MauleDriver(at)nc.rr.com Guest
Posted: Thu Jul 12, 2007 4:39 am Post subject: QB Fuselage - Door Seal Angle problems (continued) |
I'm finding that the door seal angles F-10102A and F-10102B installed on
the QB fuselage, are not fabricated properly.
First, as reported in the archives, F-10102A is 1/16" too long and will
not butt up against tailcone longeron when joining the tailcone and
forward fuselage.
Second, the plans call for both seals to be trimmed to 3/8" below
longeron. Instead, the A section has been trimmed from 3/4" to 1/2". I
assume this is unacceptable and am currently trying to confirm that.
In any case, I believe I will have to remove parts, trim to proper
dimensions and reassemble. Comments welcome.
Bill "Ripping up and reassembling QB Fuse" Watson 40605
QB Fuse #484
BTW, they were recessed from skin 1/16" as called out in plans.
Previous problems with this part are noted here:
http://www.matronics.com/searching/getmsg_script.cgi?INDEX=10100994?KEYS=door_seal?LISTNAME=RV10?HITNUMBER 3?SERIAL=03461920015?SHOWBUTTONS=NO
