Albert Gardner
Posted: Thu Jul 05, 2007 2:10 pm Post subject: Garmin 496 Wiring |
Has anyone wired up their 496 and solved these problem I have encountered? I
am installing my 496 using the Air-Gizmos adaptor and Garmin's Power/Data
cable. I want to connect the 496 to my Tru-Trak autopilot, the Dynon 180
EFIS, and the PMA8000 audio panel. The Garmin cable has 9 wires while the
manual indicates only 7 (page 158). The manual says the yellow and blue
wires are "Data in and out" but the tag on the cable labels these as "Port 1
in and out". In addition, the cable has 2 wires not mentioned in the manual,
a green and violet pair labeled "Port 2 in and out".
Questions:
1. What signal will be present on the Voice output? I want the XM radio
signal to go to the audio panel, is this the right output to wire into an
entertainment input? Do any of the alarm outputs appear here?
2. The PMA8000 has 4 unswitched audio inputs available. I wired the Dynon
EFIS and EMS alarms into #1. I plan on wiring the Garmin alarm output into
#2. I am assuming that XM music will not be present on this 496 output.
3. Would you wire the Dynon EFIS and EMS alarms together and into a single
audio input (like Dynon suggests) or split them and wire into different
audio inputs, IE, #1 (EFIS) and #2 (EMS) with the Garmin going into #3?
4. What is the difference between the 496 output labeled Port 1 and Port 2?
I can find no mention of ports in the manual. Is there different information
on them? In the setup screens on the 496 I don't see any mention of Ports. I
am assuming I should wire the Port 1 in and out to the autopilot but the
Dynon EFIS needs that input also. Do I send it to both or should Port 1 go
to one and Port 2 to the other?
5. Apparently the 496 can tune the SL-30 Nav/Comm. If I choose to do this,
the SL-30 need a data output from the 496. How is this done?
6. There is an audio mini-jack on the back of the 496 in addition to the
wire in the wire in the cable assembly. If I wire the Alarm output into a
audio panel audio input and the Voice output into an entertainment input
have I separated the two signals so that the pilot gets the alarms and the
passengers get only the XM radio signal? I assume then that this jack is
only used when I remove the 496 from the plane.
Albert (lost in space) Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
stein(at)steinair.com Guest
Posted: Thu Jul 05, 2007 3:10 pm Post subject: Garmin 496 Wiring |
Hi Albert,
I'll take these in order the best I know how.
1) The voice output is useless (in my opinion, so don't hook it up)...even
the alarm output is marginally usefull - but that's just my personal
opinion.
2) Run the XM output from the 496 (use a stereo jack in the music output
port from the GPS - not part of the power/data cable) into an "entertainment
input" for the PMA.
3) Put the Dynon's together as they suggest.
4) Leave port 2 alone for now. Just split the port 1 wire to the various
components.
5) When you set the serial port 1, you choose "Aviation In/NMEA & VHF OUT".
6) You'll need that jack to send the music to the audio panel. In the
PMA8000, the Entertainment 1 is for front seaters and/or passengers and
Ent#2 is for passengers only. You can decide how to configure them by
pressing certain buttons on the panel - which will dictate who can hear what
when! Basically we suggest wiring the XM to to ENT #1 unless you're using
it for something else. We normally install the ENT#2 jack for the rear
seaters in case they bring along their own IPOD or DVD player or such.
Hope that helps!
Cheers,
Stein.
[quote]--
Albert Gardner
Posted: Thu Jul 05, 2007 3:46 pm Post subject: Garmin 496 Wiring |
Hey Stein, I would have called you but I thought you were all on vacation
this week. Thanks for the info, it was mucho needed. BTW, I think the
air-Gizmo bracket is going to work fine, it really makes a nice setup just
below the PMA8000 and above the SL-30 and 40.
Albert Gardner
Yuma, AZ
RV-10 N991RV |
