dhall(at)donka.net Guest
Posted: Tue Feb 14, 2006 12:41 pm Post subject: No Title |
I got the idea to use PVC from other builders. It's easy to push wires through PVC.
Here's where I cut the hole.
http://donka.net/gallery/view_photo.php?set_albumName=spars&id=DSC04746
The location works out great as it will put the PVC just below the aft edge of the wing access panels. The access panel is not obstructed, and the conduit is right there to pluck wires from for pitot or autopilot.
Here's a shot of the PVC in the wing.
http://donka.net/gallery/view_photo.php?set_albumName=rightwing&id=DSC04843
other notes:
- I put the conduit in place before riveting the skins and it posed no added measure of difficulty while riveting.
- I put some blue RTV at all the PVC+Rib intersections to avoid any potential vibration or movement issues.
Date: Feb 12, 2006
Subject: PVC-tube in the wings?
Hi builders!
Thanks for the inputs on the flap hinge! I'll go for the split-pin metod then!
Another one:
I'm thinking towards intstalling wires in the wings also, and saw a builder on
the net who'd installed a small PVC-tube in the wings.
It made room for several wires (landing light, posn light, antenna etc)
Anyone else have done this?
It seems to me like a good idea??
Specially if I also put a light line in there so I can replace or add thing later.
Thoughts anyone??
Best regards Alf Olav Frog / Norway
Don Hall
N517DG (registered)
rv7 empennage
http:\\donka.net\rv7project.html
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
