lcfitt(at)sbcglobal.net Guest
Posted: Tue Jun 19, 2007 5:26 pm Post subject: Nose wheel and weight & balance for Classic IV |
John,
The problem here is that only a very few Model IVs have been converted to
nose wheel. There is no data available from either Skystar;s archives or
Kitfox Aircraft. It is a one-off design modification. I think this is what
prompted the original question. Is there anyone out there that has done
this and if so do you have the measurements and form for inputing the data.
The Six through the Seven and Sport have factory specs for nose wheel and
factory supplied documentation.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL Warp
1998 850 hrs.
Float Flyr
The problem, as I have said, is it's not compatible with the system of locating the CG and that is the system needed to document your CG.
You only need to do the weighing and measuring once and while a calculator will make life easier (it usually does) it can be done easily with a pencil and paper,eraser optional. These weighings and measurements are made with oil, coolant (if needed) and unusable fuel on board. the hardest part of the weighing is levelling the plane. To do the weighing it must be levelled as per designers instructions. I think the Kitfox uses the bottom of the pilot's door for levelling To do the calculations you need to know that an arm is a measurement from the datum along the longitudinal axis of the plane. The nose wheel or tail wheel will have an arm that will never change unless you change the configuration of the landing gear. In that case you will have to re-weigh the plane. (not too likely eh?) The main gear will have its own arm which again will never change. When you have the arms measured (once) and the empty weight measured (once) then you can do the empty weight and balance report.
Before each flight you only have to add the weight of the fuel at a given arm (never changes), the weight of front seat people (another arm never changes) and usually cargo is in a compartment which has another arm that never changes. With simple multiplication and addition the new CG for any weight location combo can be located. As long as the CG isn't too far forward or back too far (the flight envelope) you're good to go.
I think the Kitfox actually had you do the weighing with minimum and maximum flyable weights. that way it becomes impossible to fly out of balance as long as you don't put an anvil back in fuselage.
You will hear of guys putting their batteries in the tail of the plane to get a good balance. Once the empty weight balance is achieved and documented (the W&B report) then the monster will turn into a mouse.
Keep with it... It's not nearly so bad as it sounds.
[img]cid:030001823(at)19062007-3454[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
396 Time(s) |
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jdmcbean(at)kitfoxaircraf Guest
Posted: Tue Jun 19, 2007 6:58 pm Post subject: Nose wheel and weight & balance for Classic IV |
I had just caught the thread and sent an email to Francisco with a W&B
spreadsheet.
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
mclayton(at)rochester.rr. Guest
Posted: Wed Jun 20, 2007 2:44 am Post subject: Nose wheel and weight & balance for Classic IV |
Something that might be helpful....
On the FAA website, you can find something called the "Weight and Balance Handbook" It does a good job of explaining the concepts, and gives you all the information necessary to determine weight and balance for your aircraft. As others have said, it is a very easy process to go through.
My job involves running flight operations for an experimental aircraft, where we frequently change the aircraft configuration and therefore weight and balance. We maintain a spreadsheet on the computer, which allows us to put in the necessary information to accurately calculate W&B for any aircraft configuration, with a few simple measurements: Weight and Distance of the Weight from the Datum of the aircraft. When we preflight the aircraft, we always review the W&B data to make sure that the CG is within the range specified by the manufacturer.
All of this takes very little time, and is easy to do. It will be one of the key things that will help to assure a safe flight. I highly recommend it!
mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
Mobile: 585-737-5506
8 Adams Trail
Spencerport, NY 14559
N16AF (KF II Rebuild in Progress)
On Jun 19, 2007, at 4:11 PM, JC Propellerdesign wrote:
[quote]Sure you can do it this way, (this is the normal way)
just make sure that the plane is in the correct angle it should be weighted.
Jan
[quote]---
Float Flyr
Posted: Wed Jun 20, 2007 8:25 am Post subject: Nose wheel and weight & balance for Classic IV |
North of the 49th we are allowed to have a second or third W&B in reserve to cover the different gear configurations... Just helps keep the paperwork, which can be considerable, down. The flight log designates which W&B is in effect at any given time. Helicopters and spray plane may also have additional W&B reports to designate the installation of different equipment.
Noel
Kitfox III-A
john(at)leptron.com Guest
Posted: Wed Jun 20, 2007 9:03 am Post subject: Nose wheel and weight & balance for Classic IV |
When I built my fox, I put together an owners manual that covered many W&B options, as in short wings, long wings, with and with out floats and skis and baggage compartment under. This was accepted by the FAA.
John Oakley
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Noel Loveys
Sent: Wednesday, June 20, 2007 10:25 AM
Subject: RE: Re: Nose wheel and weight & balance for Classic IV
Noel
propellerdesign(at)tele2. Guest
Posted: Wed Jun 20, 2007 9:26 am Post subject: Nose wheel and weight & balance for Classic IV |
For W&B you can use this spread sheet.
all you need is a datum, distance from datum to wheel(s) and datum to wing leading edge, plus the MAC in case of constant cord wings MAC is same as cord, use a weight and string to get the points down to floor where it is eazy to measure, you can use 2 inch masking tape to mark it on the floor. and the aircraft must be in the position stated by designer. so one scale under each wheel.
And, close the hangar doors!
Jan
Description: |
 Download |
Filename: |
Swift_w&b.xls |
Filesize: |
17 KB |
Downloaded: |
495 Time(s) |
kitfoxmike
Posted: Wed Jun 20, 2007 10:41 am Post subject: Re: Nose wheel and weight & balance for Classic IV |
That's funny, close the hangar doors. Sounds like me, whenever I do anything to the fox, I close the hangar doors. Don't want anybody seeing what you're doing do we. I'm serious here.
kitfoxmike
Posted: Wed Jun 20, 2007 2:07 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
I just had a recolection of when I did the weight and balance on my plane. I measured from the front of the wing to the bolt on the tail wheel and got something like 161 and used this for the arm for the tail wheel. Now you should be able to do the same with the nose wheel, but put a negative for the arm. I would think, correct me if I'm wrong. also make sure and go straight out on the measurment, not on an angle from wing to nose wheel.
Posted: Wed Jun 20, 2007 4:21 pm Post subject: Nose wheel and weight & balance for Classic IV |
Noel,
As a practical matter, we do basically the same thing. For various configurations, we have weight and balance info. This info is always reviewed pre-flight to make sure that we have the flight configuration and the weight and balance in sync. Also, we have the weight and balance data with us as soon as the aircraft is rolled out of the hangar, in the event of a ramp check. Again, all data needs to be logged, and checked pre-flight to insure safety. An airplane that is out of weight and balance limits is not safe to fly. In my mind this is one of the most basic things a pilot can do to ensure a safe flight, along with the rest of the pre-fight checklist.
8 Adams Trail
On Jun 20, 2007, at 12:24 PM, Noel Loveys wrote:
[quote] North of the 49th we are allowed to have a second or third W&B in reserve to cover the different gear configurations... Just helps keep the paperwork, which can be considerable, down. The flight log designates which W&B is in effect at any given time. Helicopters and spray plane may also have additional W&B reports to designate the installation of different equipment.
Noel
Posted: Wed Jun 20, 2007 6:44 pm Post subject: Nose wheel and weight & balance for Classic IV |
I wonder if I am mis-reading some of the previous posts on this subject. I
guess I'm a bit out of sync with some of them.
When I licensed, I weighed/calculated for most adverse forward CG and most
adverse aft CG. Basically that limits me to about 25 pounds in my baggage
area. This info is in a packet with the airworthiness certificate and
resides under the seat cushion. With that known, any combination of
passengers, cargo and fuel load is OK as long as the baggage sack is loaded
under 25 lbs. and I am not over gross (which calculation I can pretty much
do in my head just by looking at my passenger. With that in mind, when I go
on one of the protracted cross countrys, I pack most personal gear in a back
pack that is strapped in the passenger seat. Then a careful loading of
ultra light back packing gear - four pound tent and 1.5 pound sleeping bag
etc. goes in the baggage sack - well under 25 lbs. I haven't done a W&B
calculation since I changed to the aluminum spring gear back in about 2000.
Personally, I don't feel that I am an unsafe pilot for doing it this way.
When I worked for UAL for a time, I was what they called a SOR, basically a
flight planner. I did W&B calculations for a living but these airplanes
spread the payload over a long tube - souls and cargo and a manifest for
each flight was required by law before departure and under the circumsances
was most certainly prudent. Sometimes we had to block seats and or move
passengers. Sometimes the aft cargo pit was not used. It all depended on
the specific situation - fuel load along a swept wing, etc.
Are those that are doing a W&B before each flight actually flying Kitfoxes?
There was a freighter that went down East of Sacramento ten years or so ago
due to a mis\-ballanced airplane or shifting cargo, but is anyone aware of a
Kitfox going down due to a loading problem. I am curious now. Have I been
doing this all wrong or am I just mis reading some of the comments.
Lowell Fitt
Cameron Park, CA
1998 870 hrs.
wingnut
Posted: Wed Jun 20, 2007 6:59 pm Post subject: Re: Nose wheel and weight & balance for Classic IV |
Quote: | I wonder if I am mis-reading some of the previous posts on this subject. I
guess I'm a bit out of sync with some of them. |
Well said. When I bought my Kitfox, I played with the W&B charts enough to figure out that as long as I didn't put anything in the luggage sack behind the seat, there was no combination of pilot passenger or fuel that would put me outside of the safe zone.. Assuming that I'm under gross. Since then, I only worry about the W part of a W&B. Unfortunately, I'm heavy enough myself that I can't carry full fuel and an FAA standard passenger so it is something I check often. One day, I'm going to want to put some luggage back there and carry a passenger. When that happens, I'll pull out the W&B charts again.
_________________ Luis Rodriguez
Model IV 1200
Rotax 912UL
Flying Weekly
Laurens, SC (34A) |
dan(at)azshowersolutions. Guest
Posted: Wed Jun 20, 2007 7:42 pm Post subject: Nose wheel and weight & balance for Classic IV |
<is anyone aware of a
Kitfox going down due to a loading problem. >
Lowell,
If I remember right the KF Lite that the Banks Brothers built went down upon takeoff due to an improper weight distribution. This can happen to any of us if we get careless.
Dan Billingsley
Mesa, AZ
KF-IV , 912-s 314DW
Building http://www.azshowersolutions.com/Build1.html
Lynn Matteson
Posted: Thu Jun 21, 2007 4:50 am Post subject: Nose wheel and weight & balance for Classic IV |
When I did the loading for my recent trip, I weighed everything that
went into the plane. As much as I could, I put things that weren't
immediately necessary into the baggage sack. My sack has a capacity
of 40 lbs, and I loaded 39 lbs and 10 ounces into it. One day later,
I swapped places between my clothes bag and my sleeping bag, which
put the heavier clothes bag up in front of the seat. (I had removed
the right-side stick for the trip) This configuration put me well
within the CG range no matter what the fuel situation, or possible
passenger situation....barring anyone over about 220 lbs, I think.
And most of the time that I would have a passenger, I'd have all the
camping gear out of the plane. This is with the normal taildragger on
a IV.
Lynn Matteson
flying w/over 340 hrs
On Jun 20, 2007, at 10:42 PM, Lowell Fitt wrote:
Quote: |
<lcfitt(at)sbcglobal.net>
subject. I guess I'm a bit out of sync with some of them.
Kitfoxes? There was a freighter that went down East of Sacramento
ten years or so ago due to a mis\-ballanced airplane or shifting
cargo, but is anyone aware of a Kitfox going down due to a loading
problem. I am curious now. Have I been doing this all wrong or am
Lowell Fitt
Cameron Park, CA
1998 870 hrs.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
kitfoxmike
Posted: Thu Jun 21, 2007 5:27 am Post subject: Re: Nose wheel and weight & balance for Classic IV |
Lowell,
THe only thing I see you doing wrong is putting the paperwork under your seat. Suppose to be out in view of anybody entering your airplane. I sit mine on the back opening to the luggage, in a plastic baggy.
My fox is configured for 30lb in the back two 170lb each pass and pilot and two 13 gal tanks.
Posted: Thu Jun 21, 2007 6:24 am Post subject: Nose wheel and weight & balance for Classic IV |
Mike,
As I understand it, the registration has to be in plain view. That is
postioned appropriately with a reduced size copy of the airworthiness cert.
The registration cert. is on top. The original full size documents are
under the seat cushion. I have never seen an airplane with an 8-1/2"X11"
document in full view anywhere in the cockpit.
Lowell
Joel
Joined: 06 Oct 2006 Posts: 57 Location: Bremerton, WA USA
kitfoxmike
Posted: Thu Jun 21, 2007 8:22 am Post subject: Re: Nose wheel and weight & balance for Classic IV |
Lowell
my mistake, I thought you were putting all your paperwork under the seat. I find it easier to just fold up the paperwork and put it all with the airworthiness stuff.
Float Flyr
Posted: Thu Jun 21, 2007 11:16 am Post subject: Nose wheel and weight & balance for Classic IV |
Lowell you are correct on all accounts. You can certainly do your W&B for most forward and most rearward loading situations and as you said providing you don't put more than 25lb in your cargo area you're good to go.
This is not a standard empty weight W&B similar to what you used to do. As you mentioned when you use the standard W&B form you will have to W&B calculations before every flight.
My aircraft was weighed and the Empty weight CG was calculated as was a forward most CG ( gas in the header and an 85 lb. pilot. The maximum weight was also calculated (full tanks and something like 250lb in the front seats and 50 lb in the cargo cabinet behind the seats). As I mentioned to Michel on floats as the weight increases the back of the floats sink lower.... All I really need to do is check the back of the floats before take off.... If they are under water I'm over weight and also out of W&B.
[img]cid:949221519(at)21062007-1303[/img]
Canada
Aerocet 1100s
[quote] --
Description: |
Filesize: |
19.77 KB |
Viewed: |
386 Time(s) |
Kitfox III-A
Float Flyr
Posted: Tue Jun 26, 2007 6:28 am Post subject: Nose wheel and weight & balance for Classic IV |
I also do a post flight inspection. That's when the niggling little things I noticed during the flight are still fresh in my mind. Inspections are a great way to avoid problems, legal and otherwise.
A description of exactly which W&B report is in effect has to be entered into the journey log for the airplane before it is allowed to fly with a new configuration.
The running joke around here is when the paperwork is approximately equal to the weight of the plane it MAY be allowed to fly! My kitfox, flying, is almost there
Canada
Aerocet 1100s
Kitfox III-A
