n914va(at)bvunet.net Guest
Posted: Fri Jun 29, 2007 6:45 am Post subject: Tailplane design |
The person that started my kit did not have faith in the tail plane design, nor do I. He designed and built a pinned clamping system that fits inside the fuselage that would prevent any play from developing due to wear. I don't feel that the retention between TP-4 and Tp-6 tubes to be adequate because of the thin wall. If any play at all was present at assembly, it seems that the slight movement would increase the size of the holes to where it became excessive. I've attached a PDF file ofwhat I would like to do to change it, but am not sure that it can be done with 100% realiability. Maybe there are some engineers out there that can. The 3/8" modification has not been done, so the idea of drilling out slightly smaller than 3/8" and driving increasingly larger pins through to expand the holes to 3/8" while work hardening them seems to be my other recourse. BTW, my old Sears garden tractor used the same method of attaching the front axle to the frame as the present system of a pin through thin walled metal and assembly that had worn so badly in one year that it was hard to steer and impossible to mow evenly. I took the axle off and had a tube welded in it and collars welded to the frame and was able to get 8 years of satifactory service from it until the motor gave up.
I have pictures of the clamp collars made and installed in my kit by the previous builder if anyone is interested.
Vaughn Teegarden
N914VA - no progress
Description: |
 Download |
Filename: |
scan0010.pdf |
Filesize: |
121.01 KB |
Downloaded: |
301 Time(s) |
Brian Davies
Posted: Fri Jun 29, 2007 8:14 am Post subject: Tailplane design |
Vaughn,
Are you sure you mean TP6 retention? My understanding is that a tight fit at TP6 is not desireable because it can transfer loads to TP6 if there is play at other points in the sytem and this can lead to TP6 disbonding from the tail plane.
Your method may be more appropriate at the TP12/ TP14 locations, which is, I suspect what you really meant.
Brian Davies
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Europa List
Sent: 29 June 2007 15:45
Subject: Tailplane design
Vaughn Teegarden
AVG Free Date: 28/06/2007 17:57
28/06/2007 17:57
Posted: Fri Jun 29, 2007 9:14 am Post subject: Tailplane design |
No Brian, I was off on a stupid binge which was thankfully stopped by your comment. Never mind. Sometimes too much thinking leads me to fruitless thinking and time wasted on my part.
N914VA
tonywickens(at)btconnect. Guest
Posted: Fri Jun 29, 2007 4:51 pm Post subject: Tailplane design |
Vaughn
It would certainly have more bearing surface which is good but if you do mean TP12 how would you get it through the TP11 bearing?
Tony
Posted: Fri Jun 29, 2007 7:03 pm Post subject: Tailplane design |
No, I was refering to TP-4 And TP-6, but I was totally wrong in my thinking. Ther is no need to even continue the discussion. I am embarassed by my stupidity at times, this being one of them.
Vaughn
Posted: Sat Jun 30, 2007 3:45 am Post subject: Tailplane design |
Vaughn
the most stupid thing is to refuse to acknowledge mistakes, the man who
never made a mistake never made anything
Graham
Europa List wrote:
[quote] No, I was refering to TP-4 And TP-6, but I was totally wrong in my
Vaughn
Posted: Sat Jun 30, 2007 6:06 am Post subject: Tailplane design |
Graham,
Thanks for the kind words. It's funny how a forum member's short sentence
can turn on the light in my dimly lit, cobwebbed mind. Making the mistakes
on the forum is preferable to making them on the aircraft. The forum is
indeed a valuable resource.
Vaughn
