONEL RIVET / STEEL MAND.GRADE 40
CC SERIES STAINLESS RIVET / STAINLESS MAND. GRADE 51
Shear Tens Shear Tens Shear Tens
3/32 125 175 200 300 230 280
1/8 200 325 350 525 450 600
5/32 325 450 600 900 750 1000
3/16 430 650 750 1100 1000 1300
1/4 750 1050 1450 2150 1700 2250
When I asked Vans about using these:
Could you please provide me with the shear and tensile strength
| Quote: | numbers for the lp4-3 and lp4-4 rivets?
They're around 170 shear, 220 tensile, a little less than the BSP type.
Who makes these rivets?
Gesipa Mfg, NC
| Quote: | > Would the Cherry BSPS-43(44) or the AD41BS be _*fully*_ equivalent to
> the LP series?
They'd be an acceptable substitute, but they're more expensive.
Vans
Todd Neidinger
9A - fuse.
Waunakee, Wi
H.Ivan Haecker wrote:
| Quote: | Does anyone know if Aircraft Spruce sells a rivet that is equivalent
Posted: Tue Jun 19, 2007 5:38 pm Post subject: LP4-3 Rivets |
| Quote: | Does anyone know if Aircraft Spruce sells a rivet that is equivalent to
http://www.hansonrivet.com/
Posted: Wed Jun 20, 2007 10:36 am Post subject: LP4-3 Rivets |
Tod,
Thanks for the info. Exactly what I was looking for. Glad to see the list
still works.
Ivan Do not archive
