Albert Gardner
Posted: Sat Jul 07, 2007 1:38 pm Post subject: Dynon OAT Probe |
My Dynon 180 always shows -45F or -46F degrees AOT. I ordered another OAT
probe but it reads the same. This is the OAT probe with the black band that
connects into the remote compass box. Can't find anything wrong with the
wiring and the probe is configured as choice 2 in the setup menu just like
Dynon says.
Anyone else been down this road?
Albert Gardner
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
Tim Olson
Posted: Sun Jul 08, 2007 4:14 am Post subject: Dynon OAT Probe |
Quick question, Albert.... When you go outside in a T-Shirt, is it
REALLLY cold? If so, watch the local news and see if it's
really actually -45F. This should tell you if it's reading accurately.
(Sorry, just couldn't resist. Wish I had something helpful to offer)
Albert Gardner wrote:
Dynon says.
Albert Gardner
Yuma, AZ
ddddsp1(at)juno.com Guest
Posted: Sun Jul 08, 2007 6:25 am Post subject: Dynon OAT Probe |
Albert,
I believe you may have it wired wrong. Look at how you wired the resistor in line............Read the wiring instructions closely........call Eric at Dynon...........he will walk you through it.
DEAN
_____________________________________________________________
Click here to find singles for dating, romance and fun
Albert Gardner
Posted: Mon Jul 09, 2007 1:29 pm Post subject: Dynon OAT Probe |
OK, I found the answer to my question. Eric at Dynon told me the problem was
that the D-180 unit comes from the factory with General Purpose Input #1 set
up as an OAT input and needs to be changed to some other function or set to
Unused. This also applies to any other GP input as only one OAT can be
connected at a time. Otherwise, the probe connected to the compass module
conflicts with the GP input and shows -46F.
Also, the 3 wire probe (identified with a black bank) can be used as a 2
wire probe connected to a GP input but needs to be wired as follows: Yellow
wire is sig.; blue wire is ground; and red wire is unused.
Thanks, Eric.
Albert Gardner
Yuma, AZ
RV-10 N991RV |
Kellym
Posted: Mon Jul 09, 2007 6:19 pm Post subject: Dynon OAT Probe |
Well you at least got some E-cooling to relieve the current AZ heat
wave.
Thanks, Eric.
Albert Gardner
Yuma, AZ
KCHD |
