Jaybannist(at)cs.com Guest
Posted: Wed Jun 27, 2007 5:40 am Post subject: Fuel Selector |
I had two problems with the ZAC-supplied fuel selector valve. 1) When I screwed the right angle hose barb fittings into the valve body, one of them could not be oriented correctly (by a long way). Not a product flaw, just the luck of the draw. 2) I painted myself into a corner by fabricating the center console panel, leaving the selector valve installation 'til last. As a result, I didn't have enough room for the selector valve and its fittings.
My solution was to buy a new selector valve from Andair with banjo fittings. I can make it fit, but I will have lower it about 5mm and rotate it 45 degrees. See photos.
Jay in Dallas
18.42 KB |
379 Time(s) |
25.7 KB |
370 Time(s) |
23.2 KB |
382 Time(s) |
601zv(at)ritternet.com Guest
Posted: Wed Jun 27, 2007 6:25 am Post subject: Fuel Selector |
Not cheap, but you could use the Andair extension parts and retain the
original handle position and orientation using either valve. I'm extending
my Andair 5-Way valve down to the cokpit floor.
