Eugene Zimmerman
Posted: Fri Jul 13, 2007 8:50 am Post subject: Kolb Rigging - Flaps and Ailerons |
On Jul 13, 2007, at 12:23 AM, JetPilot wrote:
What have you guys found ?? Anyone done any testing having the
flaps and ailerons rigged slightly up or down, and what is your
favorite way to rig your Kolb ?
I adjust them up/down according to the pitch trim desired.
Posted: Fri Jul 13, 2007 9:19 am Post subject: Kolb Rigging - Flaps and Ailerons |
As a starting point it is recommended that you rig them to be slightly down
or even with the bottom of the wing while lifting on the control surfaces a
bit to take the slack out of the control linkage.
Rick Neilsen
Redrive VW powered MKIIIC
