bill_dom(at)yahoo.com Guest
Posted: Tue Jul 03, 2007 2:20 pm Post subject: Scratch Building Fuel Tank |
I’m strongly leaning toward building my fuel tanks using the riveting and pro-seal method instead of welding it. I read the archives and there where a significant number of builders using the pro-seal method in the past. I have 2 questions;
Is there any Zodiac currently flying with the pro-sealed and riveted tank method?
How sensitive to humidity is pro-seal when being applied?
William Dominguez
Zodiac 601XL Plans
Miami Florida
Afterfxllc(at)aol.com Guest
Posted: Tue Jul 03, 2007 2:34 pm Post subject: Scratch Building Fuel Tank |
William I don't know if this will help you or not but all Vans aircraft fuel
tanks are built with rivets and pro seal and I can tell you that if you go
that route you need to be ready for it to get every where. If you think about
it getting on something chances are it will be there. But it is some good
stuff and if you aren't gonna use it for a while after you buy it keep it in the
fridge it lasts longer.
Jeff
questions;
method?
William Dominguez
Zodiac 601XL Plans
Miami Florida
************************************** See what's free at http://www.aol.com
carlossa52(at)gmail.com Guest
Posted: Tue Jul 03, 2007 2:48 pm Post subject: Scratch Building Fuel Tank |
William, I am not flying yet, but I can share my building experience with you.
I have a bunch of pictures I can send your way - let me know...
(Actually, I have a 12.4 MB power point file I used for a presentation at the local EAA chapter).
I found that the trick is plenty of planning and preparation.
Carlos
On 03/07/07, William Dominguez < bill_dom(at)yahoo.com (bill_dom(at)yahoo.com)> wrote:[quote] I'm strongly leaning toward building my fuel tanks using the riveting and pro-seal method instead of welding it. I read the archives and there where a significant number of builders using the pro-seal method in the past. I have 2 questions;
William Dominguez
Zodiac 601XL Plans
Miami Florida
Posted: Tue Jul 03, 2007 3:19 pm Post subject: Scratch Building Fuel Tank |
Yes, I've also spent some time in the RV list archive and learned that the pro-seal is a very messy operation. The problem with the other alternative (welding) is either, buy a Tig welder (for the price of a tig welder you can buy the tanks from ZAC), gas weld it (need like a year or more to learn) or have it weld it by a professional (I don't know any good welder who could be up to the task and I don't like the idea of knowing someone is not good until your parts have been damaged). So the DIY with the messy pro-seal seems to be the best alternative.
William Dominguez
Zodiac 601XL Plans
Miami Florida
Afterfxllc(at)aol.com wrote:[quote] William I don't know if this will help you or not but all Vans aircraft fuel tanks are built with rivets and pro seal and I can tell you that if you go that route you need to be ready for it to get every where. If you think about it getting on something chances are it will be there. But it is some good stuff and if you aren't gonna use it for a while after you buy it keep it in the fridge it lasts longer.
Jeff
| Quote: | I’m strongly leaning toward building my fuel tanks using the riveting and pro-seal method instead of welding it. I read the archives and there where a significant number of builders using the pro-seal method in the past. I have 2 questions;
William Dominguez
Zodiac 601XL Plans
Miami Florida
Posted: Tue Jul 03, 2007 5:13 pm Post subject: Scratch Building Fuel Tank |
William what size tanks are you going to build?
See what's free at AOL.com.
TxDave
Posted: Tue Jul 03, 2007 11:56 pm Post subject: Re: Scratch Building Fuel Tank |
Hey William,
I used the rivet and sealant method on my tanks. Its really not as bad as some people make it out to be. Its messy, for sure, and the stuff sticks to everything. Carlos' pictures and advice were a big help. Van's now sells Flamemaster sealant which is what I used. Be sure to scuff up the aluminum and clean well with MEK before applying the sealant. I thoroughly tested my tanks for leaks with both air pressure and water. Not so much as a hint of a leak.
Dave Clay
www.daves601xl.com
Posted: Wed Jul 04, 2007 4:47 am Post subject: Scratch Building Fuel Tank |
In the corporate aircraft world the optimal sequence would be alkaline tank clean, phosphoric acid anodize, de-ionized water rinse, corrosion resistant epoxy primer, assemble fay sealed with polysulfide sealer. In our world, the best probably would be a thorough solvent degrease followed by a thorough scour with MMM 7447 - General Purpose Scotch-Brite™ Maroon or MMM 7448 - Ultra Fine Scotch-Brite™ Gray, soap and water wash/rinse, thorough MEK/acetone (in that order of preference from a health standpoint) wet/dry wipe, immediate epoxy prime, assemble fay sealed with polysulfide sealer.
We frequently use whichever of the two pads with acetone or water to keep the surface lubricated and extend the life of the pad. Do not attempt to keep using a pad that is "dull".
I noticed a product I have not tried that looks interesting MMM 6013 - Scuff-It™ Paint Prep Gel. It looks like it may be a mild abrasive in a gel that enhances the de-ox functions of Scotch-Brite????
Keep in mind that mechanically assembled tanks are not going to have ANY twist or warp that is not assembled into them and that the rivet pitch might need to be much closer to control bulge since the sealer is very viscous. While I was in Experimental at Cessna we built a tank section with no fasteners - it was a phenomenal success - but miserable to tool and build.
TxDave <dclaytx2(at)HOTMAIL.COM> wrote:[quote] --> Zenith-List message posted by: "TxDave"
Hey William,
I used the rivet and sealant method on my tanks. Its really not as bad as some people make it out to be. Its Now that's room service! Choose from over 150,000 hotels
in 45,000 destinations on Yahoo! Travel to find your fit. [quote][b]
Posted: Wed Jul 04, 2007 5:04 am Post subject: Scratch Building Fuel Tank |
Posted: Wed Jul 04, 2007 9:40 am Post subject: Scratch Building Fuel Tank |
Posted: Wed Jul 04, 2007 12:30 pm Post subject: Scratch Building Fuel Tank |
15 gallons
William Dominguez
