		knowvne(at)aol.com Guest
				 Posted: Tue Jul 03, 2007 7:28 am    Post subject: Federal Funding |
				How does some one determine if a field has received or is receiving
 federal funding ?
 Is there a list of fields some place for the public to review??
  Mark
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		rlaird
				 Posted: Tue Jul 03, 2007 7:55 am    Post subject: Federal Funding |
				By default, any airport designated as public is required to allow any
 aircraft to use it's services. This includes ultralights.  (If a
 private airport, designated for public use, has never taken federal or
 state funding, then they have the right to deny services, but how will
 you know until you land there?)  If a public airport owner can make a
 case to the FAA to disallow certain aircraft for particular reasons,
 then portions of or all services can be denied.  That information, as
 far as I understand it, is supposed to be published in the AFD
 (Airport/Facility Directory) for public use airports, so, if  you're
 at all concerned, then refer to the AFD for the airport you're
 interested in.
   -- Robert
  federal funding ?
  Mark
 _________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
formerly: MkIIIc w/ 912ULS  &  Gyrobee
current:  Autogyro Cavalon w/ 914ULS
Houston, TX area
http://www.Texas-Flyer.com |
				 Posted: Tue Jul 03, 2007 8:50 am    Post subject: Federal Funding |
				Interesting...
 I would have never guess the AFD would have listed such info... I'll
 take a look...
  Mark Vaughn
		Ralph B
				 Posted: Tue Jul 03, 2007 9:31 am    Post subject: Re: Federal Funding |
				"By default, any airport designated as public is required to allow any
 aircraft to use it's services. This includes ultralights."
 These rules were written before Sport Pilot and the FAA has ignored overweight ultralights for many years. Everyone knows that an ultralight is a single seat no more than 254 lbs empty weight, flies no faster than 63mph, and has a 5-gallon fuel capacity.
 Under the new rules, any aircraft (air vehicle) that doesn't meet this standard should be registered with the FAA. This means all overweight fixed-wings, trikes, and PPC's.
 After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this.
 If your machine is overweight and not registered after the deadline, your flights may be limited to private fields only.
 Ralph
 _________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
		rlaird
				 Posted: Tue Jul 03, 2007 9:51 am    Post subject: Federal Funding |
				I'm sure you're right, Ralph.  My statement would be more accurate to
 have said: "...any airport designated as public is required to allow
 any FAA recognized aircraft to use it's services.  This includes a
 valid FAR 103 ultralight."
 BTW, take a picture of one of those new signs and send it to me... I'm
 really curious!
   -- Robert
 On 7/3/07, Ralph B <ul15rhb(at)juno.com> wrote:
  Ralph
  Ralph B
  Original Firestar
  20 years flying it
  http://forums.matronics.com/viewtopic.php?p=122020#122020
Robert Laird
Houston, TX area
		rlaird
				 Posted: Tue Jul 03, 2007 9:58 am    Post subject: Federal Funding |
				Mark --
 Below is a snapshot of a A/FD entry for an airport just south of me... note the "no touch and go nighttime lngs"...  that's a restriction that either they asked the FAA for, or the FAA told them they had to abide by.  I've seen other A/FD entries for "No ultralight activities" but can't put my finger on one right now.
 As I mentioned, if an airport owner can make a good case, the FAA will add the restriction.  Sometimes, the FAA sees an issue (like a noise sensitive area) and will compel the airport to comply and will publish it in the A/FD, as shown in this excerpt.
  [img]cid:part1.05060408.04050107(at)cavediver.com[/img]
		|  Description: |
		|  Filesize: |
		 43.43 KB |
		|  Viewed: |
		 371 Time(s) |
Robert Laird
Houston, TX area
		Ralph B
				 Posted: Tue Jul 03, 2007 4:35 pm    Post subject: Re: Federal Funding |
 really curious!
 -- Robert
 Robert, here's your picture of the warning sign at the Red Wing airport.
 Here is what it says as it's hard to read with the way the camera took it on the inside of the glass:
 WARNING
 Any aircraft operating at the Red Wing Regional Airport not displaying a registration number nor meeting the definition of an ultralight vehicle
 will be reported to the Federal Aviation Administration for enforcement action. An ultralight vehicle is defined as a vehicle that:
 Is used or intended to be used for manned operation in the air by a single occupant
 Is used or intended to be used for recreation or sport purposes only
 Does not have any U.S. or foreign airworthiness certificate, and:
 If unpowered, weighs less than 155 pounds, or if powered, weighs less than 254 pounds empty weight, excluding floats and safety devices which are intended for deployment in a potentially catastrophic situation.
 Has a fuel capacity not exceeding 5 U.S. gallons.
 Is not capable of more than 55 knots calibrated airspeed at full power in level flight, and:
 Has a power-off stall speed which does not exceed 24 knots calibrated airspeed.
 If your ultralight does not meet the above definition, it must be operated in accordance with applicable aircraft regulations. You will be subject to enforcement actions ($1000 civil penalty for each violation) for each operation of this aircraft.
 Tom Blue, Caretaker
 Ralph B
		|  Description: |
		|  Filesize: |
		 44.14 KB |
		|  Viewed: |
		 372 Time(s) |
		Ed in JXN
				 Posted: Tue Jul 03, 2007 5:03 pm    Post subject: Federal Funding |
				This "caretaker" sounds fascist IMHO.  This is what happens when folks don't
 speak out.
 The vast majority of airports are UL-friendly, or at least tolerant.  I
 operate out of PTK (Pontiac, MI, tower-controlled) in GA aircraft, and there
 are several ultralights based there.  The UL guys go out of their way to
 comply, some even use radios!
 Ed in JXN
 MkII/503
		rlaird
				 Posted: Tue Jul 03, 2007 5:42 pm    Post subject: Federal Funding |
				Interesting (if not a little disgusting)... but how, I wonder, does he
 magically discern the weight of a single-seat UL, not to mention the
 speed, etc...?  And, does he not honor the FAA exemption for UL
 trainers?  There's no mention of that!
 I'll bet his mistress is named Eva and he wears brown shirts, eh?
   -- Robert
  really curious!
  -- Robert
  WARNING
  Tom Blue, Caretaker
  Ralph B
  http://forums.matronics.com/viewtopic.php?p=122083#122083
  http://forums.matronics.com//files/airport_warning_sign_148.jpg
Robert Laird
Houston, TX area
		jindoguy(at)gmail.com Guest
				 Posted: Tue Jul 03, 2007 6:48 pm    Post subject: Federal Funding |
				Robert, There is no such thing as an unlicensed ultralight trainer after Jan 31, 2008. After that you have to find a Sport Pilot CFI and a certificated LSA. If it's in the aircraft's operating limitations, an E-LSA can be used for training until Jan 31, 2010. After that it will be only S-LSA that can be used for training.
 Rick
 On 7/3/07, Robert Laird <rlaird(at)cavediver.com (rlaird(at)cavediver.com)> wrote:[quote] --> Kolb-List message posted by: "Robert Laird" <rlaird(at)cavediver.com (rlaird(at)cavediver.com)>
   -- Robert
  On 7/3/07, Ralph B <ul15rhb(at)juno.com (ul15rhb(at)juno.com)> wrote:
  	  | Quote: | 	 		   --> Kolb-List message posted by: "Ralph B" <ul15rhb(at)juno.com (ul15rhb(at)juno.com)>
  really curious!
  -- Robert
  WARNING
  Tom Blue, Caretaker
  Ralph B
 "Ya'll drop on in"
 takes on a whole new meaning
 when you live at the airport.  [quote][b]
		DAquaNut(at)aol.com Guest
				 Posted: Tue Jul 03, 2007 7:43 pm    Post subject: Federal Funding |
				In a message dated 7/3/2007 12:32:52 PM Central Standard Time, ul15rhb(at)juno.com writes:
  	  | Quote: | 	 		  After the deadline, the FAA will be able to keep overweight unregistered ultralights out of airports. Already we are seeing signs going up at our airports stating this.
 Ralph |
                Ralph,
          An aircraft that weighs more than 254 with a single seat is not an overweight ultralight. It is an illegal aircraft , if you dont have a license to fly and must be registered. On the other hand if the craft meets ALL requirements for an ultralight then it should be legal as a true ultralight today or after the deadline.  The FAA  has had the authority ,all along, to keep (    overweight unregistered ultralights) from flying anywhere in the USA .  It is my understanding that FAR 103 will not change at all.  I see  " SPORT PILOT" as the solution to force everyone to comply with the rules that have been in place all along.  Do the signs you are refering to address   Legal Ultralights?   My original comment was pertaining to Legal Ultralights.
           Ed Diebel
  See what's free at http://www.aol.com.  [quote][b]
		rlaird
				 Posted: Tue Jul 03, 2007 9:33 pm    Post subject: Federal Funding |
				Yup, well aware of that, but the sign exists now, so, I was just
 wondering why the "caretaker" wasn't taking care of -current- UL
 trainers.
 On 7/3/07, Richard Girard <jindoguy(at)gmail.com> wrote:
  	  | Quote: | 	 		   Robert, There is no such thing as an unlicensed ultralight trainer after Jan
  Rick
  >   -- Robert
  > > really curious!
  > > -- Robert
  > > WARNING
  single occupant
  airspeed.
  > > Tom Blue, Caretaker
  > > Ralph B
  > > Read this topic online here:
  > "Ya'll drop on in"
Robert Laird
Houston, TX area
		planecrazzzy Guest
				 Posted: Wed Jul 04, 2007 5:16 am    Post subject: Re: Federal Funding |
				Something that wasn't mentioned about Red Wing Airport....
  There are 3M "Jets" that Fly out of there.....I SURE that has something
 to do with not wanting UL's buzzing around....
  I'm sure there has been "Situations"
  I'm flying there Thursday morning to get my Transponder Cert.
  $75 for the Transponder & $75 for the Alt Encoder (cheapest I've Found)
 Gotta Fly...
 Mike & "Jaz" in MN - FSII / N381PM
		JetPilot
				 Posted: Wed Jul 04, 2007 10:54 am    Post subject: Re: Federal Funding |
				 	  | planecrazzzy wrote: |
 Gotta Fly...
 Where did you find a transponder for 75 bucks ?
 _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		planecrazzzy Guest
				 Posted: Thu Jul 05, 2007 2:29 am    Post subject: Re: Federal Funding |
 If you read it again....I'm getting it Certified....
  So , for $150 bucks....I'm buying a Piece of Paper......
  Now, if you've got $1,500....You can Buy a "NEW" :
 Narco AT 155 Transponder   w/AR850 Altitude Reporter
  Gotta Fly...
 Mike & "Jaz" in MN
  	  | JetPilot wrote: | 	 		   	  | planecrazzzy wrote: |
 Gotta Fly...
 Mike |
		|  Description: |
		|  Filesize: |
		 59.11 KB |
		|  Viewed: |
		 365 Time(s) |
		d-m-hague(at)comcast.net Guest
				 Posted: Thu Jul 05, 2007 1:34 pm    Post subject: Federal Funding |
				At 11:55 AM 7/3/2007, Robert Laird wrote:
 state funding, then they have the right to deny services...
 That's where the issue may arise.  Many airports are "privately owned for
 public use", and if these have received no federal funding they can deny
 landing to anybody, not just ultralights.  The airport I used to call home
 (N04, now sadly closed) was such an airport.  It was ultralight friendly,
 actually friendly to any aircraft that could deal with its 1800' strip, but
 required prior permission (which was always granted) from ALL transient
 aircraft.
 Many small airports were originally WWII training or auxiliary
 fields.  That qualifies as "receiving federal funding" even if the original
 acquisition was the only dealing with the feds.
                                  -Dana
 The only correct outcome to an armed robbery attempt is a dead armed robber.
