rjdaugh
Posted: Mon Jun 25, 2007 8:57 am Post subject: No Title |
Barry,
I don’t understand what you mean by carburetor temperature. Where do you measure it?
I like Rick’s suggestion. It maybe that one float valve was better able to contain the pressure than the other when there seemed to be a difference from one side to the other.
Randy Daughenbaugh, N10NH
Black Hills of South Dakota, - Near Mount Rushmore
Home Strip, Grass Room in Hangar for visitors
Series 5/7 (7 Firewall Forward) 912S, Warp Drive Taper Tip
Gross Weight 1320 lbs, Flying since November 2004
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Barry West
Sent: Monday, June 25, 2007 8:37 AM
To: Kitfox List
Subject:
Engine Running Rough
In January, 2007 my Kitfox IV with a 912 S engine threw all three blades of my GSC propeller. There was one big “bump,” the engine stopped and I landed without incidence. Observation of the engine revealed that both carburetors came off and the engine mount was damaged. I sent the gearbox to Lockwood and performed a runout test on the crankshaft with no damage either indicated. After installing a new propeller and engine mount, the engine ran fine for about 12 hours of local flights.
Then, Saturday before last, June 16, during a Young Eagles rally, the engine started running rough. It would idle smooth but became very rough at about 3000 rpm. I suspected a kinked fuel line, removed the fire shield, saw nothing, and replaced it. Then it ran smooth and I flew it a few times with no problem. The next day I flew it about an hour with no problem. Last Friday, June 22, I started it and it was rough again at about 3000 rpm – I mean really rough and would not run at a higher rpm. In both of these situations the right carburetor was considerably cooler than the left.
At this point, I thought it appropriate to run a compression check but when I removed the first spark plug I saw it was heavily coated with soot. I removed all the plugs and they all were the same way. Then I opened both carburetors, top and bottom, but could see nothing that would cause the mixture to be rich. These plugs only had about 25 hours on them. I installed a set of old but clean plugs and put the carburetors back together, started the engine and this time it went to about 4000 rpm before cutting out and running rough. Now the carburetors are both about the same temperature. I removed the top plugs and the ones on the left side were clean and the ones on the right side were covered with soot.
What to do? I tend to believe the shock of losing the propeller blades caused some kind of problem with the carburetors.
Barry West
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 01234
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
kitfoxmike
Posted: Mon Jun 25, 2007 11:56 am Post subject: Re: No Title |
I think your problem is something new, I think the problem is in the carbs or carb. I recently went through some test trials , or whatever, with my 912ul lately that sounds close to your endevour. 3000 would not run, started while I was balancing the carbs. I pulled the choke and it ran better. So off came the bowls and looked at everything, finally I took some carb cleaner and removed the jets for the idle circuit, or the mid circuit, whatever it's called. It's the one in front of the main jets with meter rod. This circuit runs just in front of the air filter, there are three holes, the one for this circuit is on one side and it has a real small hole, about .025. After running carb cleaner and compressed air through this, walla, I have a running engine again. I since have replaced the air filters and the latest problem was the flange on the right side split open right at the lip that is inside that locks the carb in place. Got new flanges, mikuni's, Rotax ones don't work on the kitfox, why? because the intakes are reversed and there is more swing and vibration than the stock rotax engine. The mikuni is stiffer, so it holds together better. Anyway, after cleaning the carbs, fresh plugs, balancing the carbs. This plane is way cool now. Oh, and make sure the choke closes all the way.
hope this helps
