Posted: Fri Jul 06, 2007 6:11 pm Post subject: New FireFly Tail Wheel Spring System |
Kolbers, and FireFlyers,
I really wanted to get away from the tension spring and to use a clevis
spring. I could not find small light weight clevis springs. After several
iterations, I have a new system that uses compression springs in a way that
is equivalent to clevis springs. The new system can be seen at:
http://www.thirdshift.com/jack/firefly/firefly133.html
I believe the FireFly responds better to rudder pedal input than before,
especially in grass. Shaved off 1.5 ounces. While I was at it I bushed the
holes through which the hinge pin bolt passes.
I hope you have a good 7/7/07.
Jack B. Hart FF004
Winchester, IN
WhiskeyVictor36(at)aol.co Guest
Posted: Fri Jul 06, 2007 7:18 pm Post subject: New FireFly Tail Wheel Spring System |
In a message dated 7/6/2007 10:12:00 P.M. Eastern Daylight Time, jbhart(at)onlyinternet.net writes:
| Quote: | | I hope you have a good 7/7/07 |
Jack,
Make that 07/07/07
BV
See what's free at AOL.com.
